HDTV Calibration Sweep Method DIY - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-30-2011, 08:49 AM - Thread Starter
vincentfam's Avatar
Liked: 24
Greetings,
This is a method I discovered by accidentally adjusting contrast and brightness and seeing that these parameters have an effect on rgb levels during continuous measurements. Instead of focussing primarily on rgb levels at each window ire interval, I concentrated on what would be the best contrast and brightness level for my hdtv that would allow rgb levels close to 100 % from 30 ire to 80 ire. The reason that I call it the sweep method is simply sweeping or raising/lowering the contrast or brightness levels to produce consistent rgb levels across the grayscale.
I just calibrated my Samsung PN50b450 by using hcfr software and xrite eyeone lite and gamma response is pretty level. I have been DIY calibrating for over two years. Recently, I initially started using the HD DVE disc with the red/green/blue levels even at 100% at 80 ire. I then noticed the other rgb levels at 50, 60, and 70 were not level but were greatly affected when adjusting the contrast and brightness levels. I kept adjusting the rgb levels at from 50 to 80 ire by using the contrast/brightness controls (and also readjusting the rgb gain and offset levels if necessary to tweak the levels for consistency), and later separately rgb levels from 30 to 40 ire, until all rgb levels of the greyscale from 30 to 80 consistently came within 2 percent of 100% levels. This made my gamma a straight flat line and a terrific picture. My highest delta E is 2.5.
I think that all hdtv's have a sweet spot which can be found by adjusting (slowly but surely) the contrast and brightness settings to where rgb levels are consistent between 30 and 80 ire. For example, if your 70 ire has a red level at 95%, adjusting the constrast or brightness may raise this level while not affecting the 80 ire rgb levels. After I completed my adjustments, my 100 ire had a measurement of 40.8 ftL and the 10 ire was exactly .65% of the 100 ire, which may be perfect.
I call this the "sweep" method and it primarily involved adjusting the contrast and brightness levels and a lot of trial and error. See the images below for the gamma and rgb graphs.
Suggestions and protocols imho:
1. measure each window pattern while adjusting contrast or brightness in continuous measurement mode (green arrow). if using DVE patterns (not for avs) turn off continuous measurements when changing window patterns. also readjust rgb gains and offsets if necessary and for greyscale consistency when changing to a different contrast or brightness level.
2. make sure sensor is in middle of window pattern to avoid light impact on measurements from edges
3. light from on screen controls used while making adjustments may impact measurements. may need to turn off controls while in continuous measurements to get true measurement
4. plasma displays such as mine may need to warm up as much as 1 hour or more to obtain true color measurements
5. recalibrate sensor every 20 minutes or just prior to final greyscale measurement
6. turn off sharpness settings on your dvd or blu ray player when setting sharpness for your hdtv
7. follow Curt Palme's calibration for dummies religiously
The cell light was originally set at 10 - as recommended for this display, but readjusted to 9 to level out a bump in the gamma graph. I also attempted to lower the cell to 8 but the gamma graph just went bonkers.
The following are my settings for a dark room setting. The resulting gamma was 2.36 (the hcfr gamma setting preference for 2.4 for dark room environment), with static contrast at 1173:
movie mode
cell 9
contrast 87
brightness 53
sharpness 29
color 47
tint 50
gamma 0
color space auto
Grayscale:
offset: red 29, green 25, blue 35
gain: red 25, green 25, blue 45
mode warm2
16:9
hdmi black level low
all options off
Good Luck,
Vincentfam
Attachment 218751
Attachment 218752
vincentfam is offline
post #2 of 9 Old 08-09-2011, 06:20 PM - Thread Starter
vincentfam's Avatar
Liked: 24
Greetings again:
Below are other calibration settings I obtained using the above method for component cable connection for my samsung plasma hdtv. I have also attached the gamma graph which shows a very flat gamma curve.
One reason why the gamma curve may be flatter for 80 through 100 ire is because I used the small apl patterns instead of the window calibration patterns to avoid the automatic brightness limiter (abl) that is usually found on plasma tvs.
100% ire was measured at 50+ ftL, but this was probably high due to the use of small apl patterns.
Color readjusted back to 48
component cable, using apl small windiows
cell 9
contrast 89
brightness 53
sharpness 42 (used dve disc for sharpness with 720p pattern)
color 48
gamma 0
color space auto
offset red 35, green 25, blue 36
gain red 30, green 25, blue 44
mode warm2
16:9
all options off
As always,
Vincentfam
Attachment 219670
Attachment 219671
post #3 of 9 Old 08-27-2011, 04:12 AM - Thread Starter
vincentfam's Avatar
Liked: 24
Greetings finally,
I am posting the following "quote" from another discussion in this forum to further illustrate the calibration sweep method:
Originally Posted by vincentfam View Post
Plasma54321,
My hdtv model is the Samsung PN50B450 which does not have the 10 point grey scale adjustments. I think that this is a 2008 or 2009 model. I purchased it because it is a 720p model.
In using the sweep method, I only use the user gain and offset controls and not the service menu controls. Initially when I started calibrating the tv, I used the DVE disc while in movie mode to set contrast at about 40 to 45 ftL and brightness at the recommended level where you can see two bars in a pluge pattern and barely see the 4% below black bar. While adjusting rgb for the 80% ire window during "continuous measurements" with the hcfr software, I accidently moved the contrast adjustment and noticed that this had an impact on the rgb levels.
So, I adjusted the rgb levels using the user menu grey scale controls for 80 ire window close to 100% each. Next, I looked at the 70 ire window while still in continuous measurements mode and noticed that either the red or blue level dropped. Instead of using the rgb greyscale controls, I simply raised or lowered the contrast or brightness level to see if that would increase the levels close to 100%, or at least 98% color level. If increasing or lowering the contrast or brightness levels had an impact or leveled off the rgb levels for 70 ire window, then I would go back to see if 80 ire window rgb levels were still at 100%. If not, I would use the rgb gain controls to adjust the rgb levels at 70 ire close to 100%, then go back to 80 ire to see if the rgb level remain at 100%.
Next I would go to 60 and then 50 ire windows and adjust the contrast or brightness to where the rgb levels are close to 100%, going back and forth from the 80 ire window to see if all of the rgb levels were consistently showing close to 100%. In between all of this going back and forth in checking the rgb levels from 50 to 80 ire windows, you may have to make some adjustments with greyscale gain controls. Also, for my samsung, the contrast control had more impact on the rgb levels than the brightness control.
For the lower 30 and 40 ire windows, you can use the same process but also use the user menu offsets to perfect your adjustmens. Remember, any adjustment to these levels may affect your other levels. Edit note: I adjusted the brightness between 50 and 55 for proper black levels, as suggested by another person on this forum for this particular model.
I later started using APL patterns because I noticed that the picture would actually adjust itself during calibrations. I use these smaller patterns to avoid the automatic brightness limiter that may be on plasma tvs.
Also, I discovered that the on screen menus that pop up when you are changing ire windows may impact your readings. I usually wait until these displays disappear from the tv to determine the proper rgb measurements.
This method involves a lot of "going back and forth," and either I lucked up in finding a "sweet spot" on my tv or I have a lot of patience in finding contrast and brightness levels that consistently allow 98-100% rgb levels from 30 to 80 ire windows. I also double checked by black level with DVE disc and found it to be great.
Just to let you know, I previously owned a panasonic TH50PX77U that I believe produced a darker picture with a gamma around 1.8.
Good luck to you and let me know if I can clear anything up for you.
Edit Comment: Moral of the Story: There are many different calibration methods and use whatever works for you.
Vincentfam
In doing calibrations for my samsung, I used windows and small apl patterns. The apl's were used to avoid the automatic brightness limiter (abl) effects on my plasma. A recent calibration disclosed the effects of abl when my measurements @ 80 ire windows for blue and red suddenly dropped from 100% to 95% and there was nothing I could do raise them back to 100%, other than time and allowing the hdtv to readjust itself. Apparently, the tv was designed to have abl for its energy saver feature.
Final analysis: I am opting to use [Preference for using apl patterns deleted. Felt that post calibration using apl patterns may not produce realistic calibration. Picture appeared off. Went back to using regular window patterns for a calibration that provides a "real" response].
Forum Hint: "abl" is probably affecting your plasma tv calibration if your 100% ire ftL luminance (Y) reading for a small apl pattern is higher than a 100% ire ftl luminance (Y) reading for a regular windows pattern.
Nonetheless, sharpness is very important as well. Here is another quote that may be useful:
Plasma54321, . . .
After using the sweep method, the picture is noticeably very smooth, so smooth that I haven't calibrated my rgb levels for my tv for about two weeks - going on three. There is a definite difference which I noticed immediately. I think I hit a "sweet spot."
The only other significant thing that I had to do was adjusting sharpness, which isn't easy. I was told to adjust the sharpness for the samsung at "0", which actually made the picture blurry. Sharpness plays a major part of calibration. The pattern I used is on the DVE disc and I raised the sharpness from 0 until I start seeing noticeable halo artifacts from where I am viewing the tv. I found out that sharpness is related to the distance you are sitting from the tv. For example, the sharpness on my wife's LCD toshiba is cranked up very high. Her tv looks great from where she sits and views the tv, but looks horrible (too many artifacts) when you get close up on the tv. My samsung's sharpness is set at 52 right now and looks great.
Good luck,
Vincentfam . . . .
Edit Note: Sharpness adjustment - I check my hdtv's service manual that stated that a "720p" signal be used when calibrating. I previously used 1080i settings for calibration. I then calibrated sharpness using the DVE on my blu ray in 720p setting with a 720p sharpness pattern, which made a significant difference. Also, a recheck of rgb levels and the gamma curve revealed no changes.
Finally [Oct 3, 2011], I believe that this is a good calibration method, especially if your hdtv does not have the necessary picture controls like cuts or offsets, like my wife's Toshiba 37AV502, which doesn't have the cuts or bias controls in the service menu. Changing contrast and brightness impacts rgb in the 0 to 50% ire windows, much like bias, cuts, or offset controls.
Good luck,
As I remain, Vincentfam.
post #4 of 9 Old 04-18-2012, 05:03 PM
tedmales's Avatar
I am going to try these settings. I upgraded the firmware and lost my old settings and cannot take the nuclear explosion brightness without some adjustments
Hey hey, what can I do?
tedmales is offline
post #5 of 9 Old 04-19-2012, 01:12 PM
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
So are you saying you should use windows instead of apl? What about full windows.? I have led tv so...
kanti123 is offline
post #6 of 9 Old 04-21-2012, 09:36 PM - Thread Starter
vincentfam's Avatar
Liked: 24
tedmales,
You may want to check out my updated settings in the plasma display forum at this link: http://www.avsforum.com/avs-vb/showp...postcount=1235
I used the "ganging" method by equally increasing/decreasing the rgb gains and offsets, where necessary, and decreased the gamma setting in the advance settings to get an average gamma level between 2.4 and 2.5, which is recommended by some forum regulars. Also, later in that link above, I set the black tone to darkest and adjusted contrast to obtain proper brightness level to increase the static contrast ratio, with some adjustment to color and tint. Also used pop sharpness technique to get a pop from the picture. The thread is Samsung PN**B450 Picture Settings in the plasma display area. Picture looks great.
Good luck,
Vincentfam
post #7 of 9 Old 05-09-2012, 12:32 PM
nirman's Avatar
Hey guys,
Does anyone of you knows such a perfect setting for Sony KDL-ex520 series HDTV?
I don't have any calibration disc or device. And I would like to have the settings for my Sony Bravia KDL-32ex520. Let me know please.
nirman is offline
post #8 of 9 Old 05-10-2012, 08:40 PM
thebox's Avatar
Vincent,
Helpful tips. I"ll give a try.
Thank you.
thebox is offline
post #9 of 9 Old 05-11-2012, 06:59 AM - Thread Starter
vincentfam's Avatar
Liked: 24
thebox,
For your basic ganging technique, per this forum, evenly raising rgb gain levels will lower gamma level from 50 - 100 % gray, and vise versa. raising rgb cut or offsets will impact gamma level from 0 - 50 % gray. Lowering the rgb levels will of course raise the gamma levels. Please note that cell light settings also impact gamma levels.
You want to get a brightness level and contrast (picture) level where the contrast is at its highest possible setting that does not produce color at 100 % ire. For my samsung, anything over a contrast setting of 89 introduces a red tint.
Let me know how it turns out.
Vincentfam
Reply Display Calibration
