For those struggling with brightness, contrast & backlight settings on LCD's - Page 5 - AVS | Home Theater Discussions And Reviews
post #121 of 126 Old 03-24-2013, 09:29 AM
PlasmaPZ80U's Avatar
Quoted: 446 Post(s)
Liked: 256
Originally Posted by hungro View Post
If it can't be made barely visible then go with the setting that is darker.
any reason why? I thought you wanted the lowest setting that still shows 17 and up flashing
UN46EH6030 Calibration/Settings
Display: Samsung UN46EH6030 LED-LCD TV; Audio: Yamaha HTR-3066 AVR/AMP, Sony Core Bookshelves (Sony SS-CS5) and Center (Sony SS-CS8) as fronts, Cambridge Audio S20 Bookshelves (CA S20-N) as surrounds, Dayton Audio SUB-1200 as subwoofer; Sources: PS4 (doubles as primary BD player), Xbox One, PS3, Xbox 360, Motorola RNG150N (Cable Box)
PlasmaPZ80U is offline
post #122 of 126 Old 03-24-2013, 09:44 AM
buzzard767's Avatar
Quoted: 545 Post(s)
Liked: 1054
Normally. On a display with good black levels, 17 corresponds very closely with the Light Illusion pattern used to set black prior to profiling for LUT production. However, there are exceptions, some of it quite subjective. Take a look at this post of mine earlier in this thread - http://www.avsforum.com/t/1351213/for-those-struggling-with-brightness-contrast-backlight-settings-on-lcds/30#post_20771724
Buzz
THX Certified Video Calibrator
buzzard767 is online now
post #123 of 126 Old 03-24-2013, 10:56 AM
gtgray's Avatar
Quoted: 60 Post(s)
Liked: 64
Not necessarily, you don't want to have your all your near blacks to be elevated. It is a kind of damned if you do, damned if you don't. If 17 is too bright you maybe loosing contrast trading off for the last little bit of shadow detail. This is a judgment call and your room lighting will be important. My 92" DLP will cause 16 to be the slightest bit visible with your nose to the screen if you allow 17 to be visible. I opt for visible 18 and let the rest of it drop off, the overall pitcture quality is better but dark scenes with the lights on suffer.. especially since the display is glossy.
Mits WD-92840 92" DLP - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
Older 58" Panny Plasma -DVDO DUO, JBL Studio 530
Pioneer AJs, PSB Images, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #124 of 126 Old 03-24-2013, 06:57 PM
Quoted: 446 Post(s)
Liked: 256
does a display with a native CR of 3,000:1 have what you consider good black levels or are we talking about 2012 panasonic plasma black levels (10,000:1 and up native CR's)?
post #125 of 126 Old 03-26-2013, 02:11 PM
Quoted: 446 Post(s)
Liked: 256
I displayed that Light Illusion pattern on my PS3's XMB and saw that when I reduced brightness one click from the setting that shows digital 17 flashing (brightly), all the squares got much darker and the top left square (darkest one) disappeared mostly except for having some noise there that resembled the shape of the square... in other words on the verge of being visible (there was definitely something there, albeit extremely faint).
post #126 of 126 Old 04-30-2013, 04:26 AM
MSL_DK's Avatar
Quoted: 18 Post(s)
Originally Posted by alluringreality View Post
I haven't followed the HCFR fork after Version 2.1, but on the old version you can look at the measurement information in terms of RGB to find where a display might clip near white. On the right side of the HCFR Measures screen there is a "Display" setting that has pickboxes, which has choices like xyY or RGB. The measures screen also has a "Selected color" area that also displays R, G, and B numbers. There are also the "Target" bars that show how red, green, and blue relate to each other as a percentage (%), but I suggest looking at the R, G, and B numbers that generally are comparable to Y.
If you measure grayscale you would want the R, G, and B numbers to be approximately equal. As you turn up the contrast control you may find that one of the colors might stop increasing along with the other primaries. For example say a TV runs out of red, so R will get to a point where the R number might go no higher, but the B and G numbers can get much higher. Since R is unable to get any brighter, it would be necessary to set G and B to that same maximum value in order to display gray.
I've missed your reply. Thanks for the help;)
Samsung UE46H7005/7000 - Dynaudio Focus 200 XD
MSL_DK is offline
Reply Display Calibration
