Calibrated the display Wrongly.Help Please. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-24-2011, 08:44 AM - Thread Starter
s.ki_chelvee's Avatar
Hello guys,
I have just calibrated my LG LED monitor E2240 with CAlMAN using simulated display.Now I am seeing all those pink tinge in my screen Especially in bright areas.Can you tell me how I can reset this.I tried factory resetting but nothing worked.Pls help guys.I am screwed.Thanking You guys in advance.
s.ki_chelvee is offline
post #2 of 6 Old 09-24-2011, 11:28 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
Originally Posted by s.ki_chelvee View Post
Hello guys,
What do you mean using simulated display?
Simulated doesn't give any controls.
Did you use a meter?
sotti is offline
post #3 of 6 Old 09-24-2011, 03:11 PM
airbook's Avatar
Judging from his post history, I would say no.
He just wants someone to give him "settings".
airbook is offline
post #4 of 6 Old 09-24-2011, 06:14 PM - Thread Starter
I did not use any meter.I was just checking out the program but my niece or some one in my house just played with it and now My display is not looking well and has pink tinge in bright areas.I was very careless and I know that with out using a calorimeter it will spoil the monitor's pic quality.By the way they used pc calibration in calman to get in to the problem.Does reinstalling win7 helps or anyother suggesstions.Help please.
post #5 of 6 Old 09-24-2011, 08:01 PM
Dathon's Avatar
Yes, open command prompt, and type fdisk c:
then format c: That will cure all problems!
j/k. dont do that. Do you have blu-ray player? Buy spears&munsil bluray calibration disc, follow directions, and your display will look great afterwards.
Dathon is offline
post #6 of 6 Old 09-24-2011, 08:15 PM
PlasmaPZ80U's Avatar
Quoted: 2299 Post(s)
Liked: 707
can't you just reset all picture settings on the display?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
Reply Display Calibration
