Samsung Smarthub - AVS Forum | Home Theater Discussions And Reviews
Old 10-12-2011, 02:09 PM - Thread Starter
snoop832's Avatar
Do you have to calibrate the display for smarthub? And if you do how do you do it.... Thanks -A
snoop832 is offline
Old 10-13-2011, 06:22 PM
jdoostil's Avatar
on the older flat panels, anytime you do anything online, it reverts to dynamic. not 100% positive about this years models. when you are in the smarthub menu, see if you can change picture modes or at least access the picture settings. i personally am not a huge fan of "calibrated" when streaming. the quality of the stream is usually so bad, that i need to pump up some stuff. i remember watching "Shutter Island" calibrated, and streaming from Netflix, looked horrible
ISF certified in 2008
ISF Level II certified in 2010
ISF instructor certified in 2012
ISF International Trainer since 2014
ISFJasonD65@gmail.com
Serving Florida
jdoostil is offline
Old 10-18-2011, 01:22 PM
malica1's Avatar
How do I access the picture settings while in the Smart Hub. When ever I click menu while in the Smart Hub nothing happens. I just want to turn off the motion plus, it is driving me crazy while watching Netflix.
malica1 is offline
Old 10-18-2011, 01:24 PM
PlasmaPZ80U's Avatar
Quoted: 1966 Post(s)
Liked: 560
try tools
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
Old 10-18-2011, 01:31 PM
malica1's Avatar
Nothing happened with tools either. I tried pressing menu on the TV itself and I can not access the settings
malica1 is offline
Old 10-18-2011, 01:35 PM
malica1's Avatar
Just to clarify this is when I am using Netflix. I can access the menu while in the smart hub but the setting seem to be the settings for the HDMI input and as soon as I start a Netflix movie the settings change.
malica1 is offline
Old 10-18-2011, 06:02 PM
Wwright's Avatar
The picture setting for the Smarthub is dictated by the setting in TV.
Switch to channel 3, set your picture and you should be good to go.
Wwright is offline
Old 10-19-2011, 01:26 PM
malica1's Avatar
I tried that and Netflix is still showing the picture using motion plus.
malica1 is offline
Old 03-09-2012, 08:44 PM
Redfeyer's Avatar
Was this ever resolved? I have disabled motionplus on my samsung tv's smarthub but it continues to play on netflix. The same does not apply for my samsung dvd player but smarthub, but the dvd player is much slower and therefore less desireable to use.
Did anyone figure this out? Motionplus looks terrible if you're a movie buff!
Redfeyer is offline
Old 07-09-2013, 03:03 PM
trouptra's Avatar
I have a UN75F6400. When I select a channel below 100 (local channels) in the guide it sends the wrong channel number to the Directv dvr. For example, when I select channel 2 I see the tv entering channel 2958 and then the dvr shows that the channel doesn't exist, just as it would if I typed that channel on my directv remote. I double checked that my zip code and provider are set correctly. Anybody else seen this issue? Does anyone else have this working? I guess Samsung has some wrong info in it's database. I called Samsung and they ran me through the setup again and couldn't fix it. The rep is entering an issue in the database. Hopefully they will fix it soon.
trouptra is offline
