Focus Test Pattern - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-31-2011, 02:18 PM - Thread Starter
Jay5298's Avatar
Quoted: 18 Post(s)
I was just wondering does anyone know where I can find this test pattern. I know a signal generator will produce this, but can I find this on a calibration disc?
Jay5298 is offline
post #2 of 11 Old 11-01-2011, 12:50 PM - Thread Starter
Jay5298's Avatar
Quoted: 18 Post(s)
Oh well, it was worth a try.
Jay5298 is offline
post #3 of 11 Old 11-01-2011, 01:07 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Give it a chance man.. it's a forum, not Google!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #4 of 11 Old 11-01-2011, 01:16 PM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
Yes. Which disc format do you want?
GeorgeAB is offline
post #5 of 11 Old 11-02-2011, 09:16 AM - Thread Starter
Jay5298's Avatar
Quoted: 18 Post(s)
Blu-ray preferably, it just needs to be 1920 x 1080. I'm trying to get my focus dialed in and the grid pattern on my projector is really hard to look at for a long period of time.
Jay5298 is offline
post #6 of 11 Old 11-02-2011, 11:09 AM
rovingtravler's Avatar
Not the exact one but a great site. Also there are very good patterns on the AVS S&M, and DVE discs... have you tried those?
Also Calman has a good pattern generator on their download page.
http://www.walvisions.com/statics.html
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #7 of 11 Old 11-02-2011, 12:45 PM
Kris Deering's Avatar
Quoted: 1578 Post(s)
Liked: 2475
I use the AVS 709 disc for focus. In the misc patterns under resolution the second pattern (single pixel cross I think) works great for very fine focus.
My Home Theater
Kris Deering is offline
post #8 of 11 Old 11-02-2011, 01:57 PM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
I haven't seen that old pattern or an 'Indian Head' HD version of it in 1080p. There are similar patterns available from the following:
'Digital Video Essentials: HD Basics' Blu-ray Disc- see: "SMPTE RP-133 Resolution Chart" in the "Advanced Video Patterns" section (also available on 'DVE Professional' WMV HD).
'DisplayMate for Windows' PC Program- see: "Master Test Pattern" in the index.
As mentioned, there are alternate patterns specifically designed for focus and/or resolution tests in other HD test programs. They may be easier to your eyes.
GeorgeAB is offline
post #9 of 11 Old 11-02-2011, 02:03 PM - Thread Starter
Jay5298's Avatar
Quoted: 18 Post(s)
Thanks guys, I will give those a try.
Jay5298 is offline
post #10 of 11 Old 11-21-2011, 03:44 PM
sheeand's Avatar
I'm not sure how much resolution you need, but the indian head on myTvTestDisc might work for you. You can download it off their .com web site.
sheeand is offline
post #11 of 11 Old 11-22-2011, 12:19 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
If your player has a USB input and can view still images here is the NEC test patterns.
lots of stuff in here.
https://files.me.com/nashou.66/j9cf1p
Athanasios
nashou66 is offline
Reply Display Calibration
