Output Range And Samsung Black Level - AVS Forum | Home Theater Discussions And Reviews
Old 11-19-2011, 06:06 AM - Thread Starter
MSL_DK's Avatar
Quoted: 20 Post(s)
I am somewhat confused :-) I use my HTPC to play Blu-ray (MKV) and nothing else.
I've set my graphics to full RGB (ATI 4850) I use MPC-HC and have set the output range to 16-235
But what about my Samsung UE40D5005. Should HDMI Black Level be set to Normal or Low? Are Normal = RGB Full Range?
Is it best to set the graphics card to full rgb and MPC-HC to 16-235 when I do not use it for anything other than blu-ray?
Thanks in advance :-)
Panasonic TX-55CX700E - Dynaudio Focus 200 XD
MSL_DK is offline
Old 11-19-2011, 08:09 AM
PlasmaPZ80U's Avatar
Quoted: 1963 Post(s)
Liked: 559
HDMI Black Level should be Normal for RGB Full Range and Low for RGB Limited Range.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
Old 11-19-2011, 08:16 AM - Thread Starter
MSL_DK's Avatar
Quoted: 20 Post(s)
This means that I must set the Black Level to Normal, although I have set the Output Range to 16-235 in MPC-HC
This is somewhat confusing, at least for me :-)
MSL_DK is offline
Old 11-19-2011, 08:40 AM
Liked: 559
16-235 is RGB limited range and you should use HDMI Black Level Low in that case. This is the ideal range for video like Blu-ray Disc.
Old 11-20-2011, 11:10 AM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
There is only one 1 point of confusion here... years ago, Samsung started labeling the RGB levels backwards and they never stopped doing it even though their QA department has asked to have the labels reversed. So don't worry about it and just remember that Samsung did the labeling backwards.
limitz likes this.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
Old 11-22-2011, 03:47 AM - Thread Starter
MSL_DK's Avatar
Quoted: 20 Post(s)
Thanks for helping :-) one might well wish for a little more clarity from various manufacturers as well as from TV manufacturers and computer parts. But eh, now HTPC world of course also completely new.
MSL_DK is offline
Old 03-07-2013, 08:56 AM
limitz's Avatar
Quoted: 40 Post(s)
Do you know if this has been corrected?
Regards
-started thread of matter-
limitz is offline
