The "Cool" Movie Mode "Technical Manipulation" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-03-2011, 09:30 PM - Thread Starter
vincentfam's Avatar
Liked: 24
Greetings Calibration Colleagues,
I have tried the Warm1 and Warm2 color tones for the movie mode on my Samsung plasma. These tones were slightly too dark for my preferences. Also, standard mode didn't seem right and dynamic mode, a/k/a torch mode, was simply too bright.
Then I read in this forum that the movie mode can be brighten by simply changing the color tone to normal or cool.
I changed the tone to cool for my movie mode. If you are calibrating with a colorimeter, etc., RGB levels will be 90% for reds and 120% for blues, with green level at 100% as reference.
My settings, gamma graph, and rgb graph for my PN50B450 are as below:
movie mode
cell light 8
contrast 88
brightness 49
sharpness 20 [30 when blu ray adjusted to 1080i]
(per service manual, use 720p signal on a 720p pattern)
color 51
tint 51/49
Gamma 0
native color space
cuts Red 24 Green 25 Blue 41
Gain Red 34 Green 25 Blue 24
Screen Fit
All other enhancements off [edit note: make sure to maintain the same options when switching to cool tone. For example, changing to cool tone will change the black hdmi level to normal from low. You may have to change it back to low]
Target gamma is 2.4
The picture is slightly lighter and more pleasing.
As always,
Vincentfam
Attachment 229643
Attachment 229644
vincentfam is offline
post #2 of 8 Old 12-05-2011, 09:12 AM
Smackrabbit's Avatar
Quoted: 31 Post(s)
Liked: 92
While you might find the picture brighter and more pleasing, using the term calibration for this would be incorrect. With a calibration you are after a reference standard, so that you see what is on the source material as it was intended to be seen. If you want to adjust it to your liking, then you should do that as the point of all of this is personal enjoyment, it's just incorrect to refer to something done this way as calibrated, when the graphs indicate it's really far off target.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
post #3 of 8 Old 12-05-2011, 10:14 AM
GeorgeAB's Avatar
Quoted: 136 Post(s)
Liked: 240
Let's be clear. There is more than one "point of all of this." Please review the opening post in this "sticky" thread from above:
'Display Calibration: Root Fundamentals'
http://www.avsforum.com/avs-vb/showthread.php?t=1021933
In the context of the video industry standards and practices, it is the authentic art or message that is to be presented for enjoyment, not some distorted version of it.
Best regards and beautiful pictures,
G. Alan Brown, President
CinemaQuest, Inc.
A Lion AV Consultants affiliate
"Advancing the art and science of electronic imaging"
GeorgeAB is offline
post #4 of 8 Old 12-05-2011, 06:32 PM - Thread Starter
vincentfam's Avatar
Liked: 24
Dear Learned Colleagues,
I agree that I improperly use, and thus misused, the term calibration, of course after reviewing many online dictionaries. As a correction, I propose the following in lieu of the term calibration:
"I believe I have manipulated the picture quality initiated by the display manufacturer by use of an eye one display Lt colorimeter and hcfr software resulting in a picture that deviates from reference standards, which nonetheless provides a picture quality that is personally pleasing."
Perhaps I should have simply used the phrase "technical manipulation" rather than calibration, but "technical manipulation" is not a term of art used in this field either.
Thank you for your comments. They are appreciated.
As always,
Vincentfam
post #5 of 8 Old 12-05-2011, 08:34 PM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
A more appropriate way to put it would be this;
"I believe I have manipulated the picture quality initiated by the display manufacturer by use of an eye one display Lt colorimeter and hcfr software resulting in a grossly exaggerated picture that deviates from reference standards, which nonetheless provides a picture quality that is personally pleasing."
Kilgore is offline
post #6 of 8 Old 12-05-2011, 09:01 PM - Thread Starter
vincentfam's Avatar
Liked: 24
touche, mon ami!
At the least, did my gamma graph look decent?
post #7 of 8 Old 12-05-2011, 09:01 PM
Quoted: 31 Post(s)
Liked: 92
The proper way to me would be "I adjusted the settings how I like it, and here are graphs showing a massive blue push and a dE that is off the charts." It should also go in the owners thread for the TV model and not in the Calibration forum.
Chris Heinonen
post #8 of 8 Old 12-06-2011, 08:56 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 565
Yes, that's where this post/thread belongs. Calibration is about getting as close to a reference standard as possible. This thread is about setting the white balance to a personal preference while still using a meter and calibration software.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Reply Display Calibration
