Calibrate for 3D content - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-09-2011, 02:03 PM - Thread Starter
Pitou's Avatar
Hello,
How can we calibrate a display for 3D? Does putting the glasses in front of the probe, the right way to do that?
Thank you.
Pitou!
Pitou is offline
post #2 of 13 Old 12-09-2011, 02:16 PM
turbe's Avatar
Liked: 95
Yes, the glasses need to be in front of the Meter..
Which Meter are you using? Up to around $1000, the X-Rite I1 Pro is really the only meter that can do this right...
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #3 of 13 Old 12-09-2011, 02:18 PM - Thread Starter
Pitou's Avatar
I own the i1pro + Chromapure. I usually do an offset with a D2, but I guess I'll have to use the i1pro only?
Now I'm wondering how I can hold the glasses while doing the calibration!
Pitou is offline
post #4 of 13 Old 12-09-2011, 02:57 PM
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1521
Check that Article posted by SpectraCAL.
http://www.spectracal.com/downloads/...n%20Basics.pdf
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #5 of 13 Old 12-09-2011, 03:40 PM - Thread Starter
Pitou's Avatar
ConnecTEDDD,
Thanks very much for the link.
They seem to suggest to have the glasses running. In my case, I need a 3d source playing for the glasses to activate.
Do you know if a VP like the Radiance mini3D displays the patterns in 3D mode? Or can I just place the glasses turned off in front of the i1pro?
Pitou!
Pitou is offline
post #6 of 13 Old 12-09-2011, 03:42 PM
Liked: 1521
Make the conversion using your TV or your Blu-Ray Player from 2D -> 3D.
(If any of them have that 2D->3D conversion feature of cource)
post #7 of 13 Old 12-09-2011, 03:50 PM - Thread Starter
Pitou's Avatar
hmm unfortunately no. I own a Oppo BDP93 and a JVC HD250 PJ. I have the 3D VIP Theater for 3D and thinking of buying the Radiance mini 3D.
Pitou is offline
post #8 of 13 Old 02-12-2012, 03:44 PM
3dmaven's Avatar
I have a question about calibration. I tried a different method the other night; I took my reference Colormunki Spectro and placed the 3d glasses in front of it, but not in front of my I1Display3 when I profiled it. I then went on to calibrate the display with the I1Display3 (again, without putting the glasses in front of it). I know the logic behind this setup makes some sense, and in some ways the picture looked good, but it did feel a bit off (I didn't have time to though up a grayscale ramp yet). Any ideas if this method has any merit? If not, does anyone know why it wouldn't work properly?
3dmaven is offline
post #9 of 13 Old 02-12-2012, 06:33 PM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
How did it turn out?
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #10 of 13 Old 02-13-2012, 07:00 AM - Thread Starter
Pitou's Avatar
@3dmaven,
I'm not sure I'm following here. If you profile your d3 without the glasses in front of it against the munki with the glasses, the values offset will be very high. How can this setup work?
Please enlighten me!
Pitou!
Pitou is offline
post #11 of 13 Old 02-14-2012, 09:36 AM
Kazuya (FR)'s Avatar
Nobody made 3D patterns ?
It should not be too complicated for someone familiar with 3D videos...
In mkv for example, it whould works with Oppos, HTPC, Dune...
Now on AVS, discover a plug and play setup for HTPC, with amazing video quality: the Config Kaz 7 !
Kazuya (FR) is offline
post #12 of 13 Old 02-14-2012, 11:04 PM
3dmaven's Avatar
Originally Posted by Pitou View Post
@3dmaven,
The offset values were indeed very high. All in all the picture looked decent, though I felt the the colors were way undersaturated, and I couldn't get great delta e results. I haven't had time to throw in any other disks to test it (in comparison to what I had seen before on this system and elsewhere). I may het the time to do some comps tomorrow.
3dmaven is offline
post #13 of 13 Old 02-18-2012, 04:49 PM
3dmaven's Avatar
I had some time to view the calibration results more critically, and they were really not good. For whatever reason (maybe the very high offsets), it does not seem to work. The gamma curve was clearly off and there was some weird color banding.
3dmaven is offline
Reply Display Calibration
