i1 Display Pro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-01-2012, 05:57 PM - Thread Starter
noizemaker's Avatar
Hey guys - Happy New Year!!!
Got a quick question...I'm interested in picking up the i1 Display Pro but is it capable of calibrating a plasma display?
Thanks so much guys!!!
Carmine.
noizemaker is offline
post #2 of 9 Old 01-01-2012, 06:20 PM
turbe's Avatar
Liked: 95
yes
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #3 of 9 Old 01-01-2012, 08:08 PM - Thread Starter
noizemaker's Avatar
Cool....thanks turbe for the quick reply!!!!
post #4 of 9 Old 01-01-2012, 08:40 PM
turbe's Avatar
Liked: 95
I should have added, the X-Rite software that is included with the retail version of that meter isn't for calibrating your Plasma in a Home Theater environment. Out of the current mainstream enthusiast calibration software offerings, only CalMAN supports the retail version of that meter. There is also an OEM version of that meter which is supported by CalMAN and ChromaPure.
ControlCAL™
turbe is offline
post #5 of 9 Old 01-02-2012, 12:10 AM
AV-Freak's Avatar
I think every 3rd party software except Chromapure supports the retail version.
Or do you know another 3rd party software that does not support the retail version?
AV-Freak is offline
post #6 of 9 Old 01-02-2012, 03:28 AM
PE06MCG's Avatar
Liked: 51
Or put another way, if you don't want to be tied to just CalMAN and would like the choice of CalMAN and Chromapure somewhere along the line you should choose OEM version.
I have both and see they are both developing softwares so I like to have the choice as they continue their interesting progress.
PE06MCG is offline
post #7 of 9 Old 01-02-2012, 09:45 AM - Thread Starter
noizemaker's Avatar
I was thinking of going with Calman as I've used one of the first versions of it years ago with very good results....I will most likely purchase the meter/software package from the Spectracal website....
Thanks again guys!!!!
Carmine...
post #8 of 9 Old 01-02-2012, 11:26 AM
richlo's Avatar
Carmine...
If you had their version back in the Excel time, you may want to contact them, you may need not to purchase anymore and simply get the 4.xx verision free..I think so at least.
Rich L
Go Chicago Bears
richlo is offline
post #9 of 9 Old 01-02-2012, 08:04 PM - Thread Starter
noizemaker's Avatar
That's exactly what I had Richlo....I will indeed contact them before purchasing!!!!
Thank you so much for the heads up!!!!
Carmine.
Reply Display Calibration
