Eye-One Display2 or LT - AVS Forum | Home Theater Discussions And Reviews
Old 01-18-2012, 06:41 AM - Thread Starter
EmilG's Avatar
I plan on using it to calibrate my TV only, no computer monitors.
If I use HCFR is there any difference between the Display2 and LT?
I understand that the included software is different but I don't plan on using it.
EmilG is offline
Old 01-18-2012, 07:04 AM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
For HCFR there is no difference.
Brian Hampton is offline
Old 01-18-2012, 08:04 AM - Thread Starter
EmilG's Avatar
I just wanted verification.
Thank You!
EmilG is offline
Old 01-18-2012, 07:33 PM
richlo's Avatar
get the cheaper one..LT I think..same pod different software
Rich L
Go Chicago Bears
richlo is offline
Old 01-19-2012, 05:12 AM - Thread Starter
EmilG's Avatar
The LT should be arriving on Friday, then the fun will begin !
I looked over HCFR and it sure seems like it's got everything that anyone would need for a good calibration.
EmilG is offline
Old 01-19-2012, 06:57 AM
Quoted: 572 Post(s)
Liked: 302
Safe to assume you've read this guide several times...
http://www.curtpalme.com/forum/viewtopic.php?t=10457
-Brian
Old 01-19-2012, 06:59 AM - Thread Starter
EmilG's Avatar
-Brian
Only once... so far .
EmilG is offline
Old 01-19-2012, 11:32 AM
Quoted: 572 Post(s)
Liked: 302
Once is fine for some people.
I need to read it several times or maybe I just like reading it over again.
Kal says he based the guide on this thread...
http://www.avsforum.com/avs-vb/showthread.php?t=852536
Which also makes great reading.
-Brian
Old 01-19-2012, 11:49 AM - Thread Starter
EmilG's Avatar
-Brian
Thanks, another bookmark for me!
EmilG is offline
Old 01-25-2012, 12:27 PM
derekjsmith's Avatar
Liked: 116
Last of the X-Rite Display2's http://www2.spectracal.com/shared/we...e58448d3c7d90b
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
Old 01-27-2012, 10:12 AM
mjodotcom's Avatar
Quoted: 14 Post(s)
Is this a good combo package to get started with home TV calibration or are the newer meters significantly better?
mjodotcom is offline
Old 01-31-2012, 04:16 PM
chambery's Avatar
Using an i1Display LT, trying to calibrate my Samsung PN64D550 plasma.
Started with the 2 Pt WB before I consider hacking the service menu to access the 10 Pt WB controls and advanced CMS.
Using a Panasonic Blu-Ray player, the HD AVS709 disc, the meter and the CHCFR software, I get terrible grey scale readings using the 2 Pt white balance settings. I need to turn Red gain and offset to 50, the highest settings, and Blue gain and offset to 39 and 30 to get the best possible measured red results in greyscale. Blue and Green are right at 100%. but Red is no better than 90% on any greyscale % step. I left Green gain and offset untouched at 25 per the "Dummy" instructions. Then I tried lowering the Greens and that brought the Reds into line, but I lost Brightness levels. So I reset the Greens to 25.
With these extreme red settings, watching content the PQ is too red with skin tones and solid blacks showing a definite red tinge. I tried lowering contrast which did raise Red readings per the instructions but at the expense of the overall PQ, so I returned to the original contrast setting.
Based on the results, I must 1) have a bad meter (brought new and factory sealed but the "no longer manufactured" date is May 2011 and these meters are said to need periodic re-calibration usually annually) or 2) I'm using the meter wrong. The meter does adheres to the screen on its own, because when hanging it with the weight, it flushes to the screen and creates a suction without any pressure applied. This may have an adverse effect but the instructions indicated to let the meter adhere. I calibrated the meter per the instructions at the beginning of the session. I have the display type set to Plasma vs. LCD. I believe I am following the instructions properly, although I have not advanced beyond Part 7: How does your greyscale look now?
I am doubtful that going to the 10 Pt will overcome this problem if the 2 Pt is so far out of whack.
As noted before, the PQ looks excellent (although I think a tad too cool) just using the HD AVS 709 disc to calibrate with the user menu controls and leaving all white balance settings at the default of 25.
Settings are Warm2, everything off, etc., all the suggested base settings, prior to calibration with the meter and software.
Can anyone offer any observations based on your experience with the meter, software, setup and instructions? It seems most were able to make everything work to your satisfaction.
Thanks for any help you can offer.
chambery is offline
Old 02-01-2012, 02:00 PM
bruce's Avatar
I don't think it's out of line to make large adjustments to the grayscale to get it to behave. I would carry on and finish all the color setups, rather than stopping as you said you did. Forget about the 10 pt if the color temp graph looks OK and do all the color setup and see if the red problem goes away.
I recently used the same test equipment as you and did both my LED displays. One was fairly well behaved, but the other had extreme blue in the gray scale setup that required turning down the adjustment it's full swing.
bruce
bruce is offline
