Newbie Calibration Device - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 41 Old 02-16-2012, 02:11 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
Originally Posted by bob ross View Post
Wait... it's this right?
http://store.spectracal.com/consumer...i1display.html
But is this a better deal? Just different software? ($419)
X-Rite EyeOne Display 3 (i1 Display Pro) with ChromaPure Standard
http://www.curtpalme.com/ChromaPure_EyeOneDisplay3.shtm
Same hardware different software.
Unless I do my math wrong $395 is less than $419, making CalMAN less expensive.
Also I'm partial to believing CalMAN is the better software, but that's just me.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #32 of 41 Old 02-16-2012, 02:47 PM
bob ross's Avatar
Ah I see. Well as of now, the only one available is retail package (as the website advises I get) @ $439.00 I was told there would be no math....
bob ross is offline
post #33 of 41 Old 02-16-2012, 05:01 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
Oh I see we are out of stock on the OEM model. You might want to make a phone call sometimes a little prodding can get you a deal.
Also for that price you get not only CalMAN but also the X-Rite PC calibration software.
Sorry about the math.
Joel Barsotti
SpectraCal
sotti is offline
post #34 of 41 Old 02-16-2012, 06:32 PM
Tempest261's Avatar
Liked: 26
Buy.com has the i1Display Pro (retail) for ~$200 right now. I went with that. If the software isn't enough, I'll get Calman as well, coming in around $400 total.
Calibration Equipment:
Meters: X-rite i1 Pro 2, X-rite i1 Display Pro
Software: Spectracal Calman DIY, ControlCAL
Televisions:
Panasonic TC-P65VT50 (currently own)
Samsung UN55D8000 (returned) Calibration and Settings Thread
Plasma IR Removal:
Post 1 - Post 2 - Post 3
Tempest261 is offline
post #35 of 41 Old 02-22-2012, 12:43 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
for those that are really on a budget, isn't the I1 Display LT and free HCFR the best option?
how much better is the CalMan/Display 2 bundle compared to the Display LT and HCFR?
smokarz is offline
post #36 of 41 Old 02-22-2012, 01:14 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
Accuracy wise we have new stock of i1D2s but a lot of companies have new old stock and the meters will drift while sitting in their packaging.
The next question becomes how much is good software worth to you.
If that's all you can afford, I'd say go for it though. Once you start calibrating, you'll see how better tools can benefit you.
Joel Barsotti
SpectraCal
sotti is offline
post #37 of 41 Old 02-23-2012, 06:04 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
thanks,
quite frankly i am on a limited budget. if i have $1k to spend on calibration tools, i certainly won't be looking at these combos.
with that said. the I1 Display LT and HCFR combo is about $150.
the Calman/I1 Display 2 is about $200?
Is there a $50 difference in terms of accuracy? for the budget minded folks, if performance is the same, why spend more?
If there's noticeable difference with the Clamn/I1 D2 combo and it's definitely justiable to spend the extra $50.
just asking.
thanks
smokarz is offline
post #38 of 41 Old 02-23-2012, 08:08 AM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
thanks,
just asking.
thanks
From what I found CalMAN is a much more robust SW package than HCFR (which I practically dead now from a development perspective). Plus, it does not support any of the newer meters. I think it would be wise to go with the combo package from Spectracal - as it gives you a much more user friendly experience as well as flexibility to upgrade to better meters down the road.
mjodotcom is offline
post #39 of 41 Old 02-23-2012, 08:40 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
For $50 I would think the value of the software would be a no brainer.
Joel Barsotti
SpectraCal
sotti is offline
post #40 of 41 Old 02-23-2012, 09:38 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
thanks sotti.
is there a 'tutorial for dummies' on the CalMan software?
much like the dummies on HCFR?
smokarz is offline
post #41 of 41 Old 02-23-2012, 11:19 AM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
thanks sotti.
CalMAN has a nice step by step PDF guide to follow
Reply Display Calibration
