Newbie Calibration Device - AVS Forum | Home Theater Discussions And Reviews
Old 01-27-2012, 10:07 AM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
I am looking to get into trying doing my own TV calibration and am wondering which hardware people here recommend in the sub 300$ price point (something that is more advanced than just beginner stuff). Thanks!
mjodotcom is offline
Old 01-27-2012, 10:53 AM
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
the D3 colorimeter is the best device at that price point. If you can spend a bit more ($400-$500), the colormunki spectro is a better choice.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Old 01-27-2012, 02:34 PM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
You might mention the D3 doesn't work with any free software and another $200 will be needed for calibration software.
Brian Hampton is offline
Old 01-27-2012, 03:53 PM
Liked: 560
good point, but the OP was asking about hardware specifically
Old 01-27-2012, 04:38 PM
derekjsmith's Avatar
Liked: 116
A complete calibration package for $200: http://www2.spectracal.com/shared/we...e58448d3c7d90b
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
Old 01-27-2012, 05:39 PM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
Thanks - I would want to spend about 300 all in if possible. Looking for the best "bang for the buck"
Old 01-27-2012, 06:18 PM
Liked: 560
In that case, the offer in the link above for the CalMAN/D2 bundle is a better choice than using ColorHCFR.
Old 01-27-2012, 07:11 PM
richlo's Avatar
bingo..that is a great deal..
Rich L
Go Chicago Bears
richlo is offline
Old 01-27-2012, 07:22 PM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
Thanks for your responses guys. So you feel the D2 with Calman is better than a "newer" meter with the free software?
Old 01-27-2012, 07:40 PM
LESS's Avatar
Would that work for a projector as well?
LESS is offline
Old 01-27-2012, 08:36 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Th issue there is that there are no newer meters + free software.
The DTP-94 and i1 Display 2 are both out of production, as is the spyder 2. I think only the Spyder3 and i1 Pro are in production and work with HCFR, and the i1 Pro is signifigantly out of your budget,
I would guess the Spyder3 is not long for this world with the recently released Spyder 4.
With HCFR being a dead project it doesn't support any modern hardware.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 01-27-2012, 09:22 PM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
Got it - so this deal would be good for what I am looking for? The D2 is a good meter?
Old 01-28-2012, 12:50 AM
Liked: 116
Well you have to start with something. So a D2 is a good start. Getting CalMAN with a D2 to learn and understand the calibration basic is even a better start. There will always be a better meter on the horizon. But the nice thing about CalMAN is we support many meter types with the DIY license and keep adding more as they come out. So after sometime when you need a more advanced meter dump the D2 and get the latest one you can afford. This is why we put this package together is to get people into calibrating and not on the sidelines.
Derek
Old 01-28-2012, 06:11 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Look at it this way, Calman with DIY license and no meter is $199. This is a nice deal to get your feet wet and by next Christmas if you get into it, you will have something cool to put on your list.. without having to buy software to.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 01-28-2012, 01:49 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
I ordered this to get my feet wet...and it comes with two free webinars too if you order in January. Not on weekends, but can't have everything...
lovinthehd is offline
Old 01-29-2012, 09:56 AM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
So is the 400$ bundle a much better meter than in the 200$ one, or are they pretty close?
Old 01-29-2012, 10:17 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
I would say the i1 Display3 is a Much better meter.
I Believe msrp on the i1 Display 3 is $299, but you can find them for less if you wanted to start with the i1 Display 2 and them upgrade to the 3 later.
Joel Barsotti
SpectraCal
sotti is offline
Old 01-29-2012, 02:54 PM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
Is the D3 the one that comes with the $395 bundle?
Old 01-29-2012, 03:35 PM
Liked: 116
Yes it is the D3 OEM.
Derek
Old 01-29-2012, 03:56 PM
Otto Pylot's Avatar
Quoted: 1361 Post(s)
Liked: 853
How accurate is that meter, or any consumer-grade meters for that matter, and what are they calibrated against? How long do they typically keep their calibrations (reference settings) before they start to drift? Are the meters re-certifiable for a reasonable cost?
Otto Pylot is offline
Old 01-29-2012, 05:55 PM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
And that is a much higher caliber than the D2 or is the improvement marginal?
Old 01-29-2012, 09:57 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
I would say it's a bit of a leap performance wise. It reads much darker, is more accurate and should hold it's calibration much longer than a D2.
Joel Barsotti
SpectraCal
sotti is offline
Old 01-31-2012, 08:01 PM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
Decided to go with the D3 CalMAN bundle - seems universally liked. Im excited!
Next question, what DVD do people recommend using to do the calibration? I heard the HD Basics one doesn't have color patterns, is there one that has everything I need?
Old 01-31-2012, 08:57 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
The AVS disc has everything you need to calibrate and it's free, but it doesn't have much in the way of instruction.
The DVE or spears munsil are great in the amount of information they give you to help get the adjustments correct and why you are making the adjustments in the first place.
Joel Barsotti
SpectraCal
sotti is offline
Old 01-31-2012, 09:11 PM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
I thought the spears munsil disk does not have all of the display patterns needed for calibration?
I would do the AVS disk, but I don't have a bluray burner
Old 01-31-2012, 10:01 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
You don't need a bluray burner, you can burn it on DVD and it should work just fine.
Some players have issues with that, but most work just fine.
Joel Barsotti
SpectraCal
sotti is offline
Old 01-31-2012, 10:48 PM - Thread Starter
mjodotcom's Avatar
Quoted: 14 Post(s)
Ah nice - thanks!
Old 02-16-2012, 09:02 AM
Tempest261's Avatar
Liked: 26
Hey Guys,
After reading this thread, I'm looking at the "CalMAN DIY Software w/ OEM i1Display" package for $395. However, they're out of stock. Next one up is the "CalMAN DIY w/ i1Display Pro Retail" for $439. Is there anything meaningful for the ~$45 price hike, other than getting the i1Display3 in a retail box?
Calibration Equipment:
Meters: X-rite i1 Pro 2, X-rite i1 Display Pro
Software: Spectracal Calman DIY, ControlCAL
Televisions:
Panasonic TC-P65VT50 (currently own)
Samsung UN55D8000 (returned) Calibration and Settings Thread
Plasma IR Removal:
Post 1 - Post 2 - Post 3
Tempest261 is offline
Old 02-16-2012, 12:22 PM
Smackrabbit's Avatar
Quoted: 30 Post(s)
Liked: 90
Originally Posted by Tempest261 View Post
Hey Guys,
You can then use the i1Profiler software to calibrate your PC/Mac displays as well with the retail meter. Their software doesn't support the OEM meter so if you would like to do both, it's worth the extra money IMO.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
Old 02-16-2012, 02:38 PM
bob ross's Avatar
Hi,
Where are people seeing this D3 CalMAN bundle? Link please?
Wait... it's this right?
http://store.spectracal.com/consumer...i1display.html
But is this a better deal? Just different software? ($419)
X-Rite EyeOne Display 3 (i1 Display Pro) with ChromaPure Standard
http://www.curtpalme.com/ChromaPure_EyeOneDisplay3.shtm
bob ross is offline
