Can't adjust tint and color. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-07-2012, 12:25 PM - Thread Starter
bassage's Avatar
Quoted: 134 Post(s)
Liked: 29
I am using the free calibration disc that I got from this site, and I'm trying to adjust the color and tint with a blue filter on my LCD tv. No matter what tint and color settings I use I cannot get the flashing color and tint squares to match the bars around them. Is my tv just not able to do this? Or maybe my blue filter is not the correct blue? I don't know what I'm doing wrong.
bassage is offline
post #2 of 7 Old 02-07-2012, 12:34 PM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
Not "around". You match within the same bar. From the manual:
The gray bar at the left has a flashing blue box and the blue bar has a
flashing gray box. Look through a blue filter at these two bars. As you
raise and lower the color control you will see the gray and blue change
relative to each other. You want to set the color control so gray and
blue match. Ideally when this happens you would see almost no
flashing on the center of the boxes while looking through the blue
color filter. Realistically you might always be able to see a little bit of
flashing, and if that's the case then just set the color control so that
gray and blue come as close as possible to matching.
The magenta and cyan bars also have flashing boxes with the other
color. Looking through the blue filter, you use these two bars to adjust
the tint or hue control. The idea is similar to setting the color control.
Ideally you would not want to see any flashing when looking through
the blue filter, but just use the tint control to minimize the flashing so
the center of the box appears close to the same shade.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #3 of 7 Old 02-07-2012, 12:48 PM - Thread Starter
bassage's Avatar
Quoted: 134 Post(s)
Liked: 29
Yes, within the same bar. That's exactly what I meant when I said "around". The flashing box is supposed to disappear inside the bar, is that correct?
bassage is offline
post #4 of 7 Old 02-07-2012, 01:03 PM
buzzard767's Avatar
Liked: 2439
Yes. Blue and gray should look the same (color) and cyan and magenta should look the same (tint).
Buzz
post #5 of 7 Old 02-07-2012, 01:17 PM - Thread Starter
bassage's Avatar
Quoted: 134 Post(s)
Liked: 29
Ok, now I need to figure out why I can't make them disappear on my tv.
bassage is offline
post #6 of 7 Old 02-07-2012, 02:04 PM
Smackrabbit's Avatar
Quoted: 120 Post(s)
Liked: 296
Some questions that might be helpful:
- What TV are you using?
- What picture mode are you using on the TV?
- Which Blu-ray player are you using?
- Are you using one of the picture modes on the Blu-ray player?
- How are the devices connected? Is there anything between the Blu-ray player and the TV?
It could be the picture mode you are using has color jacked around so much you can't fix it, or that the Blu-ray player is in a picture mode that does the same, or a combination or the two, just for starters. Answering those questions will help determine if other people have had issues with the same equipment and how they got around it.
Chris Heinonen
Staff Writer, The Wirecutter, a NY Times Company
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Secrets of Home Theater and High Fidelity, AnandTech.com, HDGuru.com and Electronic House
Smackrabbit is offline
post #7 of 7 Old 02-07-2012, 03:44 PM - Thread Starter
bassage's Avatar
Quoted: 134 Post(s)
Liked: 29
It's a Samsung LCD, lnt model, from about 3 or 4 years ago. I'v tried all picture modes. Using a PS3 with HDMI directly to the tv.
bassage is offline
Reply Display Calibration
