THX filter glasses or DVE glasses? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-09-2012, 08:15 AM - Thread Starter
sefmiller's Avatar
I have read on here that the DVE blue filter glasses are not accurate. Should I buy the thx glasses, digital video essentials, or use both?
sefmiller is offline
post #2 of 8 Old 02-09-2012, 08:49 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
All the blue filters are not accurate. They were designed for CRT phosphors.
The purpose of the filter is to get you into the ballpark of where correct should be. YOu use your eyes as the final determiner after that.
regards
John4721 likes this.
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 8 Old 02-09-2012, 09:20 AM
realzven's Avatar
Liked: 84
+1 with Michael, your eye is the final judge.
another option : some display have a "blue mode only" more "accurate" than blue filter
realzven is offline
post #4 of 8 Old 05-18-2012, 04:23 PM - Thread Starter
sefmiller's Avatar
So, do I need to spend the money on blue filter glasses. Or should I do it by eyeball?
post #5 of 8 Old 05-18-2012, 04:30 PM
PlasmaPZ80U's Avatar
Quoted: 1966 Post(s)
Liked: 560
if you have a meter, just use that
color isolation modes in the TV are the next best option
color filters are the least reliable option
none of the options are 100% foolproof, though, so you need to verify skintones and other natural colors/objects with reference material
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #6 of 8 Old 06-02-2012, 05:52 AM
ZandarKoad's Avatar
Originally Posted by Michael TLV View Post
Greetings
The purpose of the filter is to get you into the ballpark of where correct should be. You use your eyes as the final determiner after that.
regards
The Spears and Munsil disc came with a one eye filter that had three options - 1x, 2x, and 3x for their blue filter. I've never heard doubling or tripling the blue filters mentioned on these forums. What effect does that have as to accuracy?
ZandarKoad is offline
post #7 of 8 Old 06-02-2012, 06:13 AM
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1521
Different displays need different levels of filtering to do a proper calibration, so the filter allows for 1, 2, or 3X filtering.
Using the Spears & Munsil Calibration Filter
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #8 of 8 Old 06-02-2012, 06:44 PM
ZandarKoad's Avatar
How useful are the green and red primary filters? Will they let you take it a step further?
Reply Display Calibration
