Is it best to calibrate at 75% - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 33 Old 02-15-2012, 05:32 AM - Thread Starter
EmilG's Avatar
Thanks guys, you are all awesome.
So in summary (for me )
Besides the standard 100% calibration technique you can calibrate at:
75% saturation, 100% luminance
100% saturation, 75% luminance
and of course any lesser values/combinations if beneficial and available.
So in a perfect world calibrating at any of these "other" settings would always give results that would match.
However since nothing is perfect if you are going to compromise, compromise the lesser used conditions like 100% luminance and 100% saturation and keep the 75%, most used settings, most accurate.
I'm going to first verify my best settings at 75% saturation then at 75% luminance and see how good(linear) the decoding is.
Thanks again!
EmilG is offline
post #32 of 33 Old 02-15-2012, 09:32 AM
Pannus's Avatar
Quoted: 16 Post(s)
Hello. I just goth the Lumagen mini using it with calman. The default is 75% stimulus. Does anyone know the default saturation here, and does calman automatically set it so the correct luminance and saturation are chosen?
Pannus is offline
post #33 of 33 Old 02-15-2012, 01:41 PM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
If the pattern doesn't specifically specify a saturation level, I'd bet it's 100%.
Bluescale is offline
Reply Display Calibration
