HCFR - Open source projector and display calibration software - Page 121 - AVS Forum | Home Theater Discussions And Reviews
 920Likes
post #3601 of 8914 Old 05-28-2014, 05:35 AM
TimHamburg's Avatar
Originally Posted by Holiday121 View Post
The apply button is greeted out. So I unchecked it and hit apply restartrd it rechecked 0-255 and hit apply and restated again.
In my nvidia control panel yes I have it set to rgb full 0-255 but from what I'm reading when using hdmi it resorts back to 16-235. Have you personally used nvidia drivers?
Right now I'm at a stand still again because my windows 7 desktop once again ain't seing my i1 display pro. I uninstalled it plugged it back in and when it is searching for drivers it says i1 display pro but at the end it ends up being a USB device.
No reason why. Is there a specific way to set the driver? Is there a specific driver to use?
From past posts windows 7 is supposed to auto recognize it and it's not happening.
Also is there a way to know for sure when I successfully set 0-255?
Using wpc with madvr I have the 0-255 box checked as well. When I display the clipping patter no matter what I do I can't get the boxes to flash below 16
Yes - I'm using Nvidia drivers - now with a 660 GTX before that with a 430 GT and also 460 GTX.
Did you run Levels Checker as Administrator? It's imperative.
TimHamburg is offline
post #3602 of 8914 Old 05-28-2014, 05:37 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
I'm not sure if I did or not.
But once I hit apply is another box supposed come up or something? Or does that like bypass setting so it outputs 0-255 automatically?
Holiday121 is offline
post #3603 of 8914 Old 05-28-2014, 05:46 AM
gwgill's Avatar
Quoted: 249 Post(s)
Liked: 186
It comes up as usual anytime you plug a new device in and it starts searching for drivers. I click it to open to see what it's searching for and it's showing i1 display pro. But when it's done it's only shown as a USB device. I click it in the device manager and it says no driver
When you say "it", it sounds like you mean the notification bubble. (It would be better if you were clearer on what you are referring to.)
Instead, open the device manager, and (if it has one) the HID sub-section, and then plug the instrument in. If it is being recognized you should see the entry appear in the device manager, either creating the HID sub-section, or adding one or two entries to it, and therefore know where it is.
gwgill is offline
post #3604 of 8914 Old 05-28-2014, 05:52 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
It is creating a entry in the HID. But in that entry it creates it has nothjng about a i1 display pro.
post #3605 of 8914 Old 05-28-2014, 05:55 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
The pop up bubble comes up and when I click it this is what it's doing.
post #3606 of 8914 Old 05-28-2014, 06:00 AM
gwgill's Avatar
Quoted: 249 Post(s)
Liked: 186
So what's the Details -> device instance ID value of the device that appeared ?
gwgill is offline
post #3607 of 8914 Old 05-28-2014, 06:03 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Hey zoyd I have it installed and when I run it , it says
That's how I had it set. Is there anything else to do after that?
Looks correct and assuming you are running it as admin that will set your card up in the best configuration.
Am I understanding this right? The way to tell if I'm getting. 0-255 open up a black clipping test in wpc and I should be able to see 0-16 flashing if I turn the brightness way up? If so something not right because it's just grey in those areas when I turn up the brightness
No, 0-255 means black is at 0, so if HCFR is set to 0-255 and your display expects 0-255 you should see a gradual progression from black to dark grey between 0-16 if your brightness is set correctly. If instead you set HCFR to 16-235 and your display expects 16-235 you will see black at level 16 and below if brightness is set properly.
Originally Posted by TimHamburg View Post
Thanks for your answer - and you are probably right! Just old habits from my Calman times...
Another thing I wasn't encountering with my last calibration a few months back is:
 I'm using MadVr as signal generator . When I measure the 21-point greyscale, Madvr always displays some dark grey (20%?) window for like a 1 second
before it's actually starting the measurements at 0%. Can I change that? I'm not really that patient .... with computers anyway.....
I believe the delay is required to make the initial connection to madVR. You could ask madshi to change that behavior if possible but I don't think he would be supportive of your lack of patience. wink.gif
zoyd is offline
post #3608 of 8914 Old 05-28-2014, 06:05 AM
TimHamburg's Avatar
Right-click the "madLevelsTweaker.exe" in your madvr folder.
Select "Run as Administrator" (or whatever it's called in your system language - mine's german).
Then a window should ask you , if you allow madlevelstweaker to make changes.
Press ok.
Now you run it in Admin mode.
Another tip: Change your JVC to a display mode that you haven't changed (Brightness and Contrast are at 0).
Project a 0% black field on your screen (download for example the AVS calibration disc from here:
http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration
Take for example the mp4 version and in the "Basic settings" folder play "1-black clipping".
If everything is OK with your graphics card's video levels (0-255) the field 16 is the darkest field (=0% black).
Everything below that (15,14 etc.) should be the same black and should look like dark black not greyish (your JVC
can and should produce an inky black there.
And everything higher (17, 18 etc.) should become lighter.
I don't know if you did this, but this is one of the first steps when calibrating.
post #3609 of 8914 Old 05-28-2014, 06:21 AM
TimHamburg's Avatar
So this is "normal" behaviour, not just in my setup?
I'm sure it wasn't like that in earlier versions.
And if you are taking a lot of single readings with a normally very quick sensor like
the I1 Display 3 it makes everything sooooo slooooow...
So you think it depends on madvr?
I just want a quick and peeerfect calibration.....:D
post #3610 of 8914 Old 05-28-2014, 06:36 AM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
How can I tell if my video card is compressing it? That's where I'm getting confused. How do I know it's really passing through?
you may want to consider using a Blu-Ray player or DVD player to calibrate with, and deal with the PC configuration once you have a known baseline to work with.
vega509 is offline
post #3611 of 8914 Old 05-28-2014, 08:49 AM
Stereodude's Avatar
Quoted: 3170 Post(s)
Liked: 2318
What video format are you sending to the display? If you're sending RGB it should be fine, but if it's sending YCrCb I think it will send 16-235 even when you have everything set to 0-255.
Stereodude is offline
post #3612 of 8914 Old 05-28-2014, 04:57 PM
HDTVChallenged's Avatar
Liked: 215
and Holiday,
If you read through the comments/user reviews at "amazon," you'll find that more than a few folks have had this problem even with x-rite's i1Profiler software. From the all chatter, there appears to be a systemic issue. Sadly, I don't know what the answer is, but Holiday is not alone here.
HDTVChallenged is offline
post #3613 of 8914 Old 05-29-2014, 12:07 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
This is what shows up. As you can see I only have 1 USB input device to the left. That's what comes up when I plug the meter in.
post #3614 of 8914 Old 05-29-2014, 12:13 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
It must not be accepting it then for some reason. No matter what I do 0-16 don't change
post #3615 of 8914 Old 05-29-2014, 12:14 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
Yes I ran in admin unchecked restarted then ran in admin and checked box so this step should be just fine now
post #3616 of 8914 Old 05-29-2014, 12:14 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
I'm using the black clipping pattern off the avs disk
post #3617 of 8914 Old 05-29-2014, 12:15 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
Originally Posted by HDTVChallenged View Post
and Holiday,
Ya it's still driving me nuts. I don't get it
post #3618 of 8914 Old 05-29-2014, 12:19 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
Press ok.
I think something is setup wrong or I'm missing something. To many problems right now making everything go nuts
post #3619 of 8914 Old 05-29-2014, 12:20 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
That's what I did at first. I used the Disney wow disk and that's how I came up with -8 brightness and +17 contrast in user mode 1.
That's the point where the stars were perfect in advanced mode
post #3620 of 8914 Old 05-29-2014, 01:09 AM
gwgill's Avatar
Quoted: 249 Post(s)
Liked: 186
I really can't help you if you continue to ignore me.
I asked what the device instance ID value is, and you've failed to select it, showing the Device Description instead.
gwgill is offline
post #3621 of 8914 Old 05-29-2014, 01:18 AM
karrih's Avatar
This is not the way to do it, you need to choose 0-255 or 16-235 everywhere, you can not mix them. DVD/BD players are sending 16-235 so you need to select that in projector too.
karrih is offline
post #3622 of 8914 Old 05-29-2014, 01:20 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
That would explain why the settings are so far off then...
I just keep getting hit with problem after problem.. I tried emailing Xrite about the installation of course no response
post #3623 of 8914 Old 05-29-2014, 02:09 AM
Synnove's Avatar
Is there a way to use madVR or the built in image viewer to display patterns with a constant 22% or so APL? From what I've read, that seems to be the recommended way to calibrate plasmas.
Synnove is offline
post #3624 of 8914 Old 05-29-2014, 02:15 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
if you have the actual pattern select dvd manual when u first start up hcfr. Display then you can display the image and take your readings. This is my guess Im no expert though..
post #3625 of 8914 Old 05-29-2014, 02:17 AM
Synnove's Avatar
I'm using my PC as the image source, as such I'd rather not manually advance patterns if I do not have to (hence why I'm asking if HCFR can generate patterns with a constant 22% APL).
Synnove is offline
post #3626 of 8914 Old 05-29-2014, 02:20 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
Ah I see. Im not 100% sure but I haven't seen anything in there that would lead me to believe 22% was a option. Most are in 5% or 10% or 25% increments.
But if you are using MADVR im guessing you are using WPC as well. If you have the pattern why not display it through there? You can start a new measure and just click back and forth from a manual and auto generator session easily that way I found.
post #3627 of 8914 Old 05-29-2014, 02:21 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
Ok After going through that dropdown box multiple times there is no option for device instance id value. Is it abbreviated under something different.?
post #3628 of 8914 Old 05-29-2014, 05:22 AM
gwgill's Avatar
Quoted: 249 Post(s)
Liked: 186
You still haven't clearly answered the question:
"Does a device appear in device manager when you plug the i1display pro in ?"
"Yes" or "No" would be good replies.
If "Yes", then what category it appears under would be a bonus answer.
If a device appears, then it's worth checking if it is in fact the i1display pro.
To get access to the VID and PID in device manager:
Right click on the device and select "Properties"
Select the "Details" tab.
Select the pull down at the top of the tab (that's the thing with the down arrow to the right)
Select "Device Instance ID", "Hardware ID's" or "Compatible ID's" to locate a selection
containing the VID and PID's.
Copy and paste the information from that selection in your reply.
gwgill is offline
post #3629 of 8914 Old 05-29-2014, 05:41 AM
Holiday121's Avatar
Quoted: 548 Post(s)
Liked: 148
Ok I work for another 12 hours .
I am at work right now so can't test until I get home.
Going to try to explain it though.
When u plug in the device the pop up bubble comes up in the bottom right. Says installing new hardware. When I click it it's says i1 display pro searching for drivers.
After it's done searching it says drivers found but where is said i1 display pro it turns into USB input device.
So if it's installing correctly I'm not sure. I'll get you the screenshots of te values later tonight thanks
post #3630 of 8914 Old 05-29-2014, 05:46 AM
gwgill's Avatar
Quoted: 249 Post(s)
Liked: 186
Right, but what's Device manager doing ? Are you watching it ? Does anything appear in the list ?
gwgill is offline
Reply Display Calibration
