HCFR - Open source projector and display calibration software - Page 124 - AVS Forum | Home Theater Discussions And Reviews
 920Likes
post #3691 of 8928 Old 06-05-2014, 03:33 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Yes, the L bar in 3.1.1 corresponds to Lightness, not Luminance. CIELCH are perceptual coordinates so their sensitivity to adjustments should correspond more closely to what is visually important. If you have any suggestions on what coordinate sets make for easier real-time adjustments let me know.
zoyd is offline
post #3692 of 8928 Old 06-05-2014, 04:55 AM
thegladiator75's Avatar
Well, are you suggesting is a better choice to have the lightness as target for the CMS instead of luminance?
thegladiator75 is offline
post #3693 of 8928 Old 06-05-2014, 05:29 AM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
Ok going to give this htpc ankther shot since I have a few hours.
Going to try to use a new hard drive which nothing's been installed on besides windows 7.
Should I install the software for my xrite i1 display pro or just see if hcfr find it once I plug it in?
Holiday121 is offline
post #3694 of 8928 Old 06-05-2014, 05:38 AM - Thread Starter
zoyd's Avatar
Liked: 1055
It would have been handy to try and diagnose with spotread the problem you were having rather than taking more shots in the dark. Don't install the x-rite software.
zoyd is offline
post #3695 of 8928 Old 06-05-2014, 05:39 AM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
Hold on let me try the spot read
post #3696 of 8928 Old 06-05-2014, 05:41 AM - Thread Starter
zoyd's Avatar
Liked: 1055
I'm asking what you prefer to have as target bars when making real-time adjustments. The current choices are the old RGB style or the new LCH, delta Luminance (and delta xy) still updates in the grid. But I can make them any coordinates, LUV, xyY, Lab, etc.
zoyd is offline
post #3697 of 8928 Old 06-05-2014, 06:07 AM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
Ok when I click spotread a black box just opens and closes
is there something im doing wrong
post #3698 of 8928 Old 06-05-2014, 06:43 AM
gwgill's Avatar
Quoted: 249 Post(s)
Liked: 186
Open a Command prompt window (that's something like Start->Programs->Accessories->Command Prompt),
CD (that's "Change Directory") to where the executable is, and then run it, ie:
spotread -D7
See something like this for more guidance on how find your way around.
gwgill is offline
post #3699 of 8928 Old 06-05-2014, 07:01 AM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
ok I got it. once open what am I looking for?
post #3700 of 8928 Old 06-05-2014, 07:06 AM - Thread Starter
zoyd's Avatar
Liked: 1055
type the command and then copy the output to a text file. (click the icon in the upper left of the command window and choose edit->select all and then edit->copy) zip the file and upload here.
zoyd is offline
post #3701 of 8928 Old 06-05-2014, 07:11 AM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
here you go NewTextDocument.zip 2k .zip file
post #3702 of 8928 Old 06-05-2014, 07:13 AM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
post #3703 of 8928 Old 06-05-2014, 07:17 AM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
new-D7.zip 1k .zip file
There you go sorry
File Type: zip new-D7.zip (924 Bytes, 32 views)
post #3704 of 8928 Old 06-05-2014, 07:24 AM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
post #3705 of 8928 Old 06-05-2014, 07:26 AM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
Maybe a previous step or driver or something I'm missing?
post #3706 of 8928 Old 06-05-2014, 09:49 AM
HDTVChallenged's Avatar
Liked: 215
I think it's probably OK as is in 3.1.1. The LCH bars plus the dE value gets you there pretty well. I was just surprised that it sometimes took 2 or 3 clicks of "tint" to see a change on the "H" bar. OTOH, the L and C bars are a big help in confirming the best compromise point between Lightness/Luminance and Saturation especially when you only have a single "color" control to adjust both values ... no more guessing. wink.gif
The RGB bars let you zoom in on the best "tint" pretty quick too ... so between the two current choices, I think you've got the situation pretty well surrounded.
PS: I was curious about the reference/origin point of the LCH values ... one would think that it would be the white-point, but that doesn't seem to work mathematically. My second choice was equal-energy ... or is it rooted in the Luv colorspace? confused.gif
HDTVChallenged is offline
post #3707 of 8928 Old 06-05-2014, 10:30 AM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
So I ended up trying the second hard drive with a fresh operating system still no luck.
Weird
post #3708 of 8928 Old 06-05-2014, 11:17 AM
rickardl's Avatar
Quoted: 112 Post(s)
Liked: 93
How about making the RGB bar percentages show with one decimal?
rickardl is offline
post #3709 of 8928 Old 06-05-2014, 12:35 PM
10k
10k's Avatar
Quoted: 1444 Post(s)
Liked: 1507
My CMS controls are RGB so it would be nice if the real-time RGB bars remained, at least as an option.
10k is online now
post #3710 of 8928 Old 06-05-2014, 03:21 PM - Thread Starter
zoyd's Avatar
Liked: 1055
Originally Posted by rickardl View Post
And for Spears & Munsil vol2 equal energy windows?
I would assume unchecked meaning they use round nearest.
The only functionality that has changed is that the yellow luminance target bar has been replaced by the LCH target bars.
zoyd is offline
post #3711 of 8928 Old 06-05-2014, 03:27 PM
10k
10k's Avatar
Liked: 1507
Ah, got it. Thanks and sorry for the confusion.
10k is online now
post #3712 of 8928 Old 06-05-2014, 05:00 PM
gwgill's Avatar
Quoted: 249 Post(s)
Liked: 186
There you go sorry
It's good as far as it goes - the instrument is located. But it's unclear what happens after that. Unless spotread has been terminated by something, it should then either show an error message if opening the instrument failed, or proceed with a lot more debug output up to waiting for you to trigger a reading.
ie. after "i1d3_init_coms: About to init HID" is should normally then go on with:
usb_install_signal_handlers: called
usb_install_signal_handlers: done
i1d3_command: Sending cmd 'GetStatus' args '00 01 00 00 00 00 00 00'
i1d3_command: ICOM err 0x0
i1d3_command: Reading response
i1d3_command: got '00 00 00 06 00 00 00 00 00 00 00 00 00 00' ICOM err 0x0
i1d3_check_status: got OK
i1d3_init_coms: suceeded
i1d3_init_inst: called, debug = 7
i1d3_command: Sending cmd 'GetProductName' args '00 10 00 00 00 00 00 00'
i1d3_command: got '00 00 69 31 44 69 73 70 6c 61 79 33 20 00' ICOM err 0x0
etc.
Did it do that, or not ?
gwgill is offline
post #3713 of 8928 Old 06-05-2014, 05:16 PM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
Not sure I copied and pasted everything that was in there
post #3714 of 8928 Old 06-05-2014, 06:18 PM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
What would be something getting in the way of it program wise or process that can be terminated?
post #3715 of 8928 Old 06-05-2014, 07:01 PM
gwgill's Avatar
Quoted: 249 Post(s)
Liked: 186
You haven't said whether you cut and pasted all the output or whether the .zip file contained everything.
The only time I have seen a program terminate abnormally with no messages (ie. no crash pop-up from the OS) is:
A memory corruption bug that causes it to jump to the exit code.
Being killed by another process, ie. the user hitting Control C, or terminating the process in Task manager or equivalent.
Along the lines of the last would be anti-virus software, a virus on the system, some other software interfering with the attempt to run spotread, or some OS "misfeature".
A long shot would be to check the event viewer for any clues.
Another would be to run spotread from a command prompt started as administrator.
gwgill is offline
post #3716 of 8928 Old 06-05-2014, 10:33 PM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
The zip file contained everything that came up from spotread -D7 command. I selected all copied and pasted.
Is there another command to run to check more?
post #3717 of 8928 Old 06-05-2014, 10:44 PM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
Another thing I found weird was on my laptop in the drop down box it has simulated sensor as well as my xrite.
On htpc there isn't even simulated sensor in the drop down box
post #3718 of 8928 Old 06-05-2014, 11:03 PM
gwgill's Avatar
Quoted: 249 Post(s)
Liked: 186
No. spotread -D8 is going to give all the information that is available, short of running it under a debugger, and single stepping it.
Something is very strange on your system.
gwgill is offline
post #3719 of 8928 Old 06-05-2014, 11:33 PM
Liked: 215
And the RGB bars are back if you uncheck "Detect primary colors during user measures" under advanced->preferences.
BTW, I found some wiki's that (somewhat tersely) explain the LCH coordinates. So, it appears that "C" (chroma) isn't exactly equivalent to s (saturation) in HSL, but I don't think that really matters for the intended usage. At least the wiki page explains why my feeble attempts to decipher the values failed. smile.gif
post #3720 of 8928 Old 06-06-2014, 02:10 AM
Holiday121's Avatar
Quoted: 554 Post(s)
Liked: 149
Ok I will run that later and post the results
Reply Display Calibration
