HCFR - Open source projector and display calibration software - Page 125 - AVS Forum | Home Theater Discussions And Reviews
 894Likes
post #3721 of 8666 Old 06-07-2014, 11:25 AM
thegladiator75's Avatar
Hi Zoyd, I own an i1dpro and a VT60 and I would like to understand why my readings of 0 IRE shows something like the red at 912%, blue at 0% and green at -47%. And it's weird because Calman reading of 0 IRE shows a perfectly balanced black...
thegladiator75 is offline
post #3722 of 8666 Old 06-07-2014, 12:17 PM
HDTVChallenged's Avatar
Liked: 215
That's normal. Your black level is darker than the meter can read.
I suspect Calman recognizes that the reading is "bogus" and doesn't bother to display it. Possibly to avoid messing up the gamma calculations, etc.
What happens with a 5% (or 10%) target?
HDTVChallenged is offline
post #3723 of 8666 Old 06-07-2014, 02:39 PM - Thread Starter
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
Version 3.1.2 has been uploaded to sourceforge.
  • Updated APL patterns from fixed background video level to average per channel video level.
  • Added single decimal precision to RGB/LCH bar text.
  • Disabled RGB/LCH Bars and target graphs when not in grayscale, colorspace, or freemeasures pages.
  • Added BT.1886 relative option [see ArgyllCMS collink -Ib:x.x option].
  • All dE and graph targets now use actual BT.1886 gamma values instead of user measured average.
  • Pure power law targets updated from fixed 2.22 to user specified via the Reference value.
  • Fixed bug when number of saved color checker measures conflicted with CCSG selection.
Set the BT.1886 gamma value to 0 for normal behavior. Set it to X.X to shift the curve up/down such that the point gamma at 50% is X.X. I like calibrating this to 2.4 on my display for dark room viewing.
Originally Posted by HDTVChallenged View Post
The only issue here is whether or not HCFR is adjusting it's expected target values based on the measured (average) gamma vs the disk encode gamma, which it does ... apparently, as long as you don't bring BT1886 into the mix. (It does for BT1886 too, but the adjustments can't be trusted since bt1886 <> power-law gamma.)
This update takes care of this issue, all targets are now calculated based on actual BT.1886 transfer characteristics if you have selected that option as your reference. Same goes for the power law option and "use measured" as an average is still available when using a power law reference but it's no longer very useful unless you are targeting something other than power law or BT.1886.
anta1974, Andrei_VVB and xvfx like this.
zoyd is offline
post #3724 of 8666 Old 06-08-2014, 03:55 AM
Liked: 215
Sounds good. I just spent a couple of days learning *all* about Luv, Lab, the LCH representations thereof and their relationships to the base CIEXYZ and xyY colorspace. My head's about to explode. wink.gif
During the marathon, I discovered that HCFR has always based the LCH values on the Lab colorspace ... which explains why the "H" values never made sense to me. I could never figure out why they changed dramatically as the saturation level changed. Now it does ... different scales for a* and b* gets ya every time. wink.gif I made a spreadsheet to compare all of the various possible color spaces and error deltas, so far it doesn't look like the Lab base would have a big effect on the LCH target bars.
post #3725 of 8666 Old 06-08-2014, 05:27 AM - Thread Starter
zoyd's Avatar
Liked: 1051
At some point I'll probably add more choices to the bar indicators, including the components of dE.
zoyd is offline
post #3726 of 8666 Old 06-08-2014, 07:44 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Thanks for the updates zoyd.
I haven't got around to run my test again on my htpc been busy at work will get to it Monday or Tuesday
Holiday121 is online now
post #3727 of 8666 Old 06-08-2014, 10:53 AM
Liked: 215
I haven't gotten any farther than the basic cartesian dE formulas .... and the deltaH*(uv) component. .... dE94 and especially dE2000, OTOH .... eek.gif I need a few days of rest and recovery first. smile.gif
post #3728 of 8666 Old 06-09-2014, 12:48 AM
Liked: 215
Ok ... I did some crosschecking between my latest craptacular spreadsheet and HCFR 3.1.2 with data from my last calibration run. The good news is that all of the LCh (ab) values line up. The not so good news is that delta-hue differences between LCh (ab) and LCh (u*v*) might be big enough to cause a click or two worth of "tint" adjustment difference on red and cyan. FWIW, the RGB bar method (@75% sat) lines up more with the L*u*v* delta-hue values. I don't know if this is a big issue or a small issue ... just thought I'd mention it. I confess that I don't yet understand the L*a*b* choice for display measurement, other than perhaps it allows for "legal" L* values >100 ... otherwise it just confuses me ... especially the effect on hue values. smile.gif
In the further good news department, it looks like the BT1886 target adjustment is working ... that pesky "light skin" color-checker target finally falls in the box with BT1886. A nice refinement there. smile.gif
post #3729 of 8666 Old 06-09-2014, 03:21 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Originally Posted by gwgill View Post
No. spotread -D8 is going to give all the information that is available, short of running it under a debugger, and single stepping it.
Something is very strange on your system.
Ok finally got around to doing the spotread -D8 here it is
spotread-D8.txt 4k .txt file
post #3730 of 8666 Old 06-09-2014, 07:58 AM - Thread Starter
zoyd's Avatar
Liked: 1051
Thanks for the feedback, I think it will make the most sense for knob tweaking to make the bars selectable between RGB and HSL coordinates as those are most likely to linearly proportional to CMS system adjustments. And then add a separate dE indicator to look at trade-offs.
zoyd is offline
post #3731 of 8666 Old 06-09-2014, 11:45 AM
Liked: 215
Sounds reasonable.
It did occur to me that the Lab based delta-h might be enhancing the differences between power-law and bt1886. My craptacular spreadsheet doesn't account for that, and I was using data from a bt1886 run. I should probably recheck this during a "live" session to make sure it's not a power-law vs. bt1886 artifact.
post #3732 of 8666 Old 06-09-2014, 11:12 PM
Liked: 215
Zoyd,
On third thought, perhaps the choice of RGB, HSL or LCh(u*v*) ... or Lsh(u*v*) bars? Lsh(u*,v*) seems to match the way CMS (HSL) controls usually work, while retaining the references to CIE color spaces and user defined white-points. HSL(rgb) loses those REC709/601 anchor points. I'm not sure what "HSL" version you meant ... I assumed Lsh(u*,v*) above, then I did more research.
post #3733 of 8666 Old 06-10-2014, 12:02 AM
gwgill's Avatar
Quoted: 245 Post(s)
Liked: 181
Sorry, that doesn't add anything. Spotread just dies or is killed without a message sometime around trying to open the device.
You could try this version, and see if it behaves any differently
gwgill is online now
post #3734 of 8666 Old 06-10-2014, 08:41 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Will do and post back thanks
post #3735 of 8666 Old 06-10-2014, 05:17 PM
Synnove's Avatar
Thanks to the generosity of Klein Instruments, I was able to procure readings from their CS2000 of my Kuro's red, blue, green, and white levels in xyY format. I'm trying to create conversion matrices for DispcalGUI as well as HCFR. I've read up on the process one uses for entering the corrections in to HCFR, however I cannot seem to get a proper result. Does anyone have some suitable advise for addressing this?
ConnecTEDDD likes this.
Synnove is offline
post #3736 of 8666 Old 06-10-2014, 05:52 PM
Stereodude's Avatar
Quoted: 3085 Post(s)
Liked: 2236
Isn't there a spreadsheet floating around somewhere that you enter the data into and it generates the corrections?
Stereodude is online now
post #3737 of 8666 Old 06-10-2014, 05:56 PM
gwgill's Avatar
Quoted: 245 Post(s)
Liked: 181
Without some details of what steps you have tried, and where you got stuck, it's hard to help.
post #3738 of 8666 Old 06-10-2014, 06:27 PM
Synnove's Avatar
I shall look for the spreadsheet, thank you for the suggestion!
gwgill: sorry, let me start with the actual measurements:
White
0.3152
0.3285
100.8
Red
0.6681
0.3239
23.59
Blue
0.1468
0.0631
7.5
Green
0.2755
0.6502
72.79
From my understanding, if I wish to use these measurements with HCFR, I need to the meter property page and click the "sensor matrix" tab. I assume I'm supposed to convert my primary color measurements in to XYZ and paste them in the grid as RGB from top to bottom?
With DispcalGUI, I need to do more research on the format of the file as the instructions for it are somewhat confusing for a layperson like myself.
Synnove is offline
post #3739 of 8666 Old 06-10-2014, 08:34 PM
gwgill's Avatar
Quoted: 245 Post(s)
Liked: 181
Sorry, I can't help you with HCFR.
A thread on creating an ArgyllCMS .ccmx is here. I'd imagine that a .ccmx is usable both in HCFR and ArgyllCMS + DispcalGUI.
post #3740 of 8666 Old 06-11-2014, 02:03 AM
Liked: 215
I can't tell what you're trying to do here. Are you trying to profile another meter with this data? If so, it sounds like you're making the process harder than it needs to be (in HCFR.)
post #3741 of 8666 Old 06-11-2014, 04:30 AM - Thread Starter
zoyd's Avatar
Liked: 1051
Enter those measurements in a synthetic probe page and check the reference box. Then you need the corresponding measurements for those patches from the probe you want to profile (either entered manually in the primaries page or measured). Then select advanced->meter correction file->create from existing measurements.
zoyd is offline
post #3742 of 8666 Old 06-12-2014, 05:07 AM - Thread Starter
zoyd's Avatar
Liked: 1051
Sorry for the rapid updates but I tied up some loose ends related to the last update and added a coordinate option for the levels indicators as well as a dE bar.
3.1.3
  • Fixed creation of matrix correction using manual reference entry
  • Fixed display of near black/near white selected colors
  • Updated dE of near black to use gray world weighted white reference
  • Updated special colorspace targets to BT.1886 gamma if selected
  • Added dE bar to real-time levels indicator
  • Added option for HSV coordinates to real-time levels indicator
  • Fixed luminance and satshift graphs when using BT.1886
  • Fixed delta luminance for saturation sweeps when using BT.1886
The added option is under user measures (same place as "detect primary colors...") as a checkbox for "Use HSV Level Bars". If left unchecked RGB coordinates will be used. These coordinate indicators should provide better correlation with HSV(L) CMS display controls for real-time adjustments. I've set the "V" to be identical to Luminance level, H is hue angle with values > 100% a rotation counter clockwise from target. S is a measure of the distance to the white point.
The RGB bars should also be more usable for RGB based CMS systems as they have been changed to actual coordinate differences instead of white balance values. Normal white balance indicators are maintained when you are measuring a gray/white patches.
Also put in a 4th bar with dE level. [Note: dE updating in continuous mode for the gray scale uses the same absolute dE formula as the RGB measures info window and not the user selected formula]
zoyd is offline
post #3743 of 8666 Old 06-12-2014, 10:22 AM
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Outstanding...
rickardl is offline
post #3744 of 8666 Old 06-12-2014, 11:11 AM
Liked: 215
Humm ... I guess I'll have to wait and see how well the HSL bars work. But I think the white point reference with the RGB bars was one of the reasons they were so effective for setting "Tint/Hue."
PS: I haven't even had a chance to run 3.1.2 through all the paces yet. Gettin' dizzy here. ... I know ... nag, nag, nag.
post #3745 of 8666 Old 06-12-2014, 11:40 AM - Thread Starter
zoyd's Avatar
Liked: 1051
It should be straight forward, set the right hue angle first (H=100%), then get the point in plane by setting luminance (V=100%) and save saturation for last.
zoyd is offline
post #3746 of 8666 Old 06-12-2014, 11:51 AM
Liked: 215
Yeah ... you're probably on the right track with the way the UI *should* work. And the new RGB treatment is probably better for the poor souls that don't have "proper" HSL CMS controls. As always, the devil's in the details.
post #3747 of 8666 Old 06-12-2014, 02:37 PM
xvfx's Avatar
Quoted: 408 Post(s)
Liked: 225
Will there be an option for Mascior's disc for the saturation sweeps to get rid of 0%?
xvfx is offline
post #3748 of 8666 Old 06-13-2014, 01:45 AM
Synnove's Avatar
Thank you for your assistance, the instructions you described worked great! The only oddity was a 1DE difference in the blue primary (the rest was spot on after the corrections).
Synnove is offline
post #3749 of 8666 Old 06-13-2014, 03:43 AM - Thread Starter
zoyd's Avatar
Liked: 1051
HCFR 3.1.3 is back up, let me know how it goes.
no
You didn't give any details on how the CS2000 measurements were obtained. I hope they are from your display using the same pattern generator, otherwise they are of no use for profiling.
zoyd is offline
post #3750 of 8666 Old 06-13-2014, 03:49 AM
Synnove's Avatar
They were played via Davinci Resolve/Decklink using the same slides/display settings.
Synnove is offline
Reply Display Calibration
