HCFR - Open source projector and display calibration software - Page 141 - AVS Forum | Home Theater Discussions And Reviews
 986Likes
post #4201 of 9349 Old 08-26-2014, 09:35 PM
HDTVChallenged's Avatar
Liked: 215
Originally Posted by xvfx View Post
I'm surprised most don't use CIE2000.
dE76 is the most ruthless tool for greyscale. ... IMO, one should remove as much absolute mathematical error as possible regardless of so-called "perceptual" weighing.
CIE2000 is for when you want to "feel good" about the errors you can't fix.
HDTVChallenged is offline
post #4202 of 9349 Old 08-26-2014, 10:30 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
There isn't a whole lot of difference between DE76, DE94 or CIE2000 near the neutral axis - most of the tweaks are in the saturated colors which tend to be de-weighted in DE94 and CIE2000.
gwgill is offline
post #4203 of 9349 Old 08-27-2014, 08:52 AM
Liked: 215
All I'm saying is that little "errors" add up in a Y/Cr/Cb color system ... if your "zero" is really something like "0.1," that just makes it harder to find all the other colors. So be as ruthless as possible when you can.
post #4204 of 9349 Old 08-27-2014, 07:24 PM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
HCFR - ArgyllCMS meter correction comparison
I wanted to compare the meter correction technique that HCFR uses (RGBW 4-color matrix solution) to what ArgyllCMS is doing to evaluate any differences. The data below was obtained via the following:
1. Profile a D3 against the JETI-1211 using ArgyllCMS
2. Measure a test set with the JETI-1211 and the profiled D3
3. Profile a D3 against the JETI-1211 using HCFR
4. Measure the test set again with the HCFR profiled D3
5. Remeasure with the JETI-1211 for repeatability
In Step 1 ArgyllCMS calculates the best-fit matrix that minimizes color difference errors between the two probes (as opposed to the closed form solution of the 4-color matrix method). For this method I used a profiling set of 22 colors consisting of 25% increments along each color axis and ~11% increments along the neutral axis.
Steps 2-5 use a different set of 37 test colors at higher density along each RGBW axis.
Steps 3 and 4 were repeated using both 100% RGBW and 75% RGBW patches to form the HCFR correction matrix.
Results show that the ArgyllCMS method reproduces the reference values somewhat better than the 4-color method and the 75% level-based a tad better than the 100%, although the absolute color differences are pretty small (mean dE2000: best-fit =0.19, 75% 4-color=0.26, and 100% 4-color=0.39). Repeatability was excellent at 0.09 dE2000 mean difference.
RIppolito, gwgill and spacediver like this.
zoyd is offline
post #4205 of 9349 Old 08-27-2014, 08:58 PM
James Freeman's Avatar
Quoted: 517 Post(s)
Liked: 341
Can someone please explain why do we need a spectrophotometer along with a colorimiter?
Are the results a lot better when using a correction matrix?
I've been calibrating my displays with i1D2 then with i1D3 for years, was is "not accurate"?
Is a difference of 0.5 THAT visible?
James Freeman is offline
post #4206 of 9349 Old 08-27-2014, 09:05 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
That's pretty interesting, since I haven't done such a comparison myself.
Any feeling whether Argyll's fitting makes any difference (better or worse) when just using 4 patches (RGBW) ?
gwgill is offline
post #4207 of 9349 Old 08-27-2014, 09:06 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
The point is to use the Spectrometer to create the correction matrix.
gwgill is offline
post #4208 of 9349 Old 08-27-2014, 09:09 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
if I understand correctly, the 0.5 is the difference between the i1d3 and jeti after profiling, not before.
spacediver is offline
post #4209 of 9349 Old 08-27-2014, 09:22 PM
Quoted: 517 Post(s)
Liked: 341
I understand, Thanks.
Will a spectrometer improve the calibration of the Greyscale or only the Colors?
From what I've seen I think that a well behaved Greyscale and Gamma are much more important than sub 3dE color errors.
post #4210 of 9349 Old 08-27-2014, 09:50 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
There's no guarantee that using a spectrometer will improve the accuracy of your colorimeter - by accident, the colorimeter may be more accurate with one of the standard calibration matricies.
But the point of using a spectrometer is that it will guarantee a minimum level of accuracy, irrespective of how good or bad the colorimeter and it's standard calibration matricies fit your display.
Since we are more visually sensitive to tints in neutrals, any improvement in accuracy is likely to be noticed in those areas.
Brian Hampton and RIppolito like this.
gwgill is offline
post #4211 of 9349 Old 08-27-2014, 10:07 PM
sillysally's Avatar
Quoted: 1015 Post(s)
Liked: 952
As you may know I have been asking the above question, not just for ArgyllCMS but also for CM and LS.
For my meter correction matrix, I have been using Klein's ChromaPure software for the K10-A and Jeti 1211.
How does ArgyllCMS "best fit" work.?
I did try and use dispcal/Argyll using the beta binary release for the K10-A, but didn't think it worked very well to create a meter correction matrix.
When I tried to run a meter correction matrix for the K10-A, dispcalGUI powered by ArgyllCMS used only the 4 WRGB patterns.
Does best fit use more than one four set of WRGB?
Because I use a VT60 (Plasma), I find that with using the Jeti 1211 as reference meter and K10-A as source meter to make a meter correction matrix. Using Klein's ChromaPure and make 3 or 4 meter correction matrix's, then use the correction matrix that has the best fit (least amount of errors for WRGB for use with the K10-A).
btw, are you planing on releasing the new source code for the K10-A in a binary release that I can use with dispcal.?
Also are you planing any time soon to add support for the Lumagen Radiance 20XX ?
ss
"Don't worry be happy"
For Sale Lumagen Radiance Pro 4440/2, see link for details
http://www.avsforum.com/forum/210-vi...l#post54911046
sillysally is offline
post #4212 of 9349 Old 08-27-2014, 10:23 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Zoyd/Graeme/anyone else,
I'm trying an interesting experiment with gratings to see if I can infer luminance levels below that of the instrument's range (i1d3). The approach is as follows:
take a grating with spatially alternating darker and lighter lines. Measure the luminance of each of these values separately, and then measure the grating (the colorimeter's sensor is large enough that it integrates the luminance information across the stripes). Preliminary calculations show that this works. However, when I created a grating with a black stripe and a lighter stripe, the lighter stripe measured 0.28 cd/m2, the grating itself measured at 0.14 cd/m2, implying the dark stripe (black) was exactly 0 cd/m2.
Is there anyway to gain access to more than 2 decimal places of readoff precision in the real time readings in HCFR? And do you think this approach could work to infer luminances below that of the instrument's range?
post #4213 of 9349 Old 08-27-2014, 10:47 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
It creates a matrix to minimize the delta E's between the measured values.
It uses best fit for however many patches are measured, including the default WRGB. You can select a larger number of patches using the "ccxxmake -s N" flag, where N > 1, and it will generate N x N x N regular spaced cube test patches.
A disadvantage of using ccxxmake for the K10 is that currently it has no capability to store the matrix in the meter.
The current 1.7 beta snapshot supports the K10-A.
http://www.argyllcms.com/beta1.7_win32_exe.zip
http://www.argyllcms.com/beta1.7_win64_exe.zip
I don't have a Radiance 20XX, so that's not possible. If Lumagen want ArgyllCMS support, they know what to do...
gwgill is offline
post #4214 of 9349 Old 08-27-2014, 10:52 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
It's hard to be sure what you are suggesting, but assuming you are talking about printing black stripes on a transparent medium, this will reduce the light level reaching the meter, worsening it's ability to read low light levels.
If you mean something else, you'll have to make your description clearer, and/or include some photo's.
gwgill is offline
post #4215 of 9349 Old 08-27-2014, 11:17 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Oh this is all done on a display. I use matlab to create the test patterns, like this one:
This pattern contains alternating stripes of black (video level 0) and dark grey (video level 20). Measuring the grating with a colorimeter will integrate the luminance information coming from both sets of stripes. My video level 20 (RGB = [20 20 20]) measures at 0.28 nits, and the grating as a whole measures at 0.14 nits. This implies that video level 0 is 0 nits. If I had access to more decimal places (e.g. 0.2843 nits for video level 20, and 0.1438 for the grating), then I could infer a black level of 0.0033 nits.
post #4216 of 9349 Old 08-28-2014, 04:16 AM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
I'm not sure you've thought that out. Diluting what you're trying to measure with something that may be an order of magnitude brighter (given the typical gamma) is no way to improve precision. If there were more decimal places in the reading, then you would be able to measure the black level directly.
gwgill is offline
post #4217 of 9349 Old 08-28-2014, 06:56 AM - Thread Starter
zoyd's Avatar
Liked: 1064
No, 0.5 dE2000 is not perceptible but that was after calibrating it to the spectrometer. Without a spectrometer based correction the amount of residual error you might have will depend on the colorimeter, the display, and any vendor supplied corrections. In this case no correction yields peak errors greater than 3 and with the vendor supplied plasma correction peak errors of ~1.5 (see table below).
I was not expecting much of a difference given the D3 has excellent repeatability and linearity. I repeated the experiment and added the ArgyllCMS version of 4-color correction and found the following:
A very marginal benefit when adding the extra colors.
The freemeasures tab will show 3 decimals for the Y value in continuous measure mode but I agree with Graeme, I don't see how you get more precision out of the sensor with your test.
Andrei_VVB and gwgill like this.
zoyd is offline
post #4218 of 9349 Old 08-28-2014, 01:14 PM
xvfx's Avatar
Quoted: 410 Post(s)
Liked: 242
Hmm… and the rest of that thread by the big names were very interesting.
What dE to use when calibrating?
xvfx is offline
post #4219 of 9349 Old 08-28-2014, 02:06 PM
<^..^>Smokey Joe's Avatar
Quoted: 75 Post(s)
Liked: 101
@zoyd
You may be more likely to see a better correction of the RGBW if you use 10%, 30%, 70% and 90% levels of RGBW.
My reasoning behind this is the spectral distribution changes as you get closer to black. Simply, the hollows can drop below detection and any peaks dominate more which could cause slight metameric failure.
You would use the 90% as the anchor and then apply a simple y=bx+c or use the regression x=(y-c)/b to each RGBW, depends which way you plot the slope and intercept.
A simple test to see if an improvement could be found is to do a standard RGBW correction at 10%, 30%, 70% and 90% levels. Plot the RGBW results and see if they drift. I suspect some displays will drift others won't, depends on the technology. Might even find different regression paths for each RGBW.
ConnecTEDDD likes this.
Masterpiece Calibration Ltd
Lincolnvilleshire
New Zealand
<^..^>Smokey Joe is offline
post #4220 of 9349 Old 08-28-2014, 03:58 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Take an instrument that measures with a precision of 0.01 cd/m2 (and can read down to 0.01 cd/m2).
Now take a grating that has alternating lines, with respective luminances of exactly 0.003 cd/m2 and 0.08 cd/m2. The grating will "output" a luminance of exactly 0.0415 cd/m2.
The instrument will measure the lighter line as 0.08 cd/m2, and will measure the grating as 0.04 cd/m2.
Doing the math, one can infer that the darker line = (grating luminance*2)-lighter line, = 0.08 - 0.08 = 0.
Damn, I see your point.
Ok, back to psychophysics
post #4221 of 9349 Old 08-28-2014, 04:24 PM
Quoted: 28 Post(s)
Hi All, I'm looking to contribute to the development of HCFR. Is the hcfr-development list at sourceforge still a good place to ask questions? (There hasn't been a post since February) Do the devs hang out anywhere else (irc, other mailing lists, etc?)
JStanton is offline
post #4222 of 9349 Old 08-28-2014, 04:54 PM - Thread Starter
zoyd's Avatar
Liked: 1064
Originally Posted by <^..^>Smokey Joe View Post
@zoyd
I have no desire to do multiple 4-color profiles to gain a perhaps 0.15 dE better match to the reference probe especially since the ArgyllCMS result is already near repeatability limits, and I can just use that.
zoyd is offline
post #4223 of 9349 Old 08-28-2014, 06:16 PM - Thread Starter
zoyd's Avatar
Liked: 1064
You may want to sign up on the ArgyllCMS mailing list as well but you can reach me or Graeme on the HCFR list (maybe JohnAD as well). I'm the only one working on the code at the moment and have been too busy with other things to get much done recently.
zoyd is offline
post #4224 of 9349 Old 08-28-2014, 07:22 PM
sillysally's Avatar
Liked: 952
I have the snapshot from May for beta 1.7
According to dispcalGUI beta, there is a updated version beta 1.7,
I thought Jim from Lumagen was going to send you one. At-least that is what he said he would do.
ss
post #4225 of 9349 Old 08-28-2014, 07:51 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
There is, but I wouldn't recommend it for general use at the moment since there
are some peculiarities with profiling that I'm still sorting out.
We had a discussion and there was some suggestion that they were willing to do that, but at this point they haven't followed up on it.
gwgill is offline
post #4226 of 9349 Old 08-29-2014, 08:24 AM
Liked: 215
LOL ... and so it goes ... To be fair, at this point *I* don't use the 3d DE formulas at all for greyscale (or whitepoints,) I use the 2d DeltaXY or DeltaUV values and worry about the Y (or L*) contribution(s) when I get to the gamma/EOTF adjustments. 6-axis CMS is another beast ... "cylindrical" coordinates et al. ....
So IMHO, dE is really just the final evaluation check ... but not so much of a calibration tool ... if that makes any sense.
post #4227 of 9349 Old 08-29-2014, 12:34 PM - Thread Starter
zoyd's Avatar
Liked: 1064
Originally Posted by orion2001 View Post
Thanks zoyd! I really appreciate it. It'd be great if you could post an update on this whenever you get the chance to look at it. It would be nice to know whether you had to make any changes or chose to leave things as is. Cheers.
I took a look at the differences between pattern sources in both video and PC levels by first comparing the measured output of the HCFR internal pattern generator and HCFR driven madTPG. From the results below I could not find anything in the RGB tracking or color error results that would lead one to need different display calibration settings, so either generator can be used and should result in the same adjustments. There is slightly greater mean separation in calculated dE when using PC levels but this is only ~0.3 dE. This is probably due to what I mentioned earlier in that when HCFR rounds after video to PC level conversion it does not recalculate the percentage of peak white for it's target.
I then looked at the mp4 AVSHD patterns via MPC-HC/madVR playback and compared them to the HCFR internal patterns with much the same result. So I do not see any problems with using any of the 3 source patterns in either video or PC generated levels for calibration within HCFR.
zoyd is offline
post #4228 of 9349 Old 08-30-2014, 10:23 AM
xvfx's Avatar
Quoted: 410 Post(s)
Liked: 242
So IMHO, dE is really just the final evaluation check … but not so much of a calibration tool ... if that makes any sense.
What do you use for the CMS, DE94?
xvfx is offline
post #4229 of 9349 Old 08-30-2014, 09:06 PM
Liked: 215
For evaluation or actual calibration? ... Evaluation (as in "color checker" targets) = DE2000 ... because I want to feel good about that which I can't fix.
For calibration, I look at Delta-Hue, Delta-Chroma/Delta-L and Delta-Sat (LCHuv coordinates) ... in that order of priority.
post #4230 of 9349 Old 09-01-2014, 11:05 PM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
My d3 was profiled in Calman against a spectro. On both meters it was CHECKED the Plasma option. Now I have the correction values.
Do these values, when inserted manually in HCFR work as a good correction matrix WITHOUT the plasma selected at display type or I have to check that too?
Thank you!
Andrei_VVB is offline
Reply Display Calibration
