HCFR - Open source projector and display calibration software - Page 160 - AVS Forum | Home Theater Discussions And Reviews
 920Likes
post #4771 of 8935 Old 11-03-2014, 09:12 AM
HDTVChallenged's Avatar
Liked: 215
Originally Posted by LastButNotLeast View Post
Which is why I've been looking forward to a wiki, but I seem to be a minority of one.
BTW, I was talking about the r/g/b of an individual color, one at a time.
Right ... I assumed your CMS controls were of the RGB type vs HCL/HSV type. That would add an extra layer or two of potential frustration and confusion.
The problem with developing the one wiki to rule them all, is that it seems like every display has it's own quirks, pitfalls. So it's actually quite daunting to distill all of this calibration "stuff" into a concise and understandable document. Even the top level pros struggle at times (see Quattron and OLED discussions.) Specifically, the procedure I use to dial in the CMS on my displays may not work at all on your Samsung due to the RGB vs. HCL/HSV differences. I'm sure I'd have to tweak the process a bit.
HDTVChallenged is offline
post #4772 of 8935 Old 11-03-2014, 09:45 AM
LastButNotLeast's Avatar
Quoted: 1593 Post(s)
Liked: 1202
Would that not still be easier than reinventing the wheel?
I'm doing color now. Then gamma (which I didn't know how to do until it was discussed here). Then my "final" run of grayscale (since I've found just about everything affects grayscale - actually, everything affects everything else ).
So even a simple (relatively speaking) flowchart would get someone started, with side comments added about the difference in approach when dealing with one technology vs. another.
Again, just wishful thinking.
AustinJerry started a "simple" guide to REW that's now version 3.9 and 100 pages. But it's a godsend for anyone interesting in tackling the program and room acoustics.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #4773 of 8935 Old 11-03-2014, 10:46 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Originally Posted by 22point8 View Post
If I want to adjust gamma with 10 point, should I do it using the 8/25 patterns, or the small APL patterns on the AVS709 disk (the native gamma), I can get bt1886 if I adjust the gamma with the small APL patterns, but what I have above is the best I could do with the 8/25 patterns (for 2.2). Or is it a case of see what it looks like with content?
Using the small APL patterns are fine, don't worry about it.
For SD is there any way to disable overscan (probably from the service menu)?
Not that I know of, when my display is sent 480i is does not do any overscan.
Is there a trick for enabling cal day/night from the service menu or is it just a 'not in europe' situation.
This was a problem in D-series also, no way to enable it in European firmware.
zoyd is offline
post #4774 of 8935 Old 11-03-2014, 01:29 PM
alien2108's Avatar
One question...Is there any possibility that calibration images generated inside HCFR would be somehow changed by computer when projected over HDMI? I think I got different readings when using AVSHD 709 images from USB stick directly on Samsung Media Player and images generated by HCFR running on MacBook Pro in VMWare Fusion over HDMI...
alien2108 is offline
post #4775 of 8935 Old 11-03-2014, 02:25 PM
22point8's Avatar
Quoted: 141 Post(s)
Liked: 70
Ok, I used the AVS709 small APL windows to do the BT1886, which also flattened the gamma with 8%/25APL, and then I measured regular 8% windows and still had a BT1886 gamma.
Code:
BT1886 Gamma 8% window
Target/Actual
10)2.18/2.14
20)2.25/2.25
30)2.28/2.29
40)2.30/2.31
50)2.31/2.31
60)2.32/2.33
70)2.32/2.34
80)2.33/2.32
90)2.33/2.33
AVERAGE 2.29
8% windows 25% APL
10)2.22
20)2.24
30)2.26
40)2.27
50)2.28
60)2.29
70)2.29
80)2.28
90)2.32
AVERAGE 2.27
22point8 is offline
post #4776 of 8935 Old 11-03-2014, 10:05 PM
Liked: 215
A basic battle plan:
1) Contrast (and Backlight for LCDs)
2) Brightness
3) Evaluate Greyscale ... find the best color temp preset, check for color clipping
4) Calibrate Greyscale, repeat contrast, brightness and color clipping checks
5) Gamma: Find best gamma preset, then dial-in your desired gamma/luminance curve with multipoint greyscale controls (if available) ... recheck previous work.
6) Color: a) basic color/tint controls or b) Use CMS to dial in R.709 colors ... recheck everything again.
7) Use color-checker targets as the final overall check.
Of course, the devil is in the details. Each of the steps above have various conditions and sub-steps which will depend on the individual display being calibrated. Furthermore, in some cases it might be easier to swap the order of steps 5(gamma) and 6(color/CMS) ... depending on how linearly the display operates.
That's the what ... the why and how is where things get "interesting" and divergent. Frankly, I'm not sure I could come up with a single flow chart to cover just the two displays I'm currently maintaining.
post #4777 of 8935 Old 11-04-2014, 07:11 AM
Liked: 1202
Excellent. The first footnote would be that adjusting gamma is done by comparing Y to "Target Y," which was a point I was missing for years.
Which reminds me of step 0: The little down arrow that expands the data window!
See, isn't this fun?!
Michael
post #4778 of 8935 Old 11-04-2014, 11:19 PM
Liked: 215
Michael
Note really ... gives me headache. I'm the *wrong* person to attempt anything like this. I'm the type that just clicks on stuff until I figure out to work the program and use it effectively. Mistakes have been made ... hours of work round-filed ...
I don't particularly enjoy the process of calibration, it's about one and a half steps up from doing housework on enjoyometer. I was actually relieved that my new PJ only has 2 point greyscale control ...
post #4779 of 8935 Old 11-06-2014, 07:06 AM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
2) Brightness
Is there a way to set each of these using meter readings or is it purely by looking at patterns and making a visual assessment? I'm new to HCFR but plan on giving it a go with my new Display 1 I just purchased. Thanks
carillon is offline
post #4780 of 8935 Old 11-06-2014, 07:46 AM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
I'd like to install my new i1d3... Should I just let Windows search for and install the driver or download a driver from the X-Rite site? Also, I previously had a Spyder 2 device and installed Argyll to get it to work. Do I need Argyll anymore? Thanks
carillon is offline
post #4781 of 8935 Old 11-06-2014, 08:06 AM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Use the drivers that are included in the HCFR drivers directory (ArgyllCMS.inf)
spacediver is offline
post #4782 of 8935 Old 11-06-2014, 08:18 AM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
Thanks, when I look at my device manager, it shows the i1Display Pro is listed under...
Argyll LibUSB-win32 devices
> Eye-One Display 3 (Argyll)
Is this correct?
carillon is offline
post #4783 of 8935 Old 11-06-2014, 08:26 AM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
i believe so. try it and see if it works.
post #4784 of 8935 Old 11-06-2014, 09:41 AM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
Do I need a correction matrix? I'm calibrating a Sharp Aquos LCD... what setting should I pick in the attached screen shots? There are several choices for display type, not sure which is correct.
Name:	Screen Shot 2014-11-06 at 12.36.46 PM.jpg
ID:	351834   Click image for larger version
Name:	Screen Shot 2014-11-06 at 12.36.54 PM.png
ID:	351842   Click image for larger version
Name:	Screen Shot 2014-11-06 at 12.37.14 PM.png
ID:	351850   Click image for larger version
Name:	Screen Shot 2014-11-06 at 12.37.23 PM.png
carillon is offline
post #4785 of 8935 Old 11-06-2014, 10:16 AM
Liked: 215
Both visually and with a meter. Contrast, brightness and color clipping are visual checks, however you'll need the meter to set contrast/backlight for your desired reference white level output.
Greyscale and color temp. preset evaluation requires the meter to check ... basically find which presets are closest to D65.
In fact, while you're at it go ahead an run the full greyscale, color primary/secondary and color saturation sweeps just to get an idea of how far you need to go to dial everything in.
post #4786 of 8935 Old 11-06-2014, 11:01 AM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
Thanks, I have the AVS and GCD disks, which one should I use with HCFR and for visual checks... does it matter?
carillon is offline
post #4787 of 8935 Old 11-06-2014, 11:11 AM
Liked: 215
AVS is probably better for the visual contrast and brightness patterns ... The blink rate on the GCD disk doesn't suit my eyes very well. GCD is probably easier for everything else (meter related.) Just be sure to check or uncheck the levels rounding block appropriately for the disk in use: "Use round down for ..."
PS: Sorry, I don't know the right answer for your correction "matrix" question.
post #4788 of 8935 Old 11-06-2014, 11:15 AM
numen's Avatar
Quoted: 49 Post(s)
You did not provide your TV model, but I believe Sharp only uses white LED backlight anyway, so please choose LCD White LED IPS from the drop-down list. Do not touch sensor matrix as it is used to calibrate your meter with a spectroradiometer for increased accuracy whilst still maintaining a colorimeter's high speed and its ability to take very dark readings.
numen is offline
post #4789 of 8935 Old 11-06-2014, 11:23 AM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
Where do I find this check box? Thanks
carillon is offline
post #4790 of 8935 Old 11-06-2014, 11:23 AM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
It is a Sharp Aquos LC-52LE700UN. Thanks
carillon is offline
post #4791 of 8935 Old 11-06-2014, 11:35 AM
numen's Avatar
Quoted: 49 Post(s)
Yes, this one uses a white LED backlight.
numen is offline
post #4792 of 8935 Old 11-06-2014, 02:45 PM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
Thanks! I'm going to attempt a run. We'll see how it goes.
Okay, first question... sorry but I'm really new with HCFR. I'm using the GCD disk, should I use 10% Windows with or without APL? I also set it for 75%/75% in HCFR so I'm planning on using those patterns in GCD when running the colors.
carillon is offline
post #4793 of 8935 Old 11-06-2014, 03:17 PM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
Baby steps... I just did a grayscale run after setting the Contrast and Brightness visually using the clipping patterns on the GCD disk. Here are my results after adjusting the Lo and Hi settings for color temperature. Is this acceptable before moving on the colors? Thanks
carillon is offline
post #4794 of 8935 Old 11-06-2014, 04:05 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
wow, peak white is 242 cd/m^2 - maybe I'm completely wrong here, but that seems really bright.
post #4795 of 8935 Old 11-06-2014, 04:32 PM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
I'm calibrating it for a bright room. Using 70ftL as my contrast setting.
carillon is offline
post #4796 of 8935 Old 11-06-2014, 04:48 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
cool, I don't have enough experience to comment on that. Your delta Es look pretty good on the neutral axis, apart from peak white - I wonder if the brightness being that high has something to do with it (I remember something about how having peak white too high can introduce a pink tinge).
post #4797 of 8935 Old 11-06-2014, 04:52 PM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
I'm a rookie so I could be way off here. My situation is that I have a bright room and I need to calibrate for it. I'll bump it down to 60 ftL and see how the grayscale looks.
carillon is offline
post #4798 of 8935 Old 11-06-2014, 05:14 PM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
Here's my new grayscale at 60 ftL.
carillon is offline
post #4799 of 8935 Old 11-06-2014, 05:21 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Ok, so the brightness wasn't much of a problem (although be careful that it doesn't cause eye strain!).
looks like you've got a good starting point.
post #4800 of 8935 Old 11-06-2014, 05:45 PM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
So next up, I'll move to the colors. My TV has a CMS for all colors for Hue, Saturation and Value. I have some reading to do in order to figure out how to dial the colors in.
carillon is offline
Reply Display Calibration
