HCFR - Open source projector and display calibration software - Page 168 - AVS Forum
 93Likes
post #5011 of 5022 Old 12-14-2014, 09:50 PM
WPWoodJr's Avatar
Originally Posted by zoyd View Post
no, samsung calls 0-255 normal and 16-235 low
I'm confused. When I set my NVidia card to output RGB, then the F8500 HDMI level must be set to Low to show blackest blacks. When I set the card to output YCbCr, the HDMI level is grayed out at Normal, and blacks look the same as RGB with Low setting.
Doesn't this contradict what you said above?
Samsung PN60F8500, TiVo Roamio, ASRock Vision 3D HTPC, Chromecast
WPWoodJr is online now
post #5012 of 5022 Old 12-15-2014, 08:46 AM - Thread Starter
zoyd's Avatar
Quoted: 446 Post(s)
Liked: 425
no that means your video card is sending black at 16 and white at 235 over hdmi.
zoyd is online now
post #5013 of 5022 Old 12-15-2014, 09:05 AM
Liked: 0
I personally use the particular EODIS3 with all the HCFR (3.A single.6) computer software to calibrate my EPSON TW-9200 projector (5030UB). I??am through Germany and in a German born AV forum you will find a few reports this combination (EODIS3 as well as HCFR) leads to the color red will be measured to be able to lower which this kind of brings about a reddish photo.
aboveave is offline
post #5014 of 5022 Old 12-15-2014, 12:33 PM
WPWoodJr's Avatar
Let me see if I get what the implications are.
The PC is an RGB (0-225) device. When using RGB over HDMI, it must be mapping 0-255 to 16-235 before sending, losing color resolution. This would not affect Blue Ray video (from the PC) which is already only using 16-235, but the Blue Ray player must map 16-235 to 0-255? The loss of color resolution would possibly be visible with photographs or other static content as banding or something.
When using YCbCr over HDMI, the PC is again mapping 0-255 to 16-235, with same implications as above.
Is that correct? BTW I couldn't detect a significant difference in HCFR between the two settings (RGB/Low vs YCbCr/Normal).
post #5015 of 5022 Old 12-15-2014, 03:28 PM
gwgill's Avatar
Quoted: 102 Post(s)
Liked: 88
That will happen if you are not using an appropriate calibration for your display type. I could locate no credible reports of ArgyllCMS/HCFR id13 measurements being less accurate than with any other software. If anyone has a reproducible example of such a thing, then they should bring it forward.
gwgill is offline
post #5016 of 5022 Old Yesterday, 09:13 AM - Thread Starter
zoyd's Avatar
Quoted: 446 Post(s)
Liked: 425
Some video cards scale everything over HDMI to video levels 16-235 so the rendering software (MPC etc.) will have to expand blu-ray to 0-255 first to end up with correct output this way. A better situation is to force the video card to leave the levels alone when outputting RGB over HDMI, that way if you choose to render at video levels or full RGB there will be no scaling in the video card and no possibility of banding. This is the preferred HTPC set-up.
If you set the card to output YCC it will also scale everything to video levels with the possibility of banding.
My preferred calibration set-up is HCFR 16-235 + video card passthrough (0-255) + display set to RGB limited (low).
WPWoodJr likes this.
zoyd is online now
post #5017 of 5022 Old Today, 09:57 AM
trp3383's Avatar
Quoted: 24 Post(s)
Hey, can't get my saturation's any better on my 64f8500.
Using oppo-103d set to 4:4:4
GDC disk with 10% APL and hcfr set to 75/75
Cell 17
Contrast 95
Brightness 49
Sharp 6
color 59
The last pic shows saturation sweep using 100/100 and Primary's and secondary's using 75/75.
Anything I can do to improve it? Thanks
ID:	427498   Click image for larger version
ID:	427506   Click image for larger version
ID:	427530   Click image for larger version
ID:	427538   Click image for larger version
trp3383 is online now
post #5018 of 5022 Old Today, 10:29 AM
LastButNotLeast's Avatar
Quoted: 316 Post(s)
Liked: 293
It looks great. If you're worried about the numbers, you need to run everything with preferences back to 100%/100%.
Just expect your numbers at 100% to be worse than your numbers at 75% (which is fine).
Downloadable FREE demo discs:
http://www.avsforum.com/t/1475769/de...ently-authored
Did you really need to quote that entire post in your reply?
LastButNotLeast is offline
post #5019 of 5022 Old Today, 12:22 PM
Quoted: 316 Post(s)
Liked: 293
Until midnight today:
http://www.bhphotovideo.com/c/produc...splay_Pro.html
i1Pro $129 AR.
post #5020 of 5022 Old Today, 12:51 PM - Thread Starter
zoyd's Avatar
Quoted: 446 Post(s)
Liked: 425
Looks darn good to me. How are the two skin tones on the color checker patterns and overall average? If they are a little hot you might back off the color control a couple of clicks and/or play with the flesh tone setting to tweak those (mine ended up at +3).
zoyd is online now
post #5021 of 5022 Old Today, 03:27 PM
xvfx's Avatar
Quoted: 121 Post(s)
Liked: 87
Does such a set exist where 75/75 lines up with 100/100 Luminance values? I've always noticed quite a bit of variation but 75/75 looks just a smidge too saturated. More so with Big Trouble in Little China at the start. 100/100 rectifies glowing skin tones around Kurt Russell's neck and the dog's hair looks natural ginger.
xvfx is online now
post #5022 of 5022 Old Today, 06:34 PM
WPWoodJr's Avatar
I'm narrowing in on a good calibration. All dE's under 3 (not under 2 yet like Zoyd ).
Chris Mathews is hard to get right but I like what I'm seeing. I've done my best to photograph it but it's not easy to get a photo that matches what I'm seeing onscreen.
Reply Display Calibration
