HCFR - Open source projector and display calibration software - Page 175 - AVS Forum | Home Theater Discussions And Reviews
 956Likes
post #5221 of 9132 Old 01-13-2015, 11:26 AM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Originally Posted by HDTVChallenged View Post
Historically, most folks have targeted gamma at 2.2(ish) for flat panels (including plasmas.) Due to the "superior" black level performance of plasmas, the BT1886 EOTF is often closer to a "gamma" of 2.3 to 2.4 (on average,) which makes the display look "darker" than one may be accustomed ... plus the editing and color grading was almost certainly performed on a display set to gamma 2.2(ish) ... and free from ABL issues. So, these issues often combine to make BT1886 on plasma look darker and "crushier" than desired.
Plus the superior black levels get crushed if there is any light at all in the room, which is why I'm considering calibrating at a relatively high level around 0.04 or so.
Samsung PN60F8500, TiVo Roamio, ASRock Vision 3D HTPC, Chromecast
WPWoodJr is offline
post #5222 of 9132 Old 01-13-2015, 02:44 PM
clenathan's Avatar
Hey guys. First time calibrating. Samsung f8500 60", i1 display pro only 2 weeks old, hcfr. bt.1886, 0 effective, 100% input offset, ref gamma 2.22. Started with contrast and brightness controls then did a 10 point greyscale and prim and secondary color calibration. Any input as to how my results look would be appreciated. Happy with PQ but want to make sure I'm not missing anything.
clenathan is offline
post #5223 of 9132 Old 01-13-2015, 02:51 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Originally Posted by WPWoodJr View Post
HCFR is rounding to integer levels between reference black (16) and reference white (235) for 5%, 10%, etc stimulus values.
For example 5% is really 5.02% in HCFR.
@zoyd , should HCFR be doing a two-step rounding for % White instead of one-step? First map 0-100% to PC RGB space (0-255), then map that to 16-235? From attached see difference at 35%, 65%, 70%, and 90%.
WPWoodJr is offline
post #5224 of 9132 Old 01-13-2015, 04:48 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Looks good so far! Might want to tweak 70% and 80% gamma. Also check your avg/max dE on the primaries and secondaries to be sure luminance isn't too high.
Head on over to the calibration thread.
WPWoodJr is offline
post #5225 of 9132 Old 01-13-2015, 05:20 PM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
No, the quantization is based on the assumption that the disk patterns use video level encoding.
zoyd is offline
post #5226 of 9132 Old 01-13-2015, 09:14 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Right, but when View Images is used as the generator, and Display Images Parameters is set to Gray Scale (GDI) 0-255 (instead of 16-235), there would seem to be two quantizations happening...
  1. Image is displayed by HCFR using quantized integer values from 0-255
  2. Values from 0-255 are quantized to 16-235 either by the graphics card or the TV depending on configuration
Am I missing something?
WPWoodJr is offline
post #5227 of 9132 Old 01-14-2015, 12:25 AM
HDTVChallenged's Avatar
Liked: 215
That would be an "incorrect" configuration. Specifically, in this case, the graphics card (or TV) should be set for 0-255. (This is one of the reasons I have no interest in HTPCs. Too much can "go wrong." )
xvfx likes this.
HDTVChallenged is offline
post #5228 of 9132 Old 01-14-2015, 03:55 AM - Thread Starter
zoyd's Avatar
Liked: 1064
Nope, I didn't realize you were referring to the internal pattern generator set to 0-255. In that case you are correct although the practical implications are negligible [see this post]. If you still want to avoid this situation then stick to video level output or use madTPG which will dither full range to the correct video level percentage.
zoyd is offline
post #5229 of 9132 Old 01-14-2015, 12:45 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Thanks. You don't think that the resulting HCFR target luminance gamma error is significant when the internal pattern generator is set to 0-255?
WPWoodJr is offline
post #5230 of 9132 Old 01-14-2015, 01:15 PM - Thread Starter
zoyd's Avatar
Liked: 1064
no, the perceptual errors induced (assuming you can even control and have the stability to maintain sub 0.5-1 cd/m^2 luminance for those 4 levels) are on the order of 0.2 dE or less and negligible.
zoyd is offline
post #5231 of 9132 Old 01-15-2015, 11:32 AM
WPWoodJr's Avatar
Quoted: 97 Post(s)
How hard is this to "fix" in HCFR? I guess I agree that it's not a big issue, however it still seems like something worth getting right...
I can't figure out how to turn dE2000 on for gray scale measurements in HCFR. Is that possible, or not recommended, or...
WPWoodJr is offline
post #5232 of 9132 Old 01-16-2015, 08:10 AM
fotto's Avatar
Quoted: 21 Post(s)
Feedback on cal
Hi All,
I have made two passes now adjusting grayscale on my Samsung UN60H6350 and hoping to get some feedback/advice. The second run I did (posted here) where I intended to start from ground floor up, used my first 10 point settings (I forgot to reset those) so I'm planning a third run with everything reset.
Anyway, I think I got pretty good results (to my untrained eye) but have a couple of questions regarding the Gamma graph and measures:
1) On both runs, I see that I am below target on Gamma between 20-80 IRE. Assuming the goal is to match this to the target, do I adjust RGB equally up or down to hit target curve?
2) On both runs, I am nowhere close to hitting the target gamma slope from 10-20 IRE that BT.1886 wants. I have had to lower my blue at 10 IRE down to close to the lower limit in my set's settings to get decent RBG levels at that point, so trying to lower all three to hit the curve may be problematic.
These may be simple questions but I'm still learning and couldn't find a post answering this.
I've attached my measurement file if needed for additional review.
fotto is offline
post #5233 of 9132 Old 01-16-2015, 08:25 AM
superkyle's Avatar
Quoted: 605 Post(s)
Liked: 256
@zoyd I am currently using the i1 pro to profile my i1d3. I am trying to calibrate the new P series vizio tv. the P702ui-B3 to be exact. I have a couple question that maybe you or someone else can help me with. I read through the thread trying to figure out the process that was used to modify the .ini file to allow the i1pro to work with HCFR build version 3.1.6 on windows 8.1. Can you help me figure out what is needed? Also I while back I started the official calibration forum for the P series. One of the questions asked by me and others is which tv type should I select. We have currently been using RGB LED. Im thinking now (after seeing it was told to another user) it might be best to Use white LED IPS . The panel type used in my set is a sharp VA type so not IPS but the two seem closest to the correct type. I just want to make sure I am doing everything correct in order to achieve the best/most accurate picture possible
superkyle is offline
post #5234 of 9132 Old 01-16-2015, 08:36 AM - Thread Starter
zoyd's Avatar
Liked: 1064
Hi All,
Increase RGB to lower gamma and vice-versa.
see above and you can play with the 2 point RGB controls to get more head room.
I'm not aware of any ini file editing needed, remove any xrite drivers and replace with driver found in HCFR "drivers" directory.
Perhaps with your i1pro you can provide some feedback on which display type is a better match.
zoyd is offline
post #5235 of 9132 Old 01-16-2015, 08:44 AM
superkyle's Avatar
Quoted: 605 Post(s)
Liked: 256
Thank you for your help I got it working perfectly now. Thus may be a dumb question and I will be happy to report back my findings but how exactly do I tell which display type is a better match?
post #5236 of 9132 Old 01-16-2015, 08:56 AM - Thread Starter
zoyd's Avatar
Liked: 1064
1. Profile the D3 to the i1pro using generic display type "non-refresh" and measure the grayscale using that matrix.
2. Remeasure the grayscale using display type "RGB LED" [or others] and without the matrix correction.
3. Find the display type that best matches measurements from step 1.
zoyd is offline
post #5237 of 9132 Old 01-16-2015, 10:21 AM
superkyle's Avatar
Quoted: 605 Post(s)
Liked: 256
Ok I will do that as soon as I can and report back with what I find out. I do just want to clear a few things up for myself. Basically the tv type is to auto applie a correction matrix to the colorimeter correct? So naturally the type that fits the gamma curve the best is the one for people who are not using a method of profiling. With that said for those of us using a method of profiling the tv type should always be non refresh. Is that correct?
Also when you are performing the profiling the be used you should always do this on non refresh no matter what? Sorry for the questions just want to make sure I do this correctly before I inform anyone else of the correct method.
post #5238 of 9132 Old 01-16-2015, 03:55 PM
meta22ica240's Avatar
Quoted: 45 Post(s)
Liked: 26
Trying to find someone in my area
Help with calibration
Anyone?
meta22ica240 is offline
post #5239 of 9132 Old 01-17-2015, 07:29 AM - Thread Starter
zoyd's Avatar
Liked: 1064
Display type forms a correction matrix based on a color correction sample set (ccss) combined with the probe's internal error offset data.
yes, it would be useful for people with your display that do not own a spectrometer. Is there a display type that is clearly a better fit (according to the i1pro). But you should see which gives the lowest dE errors for the grayscale (not gamma) by using the i1pro based matrix dataset as reference and looking at the dE/ref line in grid display.
You don't have to but that's easier to remember and creates a more portable matrix. non-refresh/refresh are equivalent to CalMAN's rawXYZ.
zoyd is offline
post #5240 of 9132 Old 01-17-2015, 07:34 AM
MSL_DK's Avatar
Quoted: 20 Post(s)
I am so damn grateful for HCFR and thanks to Zoyd
Originally Posted by LastButNotLeast View Post
Looks good to me, too. Don't forget that, calibrating at 75%, the primary and secondary colors chart is meaningless, since that's at 100%.
How does it look with real-world material?
Samsung PN60F5300 calibration settings?
This calibration was performed at 100%
I have not had time to 75/75 before now. Here is the result. Happy, or?
Panasonic TX-55CX700E - Dynaudio Focus 200 XD
MSL_DK is offline
post #5241 of 9132 Old 01-17-2015, 07:51 AM
WPWoodJr's Avatar
Quoted: 97 Post(s)
I think my analysis here was flawed and HCFR is fine:
  1. HCFR calculates target BT.1886 luminance values based off a quantization from percentage luminance (0, 5, 10% etc) to video (16-235).
  2. Then HCFR quantizes video 16-235 back to PC RGB 0-255 when displaying the patches
  3. Then either the graphics card or the TV quantize that back to video 16-235.
Fortuitously step 3 results in the same values between 16-235 as step 1, assuming rounding is used in the quantization.
Anyway a new version of Nvidia drivers is out which will let me send 0-255 over HDMI so to avoid all this I'm going to follow Zoyd's advice and use that setting along with the 16-235 setting in HCFR .
Sorry for the FUD!
WPWoodJr is offline
post #5242 of 9132 Old 01-17-2015, 08:22 PM
MrGoomba's Avatar
Quoted: 238 Post(s)
Liked: 45
my work
Ok, decided to do my 3rd calibration. This time, aiming for that 35 or so ftl for a night mode. Because its night, I also did a bt. 1886 @ 2.4 effective 50% offsent. Uploaded my work. few questions below. TV is a 60f8500
1- anyone have any suggestions based on screenshots?
2- How can I get closer to a 0% lumanance on the cms?
3- Where do I find patterns to measure the flesh tone? I know zoyd mentioned he turned his up to 3
Tomorrow I will be doing 2 more calibarations for movie and cal day. I want to do one at standard bt. 1886 and also one with effective of 2.2 at 50% offset. I have NO IDEA what gamma I will like or should use so I will just do these three.
MrGoomba is offline
post #5243 of 9132 Old 01-18-2015, 08:59 AM
LastButNotLeast's Avatar
Quoted: 1735 Post(s)
Liked: 1339
The numbers look great (though you might want to try a calibration at 75%/75% ).
How does it look?
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #5244 of 9132 Old 01-18-2015, 09:08 AM
MrGoomba's Avatar
Quoted: 238 Post(s)
Liked: 45
How does it look?
I did 75/75 and had red as my max at about 1.6, the rest below 1. Then did my 100% with red at 3.8 and rest at or below 2. Still need some tweaks.
Looks good but I need to play around with other gamma curves as I really don't have a preference.
How do I lower the luminance percent for colors?
MrGoomba is offline
post #5245 of 9132 Old 01-18-2015, 10:11 AM - Thread Starter
zoyd's Avatar
Liked: 1064
skin tones are available from the internal pattern generator under CCSG, which includes both skin tones and other memory colors, and the SKIN selection (24 pantone skin colors). Or you can use Ted's disk with the CCSG selection.
ConnecTEDDD likes this.
zoyd is offline
post #5246 of 9132 Old 01-18-2015, 10:18 AM - Thread Starter
zoyd's Avatar
Liked: 1064
Looks real good, I don't see any problems. Best way to compare two different calibrations is run the CCSG and look at the statistics - average, max, worst 10%.
zoyd is offline
post #5247 of 9132 Old 01-18-2015, 01:35 PM
MrGoomba's Avatar
Quoted: 238 Post(s)
Liked: 45
Really frustrating... Had a good calibration going and just fine tuning greys and TV menu froze. Had to turn off and on TV now when I run my measures, I'm wayyyy off. If it is calibrated correct, then each time I open hcfr my numbers should be similar, right?
MrGoomba is offline
post #5248 of 9132 Old 01-18-2015, 04:08 PM
ConnecTEDDD's Avatar
Quoted: 1534 Post(s)
Liked: 1978
Hi, if you want to use Ted's blu-ray calibration disk (or media files) with HCFR, you can use the CalMAN's ColorChecker SG Chapter that has 96 patches to measure, 19 of them are Skintones patches.
You need to use HCFR 3.1.1 or later release where Zoyd added CalMAN's ColorChecker SG measurements support; that made my disk the only available calibration disk with that feature, you can confirm that by checking the HCFR's Release Notes here.
If you want to see which other measurements are supported, look here: Ted's LightSpace CMS Calibration Disk
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #5249 of 9132 Old 01-19-2015, 03:39 AM
Touche's Avatar
I've tried searching through the thread and reading as much of it as I can, but I'm still struggling with some details...
1. REC.709-75% is set in preferences. That means that HCFR automatically displays color patterns @ 75A/75S? How is Pattern Intensity in Generator properties related to this? Should I leave it at 100 or change it to 75 when using REC.709-75%?
2. When I enter my gamma measured luminance in GCD_targets_v13.xlsx, the calculated xy for RGB is different than what HCFR calculates in CIE chart. E.g. HCFR shows 0.568/0.330 for Red@75%, but the spreadsheet shows 0.547/0.330 for 75/75. Which is correct?
3. How to manually display e.g. Red@75/75 pattern in HCFR?
Thank you!
Touche is offline
post #5250 of 9132 Old 01-19-2015, 05:49 AM - Thread Starter
zoyd's Avatar
Liked: 1064
assuming the TV settings didn't change then yes, measurements will be similar.
Leave at 100, the intensity setting is used to change luminance for 100% saturation patterns.
HCFR
RGBCYM at 75/75 can be displayed if you select that color space, run a sweep, select the color from the grid column, and then hit the snapshot or continuous measure arrow.
Touche likes this.
zoyd is offline
Reply Display Calibration
