HCFR - Open source projector and display calibration software - Page 179 - AVS | Home Theater Discussions And Reviews
 128Likes
post #5341 of 5351 Old Today, 10:01 AM
panman40's Avatar
I have a question please, a friend is trying to use HCFR with a retail version i1D3 meter on windows 7 platform, he gets the error 'cannot initialise' . The links to the drivers do not work, any ideas please ?,
panman40 is online now
post #5342 of 5351 Old Today, 10:05 AM
vega509's Avatar
Quoted: 79 Post(s)
Liked: 40
you do not need any drivers for the d3. be sure the diffuser is not in front of the lens on the meter.
vega509 is online now
post #5343 of 5351 Old Today, 10:07 AM
panman40's Avatar
The diffuser was not on, hcfr just will not see the meter and initialise.
post #5344 of 5351 Old Today, 11:12 AM
vega509's Avatar
Quoted: 79 Post(s)
Liked: 40
uninstall the x-rite driver, you do not need it for windows or hcfr.
post #5345 of 5351 Old Today, 12:17 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 888
Originally Posted by WPWoodJr View Post
I can rent a ColorMunki spectro for $60 with shipping. Is it worth doing this to calibrate my i1D3? Or am I just chasing perfection? I have a Samsung PN60F8500, and am using the Plasma EDR setting in HCFR.
You can actually find outfits that will rent a ColorMunki for a little over half that price for 3 days.
The other thing you can do is find an owner with your same TV and same meter (iD3) and a spectro and have them share their profile file with you.
I started this way and got a 1 - 1.5 dE change versus the standard White LED/LCD profile.
Down the road I'll be getting my hands on a spectro for a couple days to run my own profile, but I suspect the conclusion is likely to be that any profile of the same TV on the same meter is likely to get you 90% of the way to what a direct profile provides (at least for similar-age panels and meters).
A year from now I'm probably going to repeat the same exercise in the hopes of being in a position to rank the impact of these four factors:
A/ specific profile for your meter type on your TV type versus stock generic profile (ie:white LED/LCD)
B/ pre-calibration profile of your meter on your TV versus specific profile for your meter type on your TV type (shared TV-and-meter-specific profile).
C/ pre-calibration profile of your meter on your TV versus year-old profile of same meter on same TV (meter and TV drift).
D/ pre-calibration profile of your meter on your TV versus specific profile of similar-age same meter type on similar-age same TV type (panel-to-panel and meter-to-meter variation over time).
fafrd is online now
post #5346 of 5351 Old Today, 12:31 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 888
I'm now using the generator on HCFR and it has made such a difference in how efficient and effective my calibrations are, I'm really amazed at how powerful this program is.
I have one little nit and I'm hoping there is a small further improvement I can make.
I find the entire gamma settings section confusing. I'm generally using power law gamma of 2.4 or 2.2 because I at least understand how the reference is being defined.
I am actually calibrating my gamma to BT.1886 and I am doing this by hand using the spreadsheet that is floating around to determine specific 21-pt levels based on 100% peak white level and 0% black level.
So this means I am totally ignoring greyscale luminance errors in HCFR.
I would like to use the BT.1886 setting in HCFR but I find it confusing and don't understand how to align it to the spreadsheet-driven luminance levels I am using.
The spreadsheet is based on 100% luminance and 0% luminance and I am fine with having HCFR base 100% based on the measured value but don't understand how to input the 0% value in the way I would like.
I would like the BT.1886 values to be based on 0% levels of 0.001 or 0.002 cd/m2 and don't want to rely on an imprecise near-zero meter reading for that input.
Is there a way to configure the BT.1886 setting in HCFR so that the gamma curve is based on measured 100% luminance and manually-input effective 0% level?
fafrd is online now
post #5347 of 5351 Old Today, 12:44 PM - Thread Starter
Quoted: 523 Post(s)
Liked: 476
I'll probably add a manual black level for the next update but for now you can do it this way on the grayscale measures page:
1. uncheck XYZ adjustments if checked in the parameters window
2. check editable data
3. enter black level Y for 0% level
4. recheck XYZ adjustments if you unchecked it in step 1
I'm also open to suggestions for a better layout to the gamma reference page, often times what makes sense to me doesn't translate well to others.
zoyd is offline
post #5348 of 5351 Old Today, 03:30 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 888
Thanks - I'll give this a try. So by getting 0% grey manually set to the level I want, I understand I'll have the correct drivers for a standard BT.1886 gamma, but what do I do with the 'Effective', '% input offset' 'Reference Gamma' and 'Average Gamma' entry fields on the Preferences page once 'ITU-R BT.1886 has been selected? Are these all ignored and if not, how should they be configured for a standard BT.1886 gamma based on 0% black level, 100% white level, and power law gamma factor as used by the 'BT1886CalcV3' calculation spreadsheet?
Also, in case anyone on the thread knows, is a power law gamma factor of 2.4 or 2.35 generally considered the best for dark-room viewing calibration?
fafrd is online now
post #5349 of 5351 Old Today, 04:13 PM - Thread Starter
Quoted: 523 Post(s)
Liked: 476
The default values of 0 for effective gamma and 100% input offset gives you a standard BT.1886 target based on your 0% and 100% readings.
zoyd is offline
post #5350 of 5351 Old Today, 06:40 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 888
Great - thanks.
And should 'Reference Gamma' and/or 'Average Gamma' be set to 2.4 if I want to calculate BT.1886 based on a gamma of 2.4, or are those settings ignored because that is the default?
fafrd is online now
post #5351 of 5351 Unread Today, 11:20 PM
panman40's Avatar
Following this below from the maual when you click on the link in the folder nothing happens...
The USB drivers must be already on your computer. If you downloaded and installed the HCFR Colorimeter software before, you should find the USB drivers in the folder Pilote_USB under the installation folder of the software.
Reply Display Calibration
