HCFR - Open source projector and display calibration software - Page 191 - AVS | Home Theater Discussions And Reviews
 192Likes
post #5701 of 5714 Old 03-27-2015, 09:08 AM
molfious's Avatar
Quoted: 28 Post(s)
Originally Posted by LastButNotLeast View Post
It's built into HCFR; the computer generates the images on the display, which works for those of us using HTPCs as our primary source. If your source is your BDP, you are better sending the images from that device.
I think I'll give that a try this weekend. I suppose I need to have my HTPC setup as a dual display device for this; one for the calibration software and one for the images?
Do you use a specific pixel format for the pattern generation? 4:4:4 or 4:2:2? I believe the F8500 is nattively 4:2:2 so that may be best. My assumption is you don't want to use RGB Full or Limited as the color processing would be done on the video card then.
molfious is online now
post #5702 of 5714 Old 03-27-2015, 11:33 AM
LastButNotLeast's Avatar
Quoted: 539 Post(s)
Liked: 407
I just use one display, set up as it normally is when I watch anything.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #5703 of 5714 Old 03-27-2015, 12:04 PM
molfious's Avatar
Quoted: 28 Post(s)
Thanks for all the help and suggestions you guys are making the learning curve a lot easier!
post #5704 of 5714 Old 03-27-2015, 01:08 PM
cprawks's Avatar
Quoted: 34 Post(s)
Liked: 2
Hi, I have a Vizio P602ui-B3. Has anyone calibrated their screen, using HCFR?
cprawks is offline
post #5705 of 5714 Unread 03-27-2015, 06:28 PM
Liked: 0
I been searching the web for days now, but al information looks outdated. I have a Datacolor Spyder Pro/Elite but I cant get it to work. Can someone make me a step by step walkthrough?
Dirkjan de Hert is offline
post #5706 of 5714 Unread Yesterday, 10:20 PM
jhughy2010's Avatar
Quoted: 406 Post(s)
Liked: 117
Try the dedicated thread. I'm sure someone has... if not then "most" Vizio settings are the same on the various models and I'm sure their is someone that can give you pointers for general calibration.
You cannot get it to work with HCFR?
Gear: Pioneer VSX-1124-K, NHT Classic Three (L/R), Classic Two (rear) TwoC (center).
PSA V1500 (x2)
HTPC/server (MB3), Fire TV Stick, Chromecast
OTA Winegard HD7698P
Sharp LC-60SQ15U (HCFR calibrated)
jhughy2010 is online now
post #5707 of 5714 Unread Today, 10:03 AM
Basstrix's Avatar
Quoted: 36 Post(s)
Yes, you'll be doing yourself a huge favor by setting up the internal generator. Once you're set up to match your BD player's output, you are good to go. You'll want to use RGB full from the PC with raw output and set the generator to 16-235. I also suggest saving the MPEG version of the GCD disk and getting a player that will also match up with your BD for occasional non-HCFR generated patterns. I've found VCL Media Player to work well for this purpose.
In addition to pure convenience and efficiency, you'll be able to customize the number of divisions in a sweep (such as for saturation tracking).
Many of us have found that we are unable to match up the CIE at 100% color/luminance (or that 100% does not look good for various reasons) and opt for the 75% color space. The 75% space is, in essence, making the most out of a particular display's capabilities. Sweeping saturation over 8-10 points is taking this concept 1 step beyond. Combining the multi-point sat sweeps with color check patterns (and optimizing dE on color check) has provided me with the best picture on display's I've calibrated. (Thanks again, user nulsul!)
Once HCFR is generating patterns you can literally collect a 90 pt sweep (66 pt sat sweep + 24pt color check) while you take a short break. You're back and it's done. You can, for instance, make one adjustment to your gamma settings, and take a sweep in just a few seconds. This is particularly helpful when one point on the curve affects the point ahead and behind the point you're adjusting.
jhughy2010 likes this.
Vizio M652i-B2....................HCFR 3.1.6
Vizio E600i-B3.....................i1 Display Pro
Sharp LC-70C8470U............ControlCAL Elite X5 Edition v2
Onkyo TX-SR606.................AVSHD-709
PS-3
Homegrown HTPC
Basstrix is online now
post #5708 of 5714 Unread Today, 12:57 PM
Liked: 0
I have a Spyder4Pro and got it working by not installing the software that came with the device. Then let Windows find it as new hardware, then select choose a location. That location would be in HCFR drivers folder, then it will become a meter option in HCFR.
DisplayCalNoob is offline
post #5709 of 5714 Unread Today, 03:21 PM
molfious's Avatar
Quoted: 28 Post(s)
Thanks Basstrix, any reason I wouldn't use MKV over MPEG? Also, I seem to be having an issue with viewing the y target clearly. The window won't scroll all the way down and I can't seem to find a way to fix this. Anyone have an ideas?
post #5710 of 5714 Unread Today, 03:25 PM
ERuiz's Avatar
Quoted: 147 Post(s)
Liked: 39
Right next to the drop down box where you select the pattern you want to display, there are two up/down arrows. Use those arrows to expand the measurement boxes and you will be able to see the Y row clearly..
ERuiz is online now
post #5711 of 5714 Unread Today, 03:30 PM
molfious's Avatar
Quoted: 28 Post(s)
Thank god, couldn't figure that out for the life of me
post #5712 of 5714 Unread Today, 03:32 PM
Basstrix's Avatar
Quoted: 36 Post(s)
For some reason unknown to me, the MKV files are much harder to navigate from the video player. I've only tried 2 different players for the MKV, however, so your mileage may vary.
BTW, that should have read VLC media player in my prior post.
PS-3
Homegrown HTPC
post #5713 of 5714 Unread Today, 04:00 PM
molfious's Avatar
Quoted: 28 Post(s)
I typically use MPC-HC. I have already downloaded the MKV so probably won't get the MPEG file unless there is a compelling reason to do so.
post #5714 of 5714 Unread Today, 05:36 PM
Liked: 0
That's true for i1 sensors (i1Pro, i1Display, Colormunki etc.) as well. If you also want to be able to run the software that came with the device, you can have both drivers installed, and select the appropriate one depending on which software you want to run.
Dominic Chan is online now
Reply Display Calibration
