HCFR - Open source projector and display calibration software - Page 196 - AVS Forum | Home Theater Discussions And Reviews
 986Likes
post #5851 of 9354 Old 04-19-2015, 12:46 PM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
Originally Posted by xvfx View Post
Was that the same movie I saw you post a photo of with close up hand shots many months ago? With the same butterfly? That colour tone seems to have stuck in my memory…
yes that's the one. Those were photos though comparing the display calibration to a LUT calibration. The images in HCFR are pulled directly from the blu-ray disc.
Originally Posted by anta1974 View Post
Dear Zoyd!
Help me please.
ABL for panasonic plasma works from
1) level ARL
or
2) level APL?
You write about level >25% ARL work ABL plasma.
Level APL maybe another or < .... %level?
25% APL or 15% ARL will work just fine on any plasma as long as you keep the window size around 10% or below.
anta1974 likes this.
zoyd is offline
post #5852 of 9354 Old 04-19-2015, 01:29 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
if I use 15% ARL then background will 42% linear light, but perhaps it will not be much?
on plasma may already work ABL ?
Can be used safely 10% ARL ?
ABL depends on only APL or only ARL or APL and ARL???
anta1974 is offline
post #5853 of 9354 Old 04-19-2015, 01:59 PM - Thread Starter
zoyd's Avatar
Liked: 1064
Unless madshi has changed it 42% for linear light means 0.42^(2.2) = 0.18 or 18%.
It depends on total power load so either APL or ARL can be used as proxies.
zoyd is offline
post #5854 of 9354 Old 04-19-2015, 02:08 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
what should be the level APL not to cause ABL ?
<25% or <30% ?
anta1974 is offline
post #5855 of 9354 Old 04-19-2015, 02:27 PM - Thread Starter
zoyd's Avatar
Liked: 1064
<25% or <30% ?
More like <40% APL or <20% ARL although these can be higher for the F8500. You can easily measure APL effects using HCFR.
zoyd is offline
post #5856 of 9354 Old 04-19-2015, 08:52 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Hi, zoyd. I just downloaded a copy of 3.2.1. Terrific program! I'll probably get to it sometime in the next two weeks. It's time for my three month tune up on the 65VT60 with over 6,000 hours on it now.
One comment though. For the younger calibrators among us, you may want to include a test picture like this:
Just look at the realistic skin tones and color of tongue. The representation of the sky make one feel like being right there.
Larry
zoyd likes this.
LarryInRI is offline
post #5857 of 9354 Old 04-19-2015, 09:39 PM
Quoted: 29 Post(s)
Liked: 0
Originally Posted by zoyd View Post
For the display type files you will need the spyder4 install disk to use with oeminst, more detailed info here.
Thank you, that helped me a little bit. Unfortunately I still cant choose a calibration file in the HCFR start window.
Can I put the spyd4cal file manually in the correct destination? Currently its located at:
C:\Users\myusername\AppData\Roaming\ArgyllCMS
Or is it maybe my own misunderstanding that this file is not related to the Menu "external sensor calibration data" ?
Name:	20-04-2015 06-35-07.jpg
createch2 is offline
post #5858 of 9354 Old 04-20-2015, 12:53 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
1) How to measure ABL? Please tell me.
2) What different madTPG constant background and gamma light?
3) For example 8% area and 30% background in madTPG - count ARL:
- constant gray - ?
- gamma light - 0.3^2.2*0.92+(0 to 1)^2.2*0.08= 6.51%-14.51%
- linear light - 0.3^2.2 (area ignored?)=7.074%
anta1974 is offline
post #5859 of 9354 Old 04-20-2015, 03:14 AM - Thread Starter
zoyd's Avatar
Liked: 1064
yes, the probe specific corrections will be available in the Display Type selection on the next dialog. This is mentioned in the hint on the dialog screen shot. So choose "no external correction" and go to the next page.
Measure white Y vs. window area.
Example for 30%:
1. Constant background: Background = 30%
2. Gamma light = Constant APL: Background changes with window area/content so that APL=30%
2. Linear light = Constant ARL: Background changes with window area/content so that ARL = 0.3^2.2 = 7%
zoyd is offline
post #5860 of 9354 Old 04-20-2015, 04:01 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Then it turns out that my formula ARL is true for counting constant gray, but wrong for gamma light.
How to calculate ARL for gamma light?
APL=30% area=8%
ARL= ?
0.92*x+0.08*(0 to 1)=0.3
ARL=x^2.2*0.92+(0to1)^2.2*0.08
True?
anta1974 is offline
post #5861 of 9354 Old 04-20-2015, 07:02 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
When I use windows pattern for measure ABL APL=ARL
Why your level APL and ARL different?
anta1974 is offline
post #5862 of 9354 Old 04-20-2015, 07:12 AM - Thread Starter
zoyd's Avatar
Liked: 1064
APL=30% area=8%
ARL= ?
True?
yes, but x will have different values such that APL=30% and ARL=7% (0.3^2.2)
constant APL = 0.3 = 0.92 * x1 + 0.08 * y (ex. if y = 0.5, x1 = 0.283)
constant ARL = 0.3^2.2 = 0.07 = 0.92 * x2^2.2 + 0.08 * y^(2.2) (ex. if y = 0.5, x2 = 0.273)
zoyd is offline
post #5863 of 9354 Old 04-20-2015, 12:57 PM
Slower's Avatar
Quoted: 20 Post(s)
Liked: 1
Zoyd,
Outstanding job on the test patterns / evalution images! HCFR is getting better by the day!
With these new features there is hardly any need to use a BR player, either for test patterns, or for evaluation purposes. However, although I set up HCFR as a generator, I find myself using a BR player for 2 test patterns, which could (at least for me) turn HCFR into a full-featured calibration suite if you could add those to the test patterns:
1. Color clipping. As an addition to the RGBYCMW Luma Ramps (0-255), could a pattern like the one found on AVSHD (primaries), or GCD/MCD (primaries or secondaries) be added? So with emphasis on "near white"219-255, or 231-255.
2. Sharpness/overscan. I find the pattern on the AVSHD and MCD very useful because of the percentages shown (the one on DVE is also very nice, steps of 1%, comes in very handy working on CRT's geometry issues).
bmcn likes this.
Slower is offline
post #5864 of 9354 Old 04-21-2015, 12:50 AM
UnDecoded's Avatar
Hi!
Unlike most posters here I'm not really experienced in calibration so hopefully you can bear with my questions. I'd also like to take this opportunity to thank all the devs for creating such an easy to use software, even for a novice such as myself. It also works great, even in W10!
I started off running a measurement on my uncalibrated Eizo screen, not perfect by any means but it still looks pretty fair to me.
I did however run into a few problems (likely an user error) when I tried to calibrate the 8750ub. The biggest problem as I see it is that the gamma seems all over the place (not that the rgb tracking(?) is much better, but still).
My setup is, iirc: an i1d2 and I'm projecting my 8750ub on a white 1.0 gain screen hitting ~15ftL. The RGB sliders are pretty much maxed out getting these results (or I would get maybe 60% red from 50-100IRE. I'm also using the 10% 11-step patterns from the AVS HD 709 disc. The PJ is shelf mounted ~5 feet above the floor. I'm guessing I'm missing something fairly basic here. If there's anything else I need to add please let me know and I'll do my best.
Once again, many thanks!
UD
ID:	677153   Click image for larger version
ID:	677161   Click image for larger version
ID:	677169   Click image for larger version
UnDecoded is offline
post #5865 of 9354 Old 04-21-2015, 02:56 AM
BlueChris's Avatar
Quoted: 246 Post(s)
Liked: 113
@Zoid m8 sorry for asking if its obvius but i cannot find a stetting to choose in which monitor the Test Patterns will be shown.
thx
BlueChris is online now
post #5866 of 9354 Old 04-21-2015, 05:42 AM
Quoted: 1633 Post(s)
Liked: 415
Which preset mode did you select, prior to making the adjustments? The User Manual recommends using the Natural mode.
Dominic Chan is online now
post #5867 of 9354 Old 04-21-2015, 06:06 AM - Thread Starter
zoyd's Avatar
Liked: 1064
zoyd is offline
post #5868 of 9354 Old 04-21-2015, 06:14 AM
UnDecoded's Avatar
Hello and thank you for your reply Dominic!
I know I forgot something and you have a great point!
I used the living room mode (which I'm guessing is another variant of the dynamic mode...) as it was the only way I could push the ftL over 9. It might be a good idea doing some measurements in Natural and possibly shrink the image size instead (currently at 117 which going by the calculations may be pushing it").
Cheers
UD
post #5869 of 9354 Old 04-21-2015, 06:33 AM
Liked: 415
In the Living Room mode, if your cut down the Contrast before doing the calibration, you may still get more lumens than the other modes. If necessary, you can also aim for a slightly cooler temperature (e.g., D75).
It will be a compromise between colour accuracy and screen brightness.
post #5870 of 9354 Old 04-21-2015, 11:13 AM
BlueChris's Avatar
Quoted: 246 Post(s)
Liked: 113
I have a question since i don't know much but in my tryings to calibrate my lg55ub950v i had trouble to maintain 2.2 gamma with d65 as standard but with d75 the tv seemed more happy in corrections, can i proceed with that?
post #5871 of 9354 Old 04-21-2015, 12:01 PM
Liked: 415
The purists would probably say no. However, I would say you can quickly set the colour temperature to D75, and decide for yourself if it looks too "cool".
BlueChris likes this.
post #5872 of 9354 Old 04-21-2015, 03:00 PM - Thread Starter
zoyd's Avatar
Liked: 1064
Thanks for the feedback. I've updated the current version with the AVSHD sharpness/overscan pattern as well as two RGBYCMW clipping patterns, one for near black and one for near white. Also made changing patterns a little quicker by allowing the alt and ctrl keys to escape the current image.
Also added capability of displaying an image as measurement pattern background [click "Image background" in the GDI set-up]
Current hotkeys
Code:
    "CTRL+1",           Sharpness/Overscan
    "CTRL+2",           Clipping low
    "CTRL+3",           Clipping high
    "ALT+1",            Probe Alignment
    "ALT+2",            Neutral Gradient
    "ALT+3",            Luma Ramps
    "ALT+4",            Spectrum
    "ALT+5",            Light skin tone
    "ALT+6",            Dark skin tone
    "ALT+7",            Dark detail
    "ALT+8",            Granger rainbow
shpitz, anta1974, Zodduska and 3 others like this.
zoyd is offline
post #5873 of 9354 Old 04-21-2015, 03:51 PM
LastButNotLeast's Avatar
Quoted: 1804 Post(s)
Liked: 1416
No more downloading, I'm waiting for 3.3.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #5874 of 9354 Old 04-22-2015, 04:49 AM
Slower's Avatar
Quoted: 20 Post(s)
Liked: 1
Zoyd,
Thanks for these additions. Unfortunately I found out that the test patterns and evaluation images do not retain their 16:9 aspect ratio. They appear vertically stretched on my 16:10 screen. Not a problem with clipping patterns, but a bit annoying with overscan or geometry patterns and movie scenes.
Slower is offline
post #5875 of 9354 Old 04-22-2015, 05:13 AM - Thread Starter
zoyd's Avatar
Liked: 1064
Zoyd,
no problem, I can add a switch to prevent scaling.
zoyd is offline
post #5876 of 9354 Old 04-23-2015, 05:20 AM - Thread Starter
zoyd's Avatar
Liked: 1064
Current version has been updated to maintain aspect ratio for 16x9 pics when resized.
Note: This only accounts for resizing into whatever resolution the video card output is running at. If your display/projector does any additional scaling that changes the aspect ratio of the video output, I can't compensate for that.
shpitz, anta1974, s1andel and 1 others like this.
zoyd is offline
post #5877 of 9354 Old 04-23-2015, 12:17 PM
Slower's Avatar
Quoted: 20 Post(s)
Liked: 1
Zoyd,
I'm sorry to inform you that HCFR crashes when selecting a test pattern or evaluation image.
Slower is offline
post #5878 of 9354 Old 04-23-2015, 01:15 PM - Thread Starter
zoyd's Avatar
Liked: 1064
zoyd is offline
post #5879 of 9354 Old 04-23-2015, 01:33 PM
Slower's Avatar
Quoted: 20 Post(s)
Liked: 1
That's interesting, I haven't had any crashes here on a Win7 laptop display or with the TV as secondary display.
Running Vista on a 16:10 laptop. Previous versions have been stable, never had a crash. I'm assuming that it has something to do with this scaling I asked you about. Interestingly, some of the patterns do not lead to a crash: those are some of the patterns found under Additional Patters, e.g. Green Shading (stretched vertically) doesn't crash HCFR, Brightness and Contrast also don't crash. Most other do crash, as well as all the "new" patterns you added.
Slower is offline
post #5880 of 9354 Old 04-23-2015, 02:30 PM
Liked: 415
I am also getting a crash, with this version only. Windows 8.1 and Windows 10 Preview both behave the same way.
Reply Display Calibration
