HCFR - Open source projector and display calibration software - Page 199 - AVS Forum | Home Theater Discussions And Reviews
 915Likes
post #5941 of 8842 Old 05-20-2015, 05:28 PM
gwgill's Avatar
Quoted: 246 Post(s)
Liked: 183
Originally Posted by jubuttib View Post
These days there's no such thing as "installation disk". The box only has the unity, a serial for it, the warranty information, and a link to the page where you can download the Spyder5 software and quick start pdf guides.
Download the software install they refer to, onto your system somewhere, and then point oeminst at it.
jubuttib likes this.
gwgill is offline
post #5942 of 8842 Old 05-20-2015, 06:40 PM
Iceberg86300's Avatar
Quoted: 84 Post(s)
Liked: 54
If you install the software then plug in the probe windows should then grab drivers and "install" them. Basically just reads the inf file then drops the DLL into I forget where.
System or system 32 I think. Google it.
But first check the installation directory. Most installs these days place driver stores into the install directory. If they are there, and you don't want the software on your system then just copy the pertinent driver folder somewhere then uninstall.
Then point to the driver folder, wherever you decide to put it. I use a driver folder in the root, then place all my device drivers that aren't dependent on their own software into this folder.
Steve
Iceberg86300 is offline
post #5943 of 8842 Old 05-20-2015, 07:03 PM
Liked: 0
Thanks, that took care of it. You really are a super helpful bunch. =)
jubuttib is offline
post #5944 of 8842 Old 05-20-2015, 07:22 PM
Liked: 0
Oh yeah, forgot to mention: The 3.2.2 version I downloaded off of Sourceforge apparently didn't have the correct version of the Argyll CMS drivers included, when I was trying to switch the drivers it found nothing suitable in there. I downloaded ArgyllCMS 1.7.0 from the main Argyll website though and the driver in that worked fine.
jubuttib is offline
post #5945 of 8842 Old 05-21-2015, 08:37 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
zoyd is offline
post #5946 of 8842 Old 05-24-2015, 04:56 PM - Thread Starter
zoyd's Avatar
Liked: 1055
version 3.2.3 has been released.
  • Added support for dithered Chromecast patterns including constant APL backgrounds.
  • Added some additional color gradient patterns.
  • Updated instrument driver inf file with missing probes (Spyder 5).
zoyd is offline
post #5947 of 8842 Old 05-24-2015, 05:21 PM
LastButNotLeast's Avatar
Quoted: 1534 Post(s)
Liked: 1143
Originally Posted by LastButNotLeast View Post
No more downloading, I'm waiting for 3.3.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #5948 of 8842 Old 05-25-2015, 04:13 AM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
post #5949 of 8842 Old 05-25-2015, 05:44 AM
s1andel's Avatar
Liked: 1
i download but is hcfr 3.2.2 version no 3.2.3
s1andel is offline
post #5950 of 8842 Old 05-25-2015, 05:52 AM
rickardl's Avatar
Quoted: 107 Post(s)
Liked: 91
Originally Posted by zoyd View Post
What would you like to see in 3.3?
Use of the Plasma/HDTV(OPT) colorspace with images from DVD/USB stick.
rickardl is online now
post #5951 of 8842 Old 05-25-2015, 06:12 AM - Thread Starter
zoyd's Avatar
Liked: 1055
Who will create those patterns for you?
zoyd is offline
post #5952 of 8842 Old 05-25-2015, 06:25 AM
rickardl's Avatar
Quoted: 107 Post(s)
Liked: 91
Would something like this be ok?
post #5953 of 8842 Old 05-25-2015, 06:46 AM
Liked: 1143
The same thing you would: no more updates.
That would take all the fun out of it though, wouldn't it.
Honestly, the program already does more than I'm capable of understanding and has provided me with endless hours of (generally pleasant) entertainment and a fabulous picture, first on my RPCRT and now on my (second) Sammy plasma. I don't want to see it become bloatware (which, frankly, more "demo" pictures would cause, especially since there is plenty of demo material available elsewhere [not that I would suggest anyone check my sig or anything ]). Unless colorspace targets change, bug fixes and support for new/better meters are the only "features" I think the program needs.
But, hey, I'm just a guy who's happy with the program as it is since it already does more than I'm ever going to need.
Michael
post #5954 of 8842 Old 05-25-2015, 07:11 AM - Thread Starter
zoyd's Avatar
Liked: 1055
Sorry about that, correct version uploaded.
Yes, that would work. I'll enable that space for manual patterns.
rickardl and anta1974 like this.
zoyd is offline
post #5955 of 8842 Old 05-25-2015, 07:19 AM - Thread Starter
zoyd's Avatar
Liked: 1055
The demo frames are calibration specific but I do agree that more are not needed. I may added more specialty patterns in the future but those are small. What about a reporting feature? before/after PDF?
Andrei_VVB likes this.
zoyd is offline
post #5956 of 8842 Old 05-25-2015, 07:20 AM
s1andel's Avatar
Liked: 1
thanks zoyd for the version hcfr 3.2.3
s1andel is offline
post #5957 of 8842 Old 05-25-2015, 07:24 AM
rickardl's Avatar
Quoted: 107 Post(s)
Liked: 91
Tnx!
post #5958 of 8842 Old 05-25-2015, 07:39 AM
Liked: 1143
Competing with CalMan now, are we?
I certainly don't need it, since I'm not "reporting" to anyone but me and the "Reference measure" box works for that.
Okay, how about a "Check for updates" option?
Michael
post #5959 of 8842 Old 05-25-2015, 07:50 AM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
post #5960 of 8842 Old 05-25-2015, 09:23 AM
BlueChris's Avatar
Quoted: 215 Post(s)
Liked: 90
I would love a reporting because for example i upload here the hcfr session and is huge. ..i suppose a report in pdf or in html (the 2nd will be great for an online calibration results site that we can upload and everyone can see what others achieved with a specific tv model).
BlueChris is offline
post #5961 of 8842 Old 05-25-2015, 12:24 PM
xvfx's Avatar
Quoted: 409 Post(s)
Liked: 231
The possibility for built in drop downs for Ted's fine pattern disc? Rather than renaming the files all the time and losing results for the next long set of sweeps… and having to alt+prnt scrn a lot.
Though instead of screen prints, something along the lines of BlueChris would be extremely handy. Instead of trying to load old charts that might conflict with older versions made at that time trying to load it in newer versions?
ConnecTEDDD and bmcn like this.
xvfx is offline
post #5962 of 8842 Old 05-25-2015, 12:25 PM
PeterLewis's Avatar
Quoted: 136 Post(s)
Liked: 70
I would like to see a 4K color space added, I think its called DCI-P3 as this will be the new Ultra-HD blu-ray standard.
Sony OLED XBR-65A1E (Pre-Ordered)| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #5963 of 8842 Old 05-25-2015, 01:59 PM
Liked: 1143
But you never want to update!
Not never, just not constantly.
Getting good suggestions, though.
Bet you're sorry you asked!
post #5964 of 8842 Old 05-25-2015, 05:55 PM
Quoted: 132 Post(s)
Liked: 4
I would like to see a new, modern theme or even an entire GUI overhaul and NO, I would not be doing it because I don't know how . Can't some simple improvement be done? For example, increasing the resolution of button icons/images, HCFR.exe icon itself, etc?
Masharak is offline
post #5965 of 8842 Old 05-25-2015, 05:59 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
That would be nice.
Larry
LarryInRI is offline
post #5966 of 8842 Old 05-26-2015, 03:30 AM
JGrana's Avatar
Quoted: 47 Post(s)
Liked: 35
I would second the pull-down for Ted's patterns. Great disk to use with a great software product (HCFR)!
ConnecTEDDD likes this.
JGrana is offline
post #5967 of 8842 Old 05-26-2015, 07:00 AM
Liked: 1143
I don't recall seeing it, so here is the link to the article about the screen shots from Casino Royale:
http://www.homecinemaguru.com/checki...-your-display/
(and my original post about it:
Samsung PN60F5300 calibration settings?)
Michael
post #5968 of 8842 Old 05-26-2015, 10:03 AM - Thread Starter
zoyd's Avatar
Liked: 1055
Sounds like folks use Ted's sequences so I will make them easier to set-up. However, they will still be "one at a time" unless I add multiple color checker slots - which I might do. I'll have a look at reporting, HTML is probably more useful and one can always print a PDF from that.
I don't know how to do GUI design/programming either, although I could figure it out, but it's probably too much effort for no benefit since we aren't trying to sell it. Updating the help file and including a couple of walk-throughs would be much more useful to new users.
Thanks for reminding me to include that link in the first post - I did put it in the release announcement but that gets buried.
zoyd is offline
post #5969 of 8842 Old 05-26-2015, 02:49 PM
22point8's Avatar
Quoted: 141 Post(s)
Liked: 70
This, last time I went to the trouble of manually inputting the coordinates it crashed.
A 9300K colour temp could help for people who want to calibrate the 9300K presets on their monitors.
22point8 is offline
post #5970 of 8842 Old 05-27-2015, 09:18 AM
BlueChris's Avatar
Quoted: 215 Post(s)
Liked: 90
Can anyone help me or point me how to make a matrix from my i1 spectro to my i1d3
Reply Display Calibration
