HCFR - Open source projector and display calibration software - Page 235 - AVS Forum | Home Theater Discussions And Reviews
 925Likes
post #7021 of 8984 Old 01-22-2016, 09:37 AM
Quoted: 1370 Post(s)
Liked: 346
Originally Posted by Barsk View Post
Why not have a settings page where you select which values or color space to have visible and hide the rest. That would save some space too to make some information labels for the values that are displayed.
There is already a selection of colour space for the grid. Maybe the same selection can be applied to the Current Selection.
Dominic Chan is online now
post #7022 of 8984 Old 01-22-2016, 03:11 PM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Originally Posted by Dominic Chan View Post
I did not test the changes related to the update function (since none is currently available).
You can test the new update/install function now, I've uploaded a new build that should enable grid updates in all pages except contrast. I haven't tested it thoroughly yet.
zoyd is offline
post #7023 of 8984 Old 01-22-2016, 05:21 PM
Liked: 346
Thanks zoyd. The update/install function works quite well, except when there are unsaved runs, in which case the dialog box for saving the file may "compete for focus".
I haven't tried the new grid update feature on the machine that had problems with it. However, it seems to result in a lot of flickering of the whole screen, not just the column being updated (like before).
post #7024 of 8984 Old 01-23-2016, 07:37 AM - Thread Starter
zoyd's Avatar
Liked: 1055
New update available, fixes flickering during continuous measures and function hotkeys for standard sweep sequences.
zoyd is offline
post #7025 of 8984 Old 01-23-2016, 09:25 AM
Liked: 0
Hi,
I'm new to this forum and hope I put my question to the right forum.
I am trying to use the HCFR tool (3.3.9) in combination with a Spyder 5 sensor under Windows 10, but I have run into problems.
I have figured out, that I should replace the original driver with the Argyll driver, which is located in the HCFR Calibration\Drivers subdirectory. But when I point Windows to this location, I receive an error message (translated: "Found driver software for device Spyder5 (Argyll), but there was an error during installation. The hash value for the file in the catalog file was not found. The file is probably damaged or has been changed without authorization.")
Can anyone help me here?
baumfalk is offline
post #7026 of 8984 Old 01-23-2016, 09:42 AM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
post #7027 of 8984 Old 01-23-2016, 02:06 PM
Liked: 0
Thank you!
baumfalk is offline
post #7028 of 8984 Old 01-25-2016, 06:17 PM - Thread Starter
zoyd's Avatar
Liked: 1055
Update of 3.3.9 release 1/25/16
+ Added automatically generated sync patterns for Chromecast and GDI refresh mode calibration.
VBB and Barsk like this.
zoyd is offline
post #7029 of 8984 Old 01-25-2016, 08:10 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Scott,
I'm getting a 404 error from sourceforge when trying to download the newest 3.3.9 version. No problem with 3.3.8.
Larry
LarryInRI is offline
post #7030 of 8984 Old 01-25-2016, 09:10 PM
Liked: 346
You can get the latest by using the Update feature within HCFR (>3.3.6)
post #7031 of 8984 Old 01-25-2016, 09:16 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Thanks but I was only pointing out a download problem with the link that Scott uses for his updates.
Larry
post #7032 of 8984 Old 01-26-2016, 12:30 AM
Barsk's Avatar
Quoted: 36 Post(s)
Seems to work perfectly! I had great use of this functionality last night on my PJ that behaves very differently in different intensity levels in blue. So jumping back and forth between saturation pages and primaries/secondaries trying trying to find a compromise was much quicker now.
Haven't had time to test yet, but THANKS!
Great work Zoyd!
I had some random crashes though. I did not find any particular pattern to the cause, but if I do I'll come back.
Barsk is offline
post #7033 of 8984 Old 01-26-2016, 04:04 AM - Thread Starter
zoyd's Avatar
Liked: 1055
Scott,
Larry
Thanks Larry, reported to sourceforge. Use in-app download for the moment.
edit: looks like the sourceforge link is working again as of early this afternoon.
zoyd is offline
post #7034 of 8984 Old 01-26-2016, 10:34 AM - Thread Starter
zoyd's Avatar
Liked: 1055
Please do report anything that you can reproduce, it's very stable on my set-up.
zoyd is offline
post #7035 of 8984 Old 01-27-2016, 03:48 AM
Liked: 0
i1 Display Pro read and show x,y,Y in realtime?
Hello, I have a Sony G420 CRT monitor (and other flat panel monitors). The CRT has a large variety of fine internal adjustments that can be made with the proprietary Sony DAS (or WinDAS) program. Settings are made by moving sliders on a screen. However, with each test screen are instructions to "Adjust for x=0.313, y=0.329"---or other x,y,and Y values. The point is that I need to be able to know/ascertain the realtime x,y,Y levels on the display to make these slider adjustments. I’ve seen profiling software that will use your colorimeter (such as the “i1 Display Pro”) to show the current x,y,Y values, but with the stipulation that RGB are all at 255. Can anyone confirm to me if the “i1 Display Pro”, with appropriate software, will show <realtime> readings for x,y,Y—even at low IRE? This might determine if I will buy the Display Pro colorimeter in an auction which finishes in 45 minutes(?). I'm probably posting this too late to get a reply in time. But I think many of you veterans probably know the answer to this basic question. If the answer is "yes", is HCFR a software option that can show those realtime x,y,Y values (read from the Display Pro), at various light levels? If not, what software would do that? Thank you very much for your time!
John Greg is offline
post #7036 of 8984 Old 01-27-2016, 04:04 AM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
post #7037 of 8984 Old 01-27-2016, 04:22 AM
Liked: 0
That is wonderful news. Thank you, indeed. I appreciate it. In will go my bid. And I'll probably be back in a matter of days with more questions. --After doing my homework in this thread, of course!
post #7038 of 8984 Old 01-27-2016, 06:48 AM
LastButNotLeast's Avatar
Quoted: 1691 Post(s)
Liked: 1304
I would be cautious about any meter that has been used. Depending on how well it's been treated, it may no longer be accurate.
They go on sale here fairly often:
http://www.bhphotovideo.com/c/produc...splay_Pro.html
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #7039 of 8984 Old 01-27-2016, 10:39 AM
Liked: 346
There's seems to be a minor error in calculating the average gamma. It's low by about 0.01 when gamma=2.2, but there's no error when gamma=2.1.
post #7040 of 8984 Old 01-27-2016, 04:55 PM
Quoted: 821 Post(s)
Liked: 542
Been wandering if it would be beneficial to remove my AVR out the signal supply chain. I noticed an affect on grayscale accuracy that causes green push in shadows after calibration. I've also noticed this, if more than one device is on while connected to the AVR.
Are there drawbacks to removing anything out of your supply chain?
DisplayCalNoob is online now
post #7041 of 8984 Old 01-27-2016, 04:58 PM
Liked: 346
If your AVR is in the supply chain when you play the movies, then it should kept there when you calibrate.
post #7042 of 8984 Old 01-27-2016, 05:00 PM
Red_Dwarf's Avatar
Liked: 0
Thank you for the updates to HCFR. I am new to calibration and it's all a steep learning curve ATM. I have an i1Display Pro colorimeter and I am currently testing a W-LED VA panel and attempting to evaluate it's performance. however I am running into problems. I only have the one display so want to have the colours shown on the screen while seeing the results so I have the GDI (no background) selected which seems to accomplish this rather than having the screen go black with a colour patch in the centre of the screen.
I am getting problems when I begin a test such as primaries, grey scale or grey scale & colours. First it shows a black rectangle for quite some time, approx 8 seconds and then it can do two different things. It either proceeds and moves through the test correctly cycling through the different colours. However all too frequently after the black rectangle, it disappears but still updates the results reading the meter but not displaying the test colours and producing high dE errors as a result. It will also update the graphs if a graph tab is selected while misreading the meter data. I can press ESC to stop the test and retry but it can take many retries to get the colours to display and results to be read accurately.
Is there a cause to this?
Red_Dwarf is offline
post #7043 of 8984 Old 01-27-2016, 08:08 PM
Quoted: 821 Post(s)
Liked: 542
What bothers me is knowing that my avr hdmi in/out if tested may show it way off in limited or full range grayscale.
post #7044 of 8984 Old 01-27-2016, 09:37 PM
Liked: 346
The whole concept of "system level calibration" is to ensure end-to-end accuracy. Part of the system may not be working correctly on its own, but unless that part has its own calibration/adjustment, you will have to rely on the display calibration to compensate for it.
Yes, indeed it's a case of "two wrongs make a right".
post #7045 of 8984 Old 01-28-2016, 03:51 AM - Thread Starter
zoyd's Avatar
Liked: 1055
The darker the patch, the longer it takes the display pro to read it, 8 seconds is normal for black.
The pattern should stay in the foreground if you don't touch anything but trying to run the program on the same display as the fullscreen pattern is difficult. There is a detachable test color window that could be used instead which might make things a bit easier in this set-up but I'd have to add an option to turn off the full screen one. Alternatively you could use the madTPG generator which can be set to any window size.
zoyd is offline
post #7046 of 8984 Old 01-28-2016, 04:48 AM
Liked: 346
Wouldn't selecting the DVD/Manual Pattern Generator turn off the full screen window already? Of course one will have to select the columns one by one (which works well in the latest version).
post #7047 of 8984 Old 01-28-2016, 05:48 AM
Red_Dwarf's Avatar
Liked: 0
Thanks for answering that. However that is not really a problem, it was only a point of note about what is happening.
I don't want or need the test pattern on full screen pattern, what I want is the test colours displayed on top of the main window which sometimes it does but many times it does not.
I don't think HCFR is working the way it should. Sometimes the colour test rectangle shows on top of the View and Information windows how it should while doing a measure, but many times it does not show while testing. This is the problem.
I just tested it once more and it did it again. The View window flickers while it is updating the results but with no colour rectangle so that the dE is very high, 23 to 75. See attachment of a screenshot. First it shows the black rectangle in the centre of the screen and then it very briefly shows a grey rectangle and then the rectangle disappears. This is while doing a greyscale and colour measure test. Most of the test colours do not display. BTW i AM USING Win 7 SP1 x64
Is there any information that I can supply to help solve this? It looks like a bug to me because it is not behaving consistently, sometimes working and many times not working.
ID:	1215658   Click image for larger version
Last edited by Red_Dwarf; 01-28-2016 at 05:54 AM. Reason: Added another test image
post #7048 of 8984 Old 01-28-2016, 07:11 AM - Thread Starter
zoyd's Avatar
Liked: 1055
I can't reproduce this problem, the pattern never loses focus (foreground). Can you make the move the main program over to the side and see if the pattern is still displaying in the background? Some other program or windows desktop setting may be stealing focus. Also, what happens if you check GDI instead of GDI(no background), does the pattern consistently stay on top during the sweeps?
zoyd is offline
post #7049 of 8984 Old 01-28-2016, 08:08 AM
Liked: 346
I have 2-screen set-up, but I still have to open the Test Color window and drag it to the screen-under-test; that is the only way to get the Test Pattern window to display full screen. In doing so, I do notice that sometimes the Test Color window would unexpectedly show "on top" of the Test Pattern window, even though most of the time the Test Pattern window has the focus.
Unfortunately it's one of those things that cannot be repeated consistently.
[EDIT: Perhaps I should turn off the option "Display test color during measures"]
post #7050 of 8984 Old 01-28-2016, 08:16 AM
Red_Dwarf's Avatar
Liked: 0
There does seem to be another HCFR window which is appearing on top of the main window which shows the colour rectangle. I do not know what that window is, it disappears at the end of the colour test revealing the main window.
If I check GDI then the screen goes black and shows a test rectangle in the centre of the screen for ALL test colours without any problem.
BTW ATM I have 7 view windows in the windows list on the windows menu.
Ahh, if I select window 1 on the HCFR windows menu and then run the grey scale and colours measures the rectangle remains on screen for all the test colours. If I then select window 2 and run the same test, the screen goes white and shows the rectangle in the centre for ALL colours. If I then select window 3 and run the same test, it shows the HCFR window with View, Information and Selected color windows and the rectangle is in the centre of the screen for all the test colours.
The same for window 4. Window 5 first shows a black rectangle in the centre of the HCFR window and then after that the screen goes white and cycles the colour test in the centre of that white screen.
Window 6 shows the test colour rectangle for all colours in the centre of the HCFR window which shouldn't be happening with GDI checked. Window 7 shows a black screen immediately and cycles the test colours. This is with GDI checked. I don't think that this should be happening. Shouldn't the screen always go black and run the test on blank screen? Only when GDI (no background) is checked should it show the test rectangle on top of the main window.
BTW2 I am using a nVidia GT 240 using HDMI to my monitor.
Changed back to GDI (no background) select window 2 and rerun the same test and the screen goes white again and displays the colour rectangle in the centre of the screen for all test colours. Doing the same with window 7 and the rectangle shows centre screen for all cycled test colours. It's not now failing to show the test rectangle like it was doing earlier. I do not know why it is doing that. I don't think that HCFR should be displaying the white screen background when GDI (no background) is checked or why some windows are working like I expect and showing the test rectangle over the main HCFR window.
Do you know why it is doing this?
Attached is the Settings tabs and the last one is the Generator Configure options but BEFORE the change to GDI when I did the above tests.
ID:	1215826   Click image for larger version
ID:	1215834   Click image for larger version
ID:	1215842   Click image for larger version
ID:	1215850   Click image for larger version
Reply Display Calibration
