HCFR - Open source projector and display calibration software - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 928Likes
Old 06-24-2012, 04:45 PM
ndaa75's Avatar
Originally Posted by vega509 View Post
What do you use if you have an OEM i1Display3?
Whats an OEM version ?
The ones ive seen come in ablack box!
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
Old 06-25-2012, 01:05 AM
ndaa75's Avatar
I note the color munki diaply is identical (hardware) to that of the i1D3, so, if im only ever going to be using HCFR, will the performance of the CM be identical to that of the i1D3, including reading times? FYI I will be calibrating my plasma.
ndaa75 is offline
Old 06-25-2012, 04:48 AM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
The OEM i1display3 is a Spectracal unit, its sold as a meter only with Calman, no X-Rite software.
vega509 is offline
Old 06-25-2012, 06:17 AM
kjgarrison's Avatar
Chromapure also.
kjgarrison is offline
Old 06-25-2012, 07:52 AM
ndaa75's Avatar
Ok, so Ive just purchased an i1 Display Pro - presumably I can just plug and play - is there anything else i need to do?
ndaa75 is offline
Old 06-25-2012, 02:45 PM
ndaa75's Avatar
Can anyone help here?
ndaa75 is offline
Old 06-26-2012, 09:39 AM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
you are good to go.
vega509 is offline
Old 06-26-2012, 09:59 AM
djams's Avatar
you are good to go.
Xrite recommends a powered usb hub for the i1pro - not required for i1D3?
djams is offline
Old 06-27-2012, 09:15 AM
5h4d0w's Avatar
Quoted: 34 Post(s)
I'm trying to use a i1display pro (I guess what you call "i1d3"?) on w7 x64 but changing the drivers just won't work.
If I just specify the directory, without doing "let me pick from a list"/"have disk", Windows simply says that it has determined that the driver is already up to date.
And if I choose the "Have Disk" and select "i1Disp.inf", it says "The folder you specified doesn't contain a compatible software driver".
Did this ever happen to anyone? Because so far, I've only read reports of people who were able to simply do the switch...
5h4d0w is offline
Old 06-27-2012, 09:42 AM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
you need version 3.0.4 of HCFR for your meter, no drivers are required.
vega509 is offline
Old 06-27-2012, 10:15 AM
5h4d0w's Avatar
Quoted: 34 Post(s)
But then why do I only see an empty sensor list? (and why does it say this in the changelog for 3.0.4.0? "Update argyll code to latest version with fixes for i1d3")
5h4d0w is offline
Old 06-28-2012, 09:23 AM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
Look in device manager and see if there are any devices flagged with a yellow triangle. If not, unplug the d3 from the pc and plug it back in. Open HCFR and see if the meter is recognized. You do not need to install any drivers for the d3, windows detects it and lists it as an HID-Compliant device, and an USB Input Device. You can see this in devices and printers. If the i1Display3 does not show in Devices and Printers you may have a problem with the USB port, try another port.
Be sure you are using HFR 3.0.4.0 by clicking Help / About
Also be sure the X-rite software is not running, or any other software is accessing the d3.
490
305
417
484
vega509 is offline
Old 06-28-2012, 09:38 AM
5h4d0w's Avatar
Quoted: 34 Post(s)
Haha... I know you have to make a luser assumption but... I am aware when hardware isn't working correctly... I would have mentioned that.
And I assume basiccolor display also would've had issues with recognizing it in that case.
Nope, it's there, working just fine.
Check.
Check.
5h4d0w is offline
Old 06-29-2012, 08:46 PM
dml1333's Avatar
Thanks for that - as a noob, do i have to download i1D3ccss.exe from somewhere? Where do i find it?
i1D3ccss is included in HCFR 3.0.4.0 in the C:\Program Files (x86)\HCFR Calibration\Tools\ directory.
dml1333 is offline
Old 06-30-2012, 03:51 PM
65Cobra427SC's Avatar
I just downloaded Argyll Color Management Win32 v1.4.0 and compared the files in that libusb1 subdirectory with the Drivers supdirectory from my installation of HCFR 3.0.4.0, but they don't match. I'm assuming something is wrong?
65Cobra427SC is offline
Old 07-02-2012, 08:44 AM
JGrana's Avatar
Quoted: 54 Post(s)
Liked: 39
Not sure where to post bug reports - apologies if this is not the correct thread!
In any case, HFCR 3.0.4.0, installed on a Dell laptop model D620 running WindowsXP SP3.
I have this installed on 3 different laptops, 2 of the D620's and one a D630.
On one of the laptops (my main one!) HFCR crashes when going to the "Select Sensor" window. There is a brief delay, then HFCR exits.
The also occurs if I attempt to open an existing .chrc file I had previously saved.
I have attached the minidump and stderr.log files. In looking at the stderr.log file, it appears to be some kind of issue with one of my USB devices. It attemps to open a device called "NmeaDev" then reports "SEH Exception Occured".
I have tried to disable various USB devices - Bluetooth, and some devices from a Sprint aircard. There are less devices being accessed, but in the end the access to the NmeaDev seems to crash HFCR.
JGrana
HFCRcrash.zip 107k .zip file
JGrana is offline
Old 07-03-2012, 04:04 AM
ndaa75's Avatar
Have to excuse my somewhat ignorance on this subject but I have recently purchased a Samsung D8000 plasma display which I would like ti calibrate using my i1D pro and this latest version of HCFR.
However i am trying to understand what I need to do to ensure I have an accurate reading using this combination. I'm not sure how to use the i1d3ccss utility to convert the EDR files into readable ccss files.
Using command prompt i have type 'i1d3ccss.exe' - nothing happens at all. What am i doing wrong here????
ndaa75 is offline
Old 07-03-2012, 05:44 AM
ndaa75's Avatar
OK think ive figured this out - just done a calibration, HCFR is telling me everything is where it should be.
Shall run some comparisons a bit later
ndaa75 is offline
Old 07-03-2012, 07:00 AM
stevekale's Avatar
Quoted: 370 Post(s)
Liked: 45
I just wanted to add my own dose of thanks to JohnAd and others for reinvigorating this project. I used HCFR with my i1 pro spectro about 5-6 years ago (some of the names appearing in this thread are familiar from my discussions back then and they were very helpful) but I haven't had any time over recent years to revisit it. I hadn't even realised the project had folded until I saw this thread. Back then I borrowed a Windows laptop to run HCFR. I was hoping to be able to use it on a Mac but it seems I will have to wait awhile. I have been upgrading my HT equipment (CB III -> CB III HD, new BD player etc) and was looking forward to getting HCFR out again to check my Pioneer LX608d Kuro. Having skimmed through these 26 pages, when can we expect the i1 pro (old version not the 2) support up and running and what's the status of a Mac version?
Once again - very thankful for the work.
Demand greater honesty and transparency in high-end audio
With Theta, Egglestonworks and Krell since 1998!
stevekale is offline
Old 07-05-2012, 08:36 AM
Daffy07's Avatar
Hi everybody
I tested the new HCFR (very good job) with the spyder 3 colormeter and it works fine.
I plan to buy a new colormeter, a X-Rite i1 Display Pro.
I read that there is two versions, a box version (that include X-rite software) and an OEM version (without software).
Could you tell me if both versions work with the last revision of HCFR software ????
I apologize if the question have already been ask but my english is not very good and it is not easy for me to read the 25 pages of the post.
Many thanks in advance,
Daffy
Daffy07 is offline
Old 07-05-2012, 11:53 AM
JohnAd's Avatar
Here is fine, thanks a lot for the bug report. I'm looking into it.
John
My Company - Upsilon Software
Free Projects - DScaler & hcfr fork
JohnAd is offline
Old 07-07-2012, 02:53 AM
rahzel's Avatar
Liked: 148
Originally Posted by Daffy07 View Post
Hi everybody
Daffy
I second this question.
Is there an OEM and Retail version of the ColorMunki Display as well? Has anyone actually used the CMD with HCFR yet? What would the differences be other than speed?
rahzel is offline
Old 07-07-2012, 03:22 AM
jimlad2012's Avatar
Hi everyone, apologies if this has been covered before but I am having trouble getting HCFR to connect to my I 1 Pro - it just comes up with the error message that the driver is incorrect. (argyll error)
System details
Win 7 32bit
HCFR 3.0.4.0
I1 Pro driver 2.40.0.1315
let me know if you need any more details
regards
James
jimlad2012 is offline
Old 07-07-2012, 09:04 AM
djams's Avatar
^^ there are issues with the i1pro. John is working on it.
djams is offline
Old 07-08-2012, 10:02 AM
jkozlow3's Avatar
Quoted: 46 Post(s)
Liked: 35
Hi everybody
Daffy
I third this question. Thinking of purchasing the ColorMunki Display myself if there aren't any disadvantages with HCFR.
jkozlow3 is offline
Old 07-09-2012, 05:34 AM
ndaa75's Avatar
Now this is strange,
Have calibrated using Calman 4, got it as perfect as i can. Ran an immediate comparison (closed calman, rebooted laptop, loaded HCFR) with the same settings with HCFR and my grayscale is now off, getting DE's of 6+ across the board with red running approx 92-93% all the way. This is on a Sammy PS51D8000 plasma - now i note there is no presetting for plasma displays, perhaps this maybe the culprit, or maybe Calman is out?
ndaa75 is offline
Old 07-09-2012, 07:13 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Does Calman implement a profile for your D3? Uncorrected D3's measure red low on plasma's (CCT ~500K too high) so you need a correction matrix to use it with HCFR.
zoyd is offline
Old 07-09-2012, 09:40 AM
djams's Avatar
I contacted xrite a while back to inquire about the difference between CM Display and i1 Display Pro. For what it's worth, here is the response. Does not delve into important aspects of meter performance such as accuracy, repeatability, low-light sensitivity - so not all that helpful. If I were considering purchsing a CM Display, I'd make more inquiries/do more research. The statement "hardware is also a little bit different" is too vague for me. smile.gif
Thank you for contacting X-Rite. You can see a complete side-by-side feature chart for ColorMunki Display and i1Display Pro at this link. You will have to scroll down the page to see it. Both products allow you to profile monitor and projector. If you look at the features listed under “Software,” you will see ColorMunki is limited to Predefined options for quite a few things, whereas i1Display Pro allows user defined or custom options. This can make a difference if you are profiling several monitors.
The hardware is also a little bit different. I1Display Pro can cycle through readings much faster than ColorMunki can. This may not be a concern for you, because you can see from the demo videos, monitor calibration takes only a few minutes.
http://www.xritephoto.com/custom_page.aspx?PageID=274
djams is offline
Old 07-09-2012, 10:25 AM
Padex's Avatar
Hi,
I recently purchased ColorMunki Display and I have used it with the excellent new HCFR successfully. The reading times near black are no slow at all. Compared to Spyder 2 the ColorMunki Display is very fast and very accurate.
I did some searching in the Web and there should not be very much difference between CMD and I1 Display Pro. Ambient light measurement and measurement speed are different. I think accuracy is the same..
Padex is offline
Old 07-09-2012, 01:04 PM
ndaa75's Avatar
Unsure what you mean by 'does Calman implement a profile for your D3'?
With Calman its plug and play - it already selects the D3 as the metre found, you select plasma, away you go.
HCFR finds the D3, but no plasma option and unsure where to find any correction matrix???
ndaa75 is offline
