HCFR - Open source projector and display calibration software - Page 256 - AVS Forum | Home Theater Discussions And Reviews
 925Likes
Old 07-08-2016, 06:53 PM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Originally Posted by Dominic Chan View Post
zoyd,
I encountered a problem when selecting "Absolute Y w/gamma" for dE handling - the Selected Color window does not show the RGB Levels. See attached screen shots w/gamma and w/o gamma.
The issue seems to be specific to the configuration; I did not encounter this on another computer.
Fixed in latest upload.
Updates on 07/09/16
  • Fixed scaling of iso12233 and 1956 pattern
  • Added another alignment pattern
  • Added option for 6 user patterns/defaults to casino royale images
  • Fixed occasional gdi pattern appearing when not requested
  • Switched HDR calibration white point to level 126
  • Fixed selected color RGB levels or target not showing after Y w/gamma measurement
VBB and anta1974 like this.
zoyd is offline
Old 07-10-2016, 06:46 PM
carneb's Avatar
Quoted: 73 Post(s)
Liked: 35
Es-2000
Is it possible to use the EFI ES-2000 in HCFR? There are a couple on ebay, but I can't find any info on whether it can be used with HCFR (or other TV Cal software for that matter). It looks like an I1 Pro 2 clone but I'm not sure if it has custom firmware
carneb is offline
Old 07-11-2016, 02:45 AM
Steffche's Avatar
Ive only just discovered that i may have an inferior meter. A couple of years ago i purchased the i1display pro meter eosd3, thinking that i was buying the i1 pro. Having just read another post by someone explaining the differences between the various versions of the xrite meter I'm now beginning to question the accuracy of my results of calibrating my vt60 with hcfr and my i1 display meter?
Are they good enough for the vt 60 and are they susceptible to drift after a couple of years. It has a date of 05/2013 ?
Steffche is offline
Old 07-11-2016, 02:51 AM - Thread Starter
zoyd's Avatar
Liked: 1055
According to the ArgyllCMS documentation:
The EFI ES-1000 (which is a re-badged Eye-One Pro) is also reported to work with Argyll.
So there is a decent possibility the 2000 will work with HCFR but no guarantee.
zoyd is offline
Old 07-11-2016, 05:00 AM
Quoted: 629 Post(s)
Liked: 515
I don't think that this is on topic with this thread really.
The i1 Display Pro is quite an accurate colorimeter right out of the box, obviously it won't be as accurate as a good spectrophotometer, but it should do the job of getting your plasma looking good.
As far as I know, it's less prone to drifting than other meters, since the color filters are internal and are not exposed.
I *think* that it's far more likely that the plasma has deteriorated over the 3 years rather than your meter has. In addition, calibrating a plasma can be a tricky matter due to their ABL which can limit brightness in certain situations and skew the results of your calibration.
HCFR 3.4.3 | Git branch
Vizio M60-D1 | T95M with LibreELEC | Vizio SB3851-D0 | Calibration + Settings
Vizio M55-C2 | M8S+ with LibreELEC | Calibration + Settings
The Coolest is online now
Old 07-11-2016, 06:55 AM
Slower's Avatar
Quoted: 20 Post(s)
Liked: 1
Updates on 07/09/16
Zoyd,
Thanks for the last update. Unfortunately ISO 12233 is still stretched vertically to fill 16:10 instead of keeping 16:9. Other patterns are OK. Really happy with the Alignment & Uniformity pattern, and the return of the Casino Royale images. Good job!
By the way, is there a particular reason to use the ISO 12233:2000 pattern instead of the newer ISO 12233:2014 version? See for instance http://www.imatest.com/testing/iso-12233/
Slower is offline
Old 07-11-2016, 10:37 AM
Knight7m's Avatar
Quoted: 42 Post(s)
Its my first time using HCFR. I just download ver 3.4.2 to calibrate my LG OLED, please can someone tell me how to make calibration and what other things i need to have, also I have Spydor 4Pro meter about 4 years, is it good for calibration ?
(I couldn't find tutorial how to use HCFR)
Knight7m is offline
Old 07-11-2016, 04:37 PM
Lenthan's Avatar
Quoted: 40 Post(s)
http://www.curtpalme.com/forum/viewtopic.php?t=10457
I used this one posted on the main page here. It's a bit dated but works. I can't comment on the Spyder 4, I used a Spyder 3 with mixed results...seemed a bit washed out after my calibration.
Lenthan is offline
Old 07-12-2016, 05:31 AM
Quoted: 90 Post(s)
Hello, i'm calibrating my lg oled with hcfr and i think i got everything perfect minus the luminance.
When i put the tv at 20 points IRE a new setting shows up called "adjusting luminance"("Adjust luminance level for selected IRE point").
Will messing around with that setting fix my luminance in above pic?
If that doesnt work do you guys know other ways you can recommend me?
OledGod is offline
Old 07-12-2016, 09:09 AM
Quoted: 1369 Post(s)
Liked: 346
Yes, that screen is precisely what you need to fix the luminance. Make sure HCFR is also set to 20-points.
Dominic Chan is offline
Old 07-12-2016, 09:32 AM
Quoted: 90 Post(s)
Thanks a lot!
A new problem i run into now is every time i adjust luminance the gamma gets messed up, i then go to adjust gamma the luminance gets messed up, i then go to adjust luminace the gamma gets messed up lol.
Is there an easier way to adjust both at the same time?
OledGod is offline
Old 07-12-2016, 11:25 AM
LastButNotLeast's Avatar
Quoted: 1689 Post(s)
Liked: 1303
You might get more information from luminance of each color. Right-click on the graph and turn on red, green and blue.
Let's see what THAT looks like.
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
Old 07-12-2016, 01:07 PM
Liked: 346
Thanks a lot!
The Luminance graph and gamma are two different "views" of the same thing. Changing gamma will change the luminance in between 0 and 100%, and vice versa.
Make sure you set the Gamma preference to your desired setting; e.g., BT.1886 or power law first. Then getting the correct gamma will also give you the correct luminance "automatically".
bmcn likes this.
Old 07-13-2016, 09:10 AM
Quoted: 90 Post(s)
Thanks a lot, changing to power law did the trick!
OledGod is offline
Old 07-13-2016, 09:14 AM
Quoted: 90 Post(s)
Michael
Thanks for the info!
Here's some pics after i was able to get the gamma and luminance close to good.
Let me know what you think!
OledGod is offline
Old 07-13-2016, 10:56 AM
Liked: 1303
I think your "close to good" is terrific.
Michael
Old 07-14-2016, 09:33 AM
Quoted: 90 Post(s)
Michael
Didn't got to enjoy these terrific results for too long.
After running primary, primary and secondary colors measures, then measure grayscale primary and secondary colors and then running "measure grayscale" alone the results end up very worse.
I recalibrated my tv close to perfect and tried to see if the same thing happens again and it did!
Do you know why when running the 3 measures next to the grayscale button messes up the grayscale when i run it again?
OledGod is offline
Old 07-14-2016, 10:56 AM
shoman94's Avatar
Quoted: 1946 Post(s)
Liked: 1555
SO you're saying that running a grayscale sweep alone is fine but if you run the three measures listed above...then run a grayscale sweep...its totally different results?
My P75-C1 Calibration Settings (3.0.14.0).
My P75-C1 BETA Calibration Settings (3.2.8.3).
Vizio P75-C1 (fw-3.2.8.3), Pioneer Kuro 5020, Pioneer VSX-1131, XBox One, Wii
NVIDIA SHIELD.v1, Antennas Direct DB4e w/Dipole OTA antenna and 2x HDHR Connects, QNAP 431+
shoman94 is online now
Old 07-14-2016, 11:12 AM
Quoted: 90 Post(s)
Not totally different but very different like the DE shifts up to 4 digits in some areas. Even the gamma shifts a lot.
By the way could this happen because my tv is oled?
OledGod is offline
Old 07-14-2016, 11:24 AM
shoman94's Avatar
Liked: 1555
I have no clue , it doesn't make sense the way I'm understanding it and I've never owned an OLED..
Old 07-14-2016, 11:30 AM - Thread Starter
zoyd's Avatar
Liked: 1055
If you are using the detached (floating) window for patterns there is a bug in the automatic pattern sequencing, please use the other pattern options (GDI or GDI/no background) until fixed. thx.
shoman94 likes this.
zoyd is offline
Old 07-14-2016, 11:47 AM
Quoted: 90 Post(s)
I'm using "GDI" too.
Running gray scale alone many times the results differ little too each time, it's only when i run the 3 color buttons next to gray scale and then run gray scale again when the DE, the gamma and rgb levels shift a lot.
Thanks for the reply by the way!
OledGod is offline
Old 07-14-2016, 12:11 PM - Thread Starter
zoyd's Avatar
Liked: 1055
ok then there shouldn't be a problem with any of the sequences, or the order in which you run them. Please save and upload the zipped .chc files showing the problem and list the steps you used to create them so I can try and reproduce it here.
zoyd is offline
Old 07-14-2016, 02:27 PM
Quoted: 90 Post(s)
I couldnt upload the files here so i used an external uploader.
This file is from running grayscale alone 4 times and results remained constant each time.
http://www111.zippyshare.com/v/6GVsPpOO/file.html
This file is from running grayscale then running the button next to it "primary colors", then the button next to it "primary and secondary colors", then the button next to it "gray scale primary and secondary colors" and lastly running grayscale alone(first button) expecting to get same results i got in first link above but didnt.
http://www111.zippyshare.com/v/XFW3qMzl/file.html
I also noticed the rgb levels and gamma to shift after i run each of the 3 buttons next to gray scale, but when i run grayscale alone after the gamma, rgb levels, de dont go back to the way they were, even if i close hcfr and create a new file and run only grayscale the de, rgb levels and gamma will still be way off.
OledGod is offline
Old 07-14-2016, 02:58 PM - Thread Starter
zoyd's Avatar
Liked: 1055
Those are just normal measurement variations. If you compare your before to after using the before as reference:
The dE/ref and dxy/ref are all within normal repeatability variations. (These direct comparisons of the grayscale color difference between the two measurement sets).
The gamma and RGB plots also lie on top of each within normal repeatability limitations. Dotted lines are before, solid after.
The small offset shift you see in gamma (average shift = 0.01) is entirely due to the different peak white measurements (376 nits before, 386 nits after) and is due to panel instability. OLEDs can have variations in peak luminance based on both the content of the rest of the image and the patch history. You'll probably find it a bit more stable at lower peak white (120 nits is recommended for critical viewing in the evening.) although a net shift of 0.01 is negligible.
zoyd is offline
Old 07-14-2016, 04:14 PM
Quoted: 90 Post(s)
Thanks a lot for the info zoyd!
I feel much better now that i know it's normal.
OledGod is offline
Old 07-14-2016, 04:27 PM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
Old 07-15-2016, 06:50 AM
Quoted: 90 Post(s)
Is it better to calibrate the rgb levels and gamma by using the button that measures "grayscale primary and secondary colors" at the same time?
OledGod is offline
Old 07-15-2016, 07:39 AM - Thread Starter
zoyd's Avatar
Liked: 1055
Normally when you are calibrating you'll select the grid point you are working on and run continuous measurements (green arrow) while you adjust the display. Then you run the sweeps to check everything after adjustments.
zoyd is offline
Old 07-15-2016, 08:30 AM
Quoted: 90 Post(s)
When i click the green arrow the small window in the center gets stuck at the black color, does that mean i need to start adjusting the tv settings for it to continue into other colors?
I never used that green arrow button before, excuse my noobness.
OledGod is offline
