HCFR - Open source projector and display calibration software - Page 259 - AVS Forum | Home Theater Discussions And Reviews
 920Likes
post #7741 of 8971 Old 07-26-2016, 02:26 PM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Leave intensity at 100% and I use 5% pattern size with 10% APL. This should give a black level consistent with average viewing levels. Try BT.1886 set to 2.4 relative gamma and 50% offset.
rickardl and LastButNotLeast like this.
zoyd is offline
post #7742 of 8971 Old 07-26-2016, 06:36 PM
Quoted: 1347 Post(s)
Liked: 344
zoyd,
Why is the Y Target for 0% white always left blank in the grid? The graphs show it as 0.
Dominic Chan is online now
post #7743 of 8971 Old 07-28-2016, 07:13 AM
Slower's Avatar
Quoted: 20 Post(s)
Liked: 1
Zoyd,
After opening some older calibration files in 3.4.2, I found some bugs not present in 3.4.1:
Selecting BT 1886, in near-black graph the target luminance goes to zero instead to actual black level for 0% white stimulus. Also noted by Dominic Chan in the above post, I now see.
Saturation shift graphs look completely different: in 3.4.1 starting with 0% shift (as a result of near-perfect grayscale) to max +/- 5% for fully saturated primaries/secondaries. On the other hand, 3.4.2 starts with +/- 3% (even for near-perfect grayscale!!) with fully saturated green and magenta going to 20-50%. The resulting dE graph of course is also different compared to the one in 3.4.1.
Sorry to bother you with this, but perhaps you missed my post #7657 about scaling ISO 12233?
Slower is offline
post #7744 of 8971 Old 07-29-2016, 09:28 AM
Liked: 1
hai all
jyothish is offline
post #7745 of 8971 Old 07-29-2016, 10:26 AM
Liked: 344
Originally Posted by Dominic Chan View Post
zoyd,
zoyd,
Just noticed a not entirely new problem with 3.4.1. In the GDI mode, the test patterns do not cover the entire screen on the 2nd display. In the past, my workaround was to open the "Test Colors" window and drag it to the 2nd display. This still works for 3.4.1, but it reverts to the partial screen for every run, meaning I have to reopen the Test Colors window before each run.
post #7746 of 8971 Old 07-30-2016, 04:40 AM
Quoted: 90 Post(s)
You can keep the card gamma tables active by unchecking "disable video card lut " in the pattern generator setup
That's awesome, thank you so much for this info!
OledGod is offline
post #7747 of 8971 Old 07-30-2016, 06:47 AM - Thread Starter
zoyd's Avatar
Liked: 1055
Originally Posted by Slower View Post
Zoyd,
Upload the chc file where you are seeing a difference between 3.4.1 and 3.4.2 sat shift graphs so I can take a look at it.
zoyd,
Do you mean 3.4.2? What is the resolution of the screen you are trying to calibrate and what is the resolution of the screen you are running the program on? The pattern size HCFR produces should be exactly what windows tells it is the size of the screen. Can you tell if the pattern produced on the extended screen is either 1. The same resolution as the primary screen? or 2. Trying to maintain a 16x9 aspect ratio on a non-16x9 screen?
zoyd is offline
post #7748 of 8971 Old 07-30-2016, 07:23 AM
Liked: 344
Yes, I meant 3.4.2. The resolution is 1920x1080 for the projector, as well as the laptop itself.
It does that, but only after I display the Test Colors windows.
I previously used a lower resolution laptop and thought that was the cause, but apparently not, as the same problem occurs with the new laptop which has the same resolution as the projector.
post #7749 of 8971 Old 07-30-2016, 07:42 AM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
post #7750 of 8971 Old 07-30-2016, 07:46 AM
Liked: 344
What is the resolution?
1080p (1920x1080)
post #7751 of 8971 Old 07-30-2016, 08:58 AM
Liked: 344
zoyd,
Also, in 3.4.2, the dE is always 0 at 100% white when using simulated sensor, unlike in previous versions.
post #7752 of 8971 Old 07-30-2016, 08:58 AM - Thread Starter
zoyd's Avatar
Liked: 1055
hmmm...I use that resolution set-up as well without issue. Is the aspect ratio maintained? Can you post a picture? Anyone else see similar?
zoyd is offline
post #7753 of 8971 Old 07-30-2016, 10:26 AM
Slower's Avatar
Quoted: 20 Post(s)
Liked: 1
Here it is. REC 709, BT1886, CalmanSG Colorchecker.
Thanks for having a look.
Slower is offline
post #7754 of 8971 Old 07-30-2016, 12:19 PM
Liked: 344
Here's a picture. I use a pattern size of 50%. The pattern (including background) seems to have the same aspect ratio, but only occupies the upper left portion of the screen.
post #7755 of 8971 Old 07-30-2016, 01:44 PM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
post #7756 of 8971 Old 07-30-2016, 03:43 PM
Liked: 344
Is the native resolution of that display 1920x1080? If the display is identified as 1920x1080 that's what the image size will be.
The secondary display is a JVC DLA-x30 Projector, 1080p with no e-Shift.
I connected another display, a 2560x1080 ultra-wide monitor. It shows a similar problem but with the pattern height larger than the physical display, as if it's being scaled to fill the 2560 width (see picture attached).
In both cases, if I first drag the Test Colors window to the secondary display, the pattern will then display properly.
What's different in 3.4.2 is that I have to repeat this every time I display a pattern, whereas in previous versions I only have to do it once per session.
post #7757 of 8971 Old 07-31-2016, 02:44 AM
carneb's Avatar
Quoted: 73 Post(s)
Liked: 35
When using the ST2084 transfer function the following calibration sequences will assume a reference white of 98.7835 cd/m^2 (closest 8-bit value to 100 cd/m^2)
  • Primaries and Secondaries
  • Saturation sweeps
  • Color checker sequences: GCD/MCD and CalMAN classic, Pantone, CalMAN, and ChromaPure skin tones, CalMAN SG.
Is this only the case if there is no white reference measured for primaries and secondaries? If there is a white reference is this used for all the above mentioned sequences?
carneb is offline
post #7758 of 8971 Old 07-31-2016, 04:05 AM - Thread Starter
zoyd's Avatar
Liked: 1055
The primaries/secondaries white is used as the user measured white reference for the color checker series. If that isn't available the grayscale white is used. For HDR10 targets, 50% stimulus (98.7835 cd/m^2) white is assumed in order to calculate the target reference. When ST.2084 is the selected transfer function the internal generator will automatically run the primaries/secondaries sweep at 50% stimulus.
zoyd is offline
post #7759 of 8971 Old 07-31-2016, 12:50 PM
bradthebold88's Avatar
Quoted: 16 Post(s)
Liked: 31
I just attempted to calibrate my TV for the first time with a i1display pro on a Vizio M602i-B3. I got everything looking pretty good, I think, except for the gamma. Is there anything I can do about the gamma curve?
Living room: Definitive BP2000TL, CLR3000, BPVX, Quad SI 18" subs
Bedroom: Definitive BP30, CLR2000 Also have had: BP7000SC, BP8B, BP10B, BPX, Dayton 15" HF subs, Rythmik F15
bradthebold88 is online now
post #7760 of 8971 Old 07-31-2016, 02:41 PM
carneb's Avatar
Quoted: 73 Post(s)
Liked: 35
The reason I ask is that I'm getting some dEs of around 4 for the grey and white windows in the MCD Classic colorchecker and some of the colour sweep 0% saturation measurements from Mascior's HDR tests. If the target was 98 nits then that could be the reason. I did measure a white reference for the primaries/secondaries so the 98 nit reference is not the reason
carneb is offline
post #7761 of 8971 Old 07-31-2016, 02:55 PM - Thread Starter
zoyd's Avatar
Liked: 1055
Upload your .chc so I can see what you are talking about, if you don't measure 98.7835 cd/m^2 for 50% white then you will have errors.
zoyd is offline
post #7762 of 8971 Old 07-31-2016, 04:44 PM
LastButNotLeast's Avatar
Quoted: 1624 Post(s)
Liked: 1235
You have changed these recommendations periodically (see, someone really IS paying attention ). Is there a method to the madness?
It's been a while since I've checked my set, so I'm eager to see how close it is with these parameters.
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #7763 of 8971 Old 07-31-2016, 05:20 PM - Thread Starter
zoyd's Avatar
Liked: 1055
Michael
I ended up using these because the black level corresponded to what it is during typical movie scenes. The overall color reproduction will not vary significantly whatever pattern geometry you use as long as it's under 15% area, and APL level is in the 5-20% range.
zoyd is offline
post #7764 of 8971 Old 07-31-2016, 08:03 PM
Liked: 344
If your TV has the 10- or 20-point grey scale adjustments, you can use those to adjust the gamma. You should be able to find the recent discussions in this thread.
Also, if you choose a Gray Scale dE handling that includes gamma, you will automatically get the correct gamma when you adjust the 10-point grey scale; i.e., in addition to ensuring that each step is neutral in colour, the same adjustments also ensure that the luminance is correct for the target gamma.
post #7765 of 8971 Old 08-01-2016, 12:39 AM
carneb's Avatar
Quoted: 73 Post(s)
Liked: 35
I've attached my chc file. My Greyscale 50% is around 92 nits (the target 94) and the white window for primaries/secondaries is 90 nits.
carneb is offline
post #7766 of 8971 Old 08-01-2016, 07:12 AM - Thread Starter
zoyd's Avatar
Liked: 1055
Zoyd,
Luminance and near-black 0% issue has been confirmed and fixed.
The satshift graph issue has been confirmed and will be fixed in next update.
fixed.
I can't reproduce this on any resolution or display combo that I can access so it's not a generic problem. Will have to wait for more reports to see if some consistent reason can be discovered.
Ok, so for your colorchecker measurements, some of the error you are seeing is because your display is not hitting it's PQ targets (98.735 nits @white ). PQ is an absolute scale and the targets are being calculated to that absolute scale, not your measured white.
zoyd is offline
post #7767 of 8971 Old 08-01-2016, 04:43 PM
carneb's Avatar
Quoted: 73 Post(s)
Liked: 35
Hi Zoyd. I just checked with Ryan about the levels in his test patterns and this was his response:
All of my 50% white/gray patches utilized in grayscale, color primaries/secondaries, and Colorchecker measurements are based on 94.4 nits or 126,126,126 (triplets shown in 8bit). These triplets also match what HCFR and Calman are looking for within there HDR10 workflows.
Is this what you expected?
carneb is offline
post #7768 of 8971 Old 08-01-2016, 11:09 PM
Turrican4D's Avatar
Quoted: 729 Post(s)
Liked: 427
Spyder 3 is not recognized!
My Spyder 3 TV worked well five years ago with my old WinXP system on my old computer with HCFR. Now I have a new PC with Windows 7, downloaded the new HCFR version and the Spyder 3 TV is in the device manager as "Spyder3 Argyll".
Problem is, HCFR won't let me use it. It only gives me the option to simulate a sensor. Am I too dumb? What am I missing?
Prof. Dr. Turrican M.D.
Turrican4D is offline
post #7769 of 8971 Old 08-02-2016, 12:20 AM
Turrican4D's Avatar
Quoted: 729 Post(s)
Liked: 427
Originally Posted by Make73 View Post
Quote: Originally Posted by jrussell88
Can you suggest where I'm going wrong?
Unpack this file and copy "Spyder3.dll" to HCFR folder, someone wrote that got it working. However it may still give some error notes but it´s working.
Unfortunately the zip-file is corrupt.
post #7770 of 8971 Old 08-02-2016, 12:36 AM
Make73's Avatar
https://1drv.ms/u/s!AmJitHy1KlXghXiSNB-y27J068rv
Turrican4D likes this.
Make73 is offline
Reply Display Calibration
