HCFR - Open source projector and display calibration software - Page 312 - AVS Forum | Home Theater Discussions And Reviews
 986Likes
post #9331 of 9345 Old 10-10-2017, 11:17 AM
Freeco's Avatar
Originally Posted by jpgfontes View Post
wondering what is the optimal distance from the screen I should place the Colormunki.
Don't think the distance matters too much, as long is it's not too close (casting a shadow) or overly exaggerated too far.
Mine is about 1m away from my 90" screen. I've placed my tripod just high enough so its shadow is still in the black, unlit part of the test image. The meter is set at a 75-80° angle, pointed at the middle of the lit test image.
But you have to experiment a bit going back and forth, tilting left/right and up/down. Look for the highest captured light input while doing a continuous measurement. If you place it further away and the Y ftL value decreases, you're going in the wrong direction
jpgfontes likes this.
Freeco is offline
post #9332 of 9345 Old 10-10-2017, 11:22 AM
Quoted: 1629 Post(s)
Liked: 415
Hi!
I've just got an Epson 5040 and a Colormunki Display. I'm planning to use HCFR to calibrate it and was wondering what is the optimal distance from the screen I should place the Colormunki. I think it doesn't make a difference, but I'm using a gray 0.8 gain screen.
The distance is not critical, as long as the meter doesn't "see" its own shadow on the screen, or measure outside the screen area (if it's placed too far). As a rule, find the position and angle that gives you the maximum reading.
Some people recommend measuring from the normal viewing position, but with the Colomunki that may be too far. Try to have the meter pointing in the same direction as would be from the viewing position.
Also, I used the color filter that comes with the DVE Bluray to calibrate the projector's colors (using my eyes ). Should I start my colormunki calibration from this "eye" calibration or is it better to reset everything to default and start from 0?
I would start from 0.
JVC DLA-RS400
HCFR v3.4.x Bug List
Dominic Chan is online now
post #9333 of 9345 Old 10-15-2017, 04:39 AM
alamagar's Avatar
Originally Posted by jamesb23 View Post
So I've moved on from SDR to HDR calibration but I'm a little bit confused. I purchased the Masciola patterns for my USB to use on my LG c6 OLED. In HCFR preferences I'm assuming I select 2084 for gamma, but which standard is it in the drop down menu - there's Rec2020, Rec2020/P3, DCI-P3? Also, given that I have to use the LG code patterns rather than standard 5-100 IRE grayscale, how does HCFR track it? It's not going to show something by LG's code values right? So how do I know which grayscale pattern aligns with what?
Hi Jamesb23, I am in the same situaipn as you. How do you solve the tracking of LG code patterns?
Thanks in advance.
alamagar is offline
post #9334 of 9345 Old 10-15-2017, 06:02 AM
A/V Addicted Member
mascior's Avatar
Quoted: 277 Post(s)
Liked: 405
Thanks in advance.
Hi alamagar,
There is no fix. LG's code specific methodology just isn't implemented correctly. However, the recommended approach has been discussed several times, HERE is one thread to reference. At a high level, the best overall approach is to leave code value 127 at default and only make small +/- RGB adjustments through the rest of the entire sweep (disregarding luminance errors and constantly referencing a grayscale ramp for discoloration). Thanks!
- Ryan M.
mascior is offline
post #9335 of 9345 Old 10-15-2017, 10:46 AM
alamagar's Avatar
Originally Posted by mascior View Post
Hi alamagar,
- Ryan M.
Thanks Ryan,
So,
what I learned when calibrating LG C6 is:
  • OLED Light and contrats at 100
  • Bright at 50 (even the black pattern tells you something different)
  • Color: Leave at 55 (please confirm, would not be 50 the recomendable?)
  • Tint: 0
  • Color Space: Normal (not wide, please confirm)
  • in RGB calibration, do not touch 127
  • The rest at OFF
and a copule of questions:
1.- When adjusting RGB, from 50% IRE (513 and onwards) I need to down Red and Blue a lot (-50, -20) aprox. Even in higher ones -50 it is not enough. Is this normal? is it advisable to do such variations in RGB?
2.- Do your recomend to calibrate CMS as well?
Mario.
alamagar is offline
post #9336 of 9345 Old 10-15-2017, 06:35 PM
forkenbrock's Avatar
Quoted: 14 Post(s)
Is there any way to get 20 step greyscale patern in HCFR? Can't find it in the menu or with a google search, so I'm under the assumption that the only advantage of 10 more steps is more flexibility to fine tune each of the 10 steps.
forkenbrock is offline
post #9337 of 9345 Old 10-15-2017, 07:29 PM
Liked: 415
It’s under Measures->Parameters. You can have up to 50 steps.
JVC DLA-RS400
post #9338 of 9345 Old 10-16-2017, 02:17 AM
Barsk's Avatar
Quoted: 42 Post(s)
Hello everybody.
Back again after a long time. I'm about to take the leap to 4K HDR (an LG B7 OLED) and wondering if the Chromecast Ultra is supported för HDR pattern generation? Actually, I could use a few pointers at where to look for methodology on HDR calibration at large. I'm coming in blind here...
Btw, has Zoyd left the forum (and development)? I see The Coolest has picked up with a fork...
Barsk is offline
post #9339 of 9345 Old 10-16-2017, 08:23 AM
jamesb23's Avatar
Quoted: 38 Post(s)
Thanks in advance.
I see mascior already replied and linked you to that other thread. I've been too busy lately to try this myself, but I will be doing a 2pt RGB balance in the service menu soon. The consensus seems to be that that's the best way to handle HDR calibration. You can put the HDR color temp on medium (one that you wouldn't use for SDR settings) and then in the service menu go to white balance and select medium for 2pt calibration and adjust to get it balanced. The actual LG code balance is all out of whack so you can try to use it to fine tune AFTER the 2pt calibration if you want, but to use it alone is likely to be an exercise in extreme frustration. Also, with HDR you run the risk of some actual burn-in on your screen if you leave any of those bright white patterns up for any length of time.
jamesb23 is offline
post #9340 of 9345 Old 10-18-2017, 09:16 AM
Barsk's Avatar
Quoted: 42 Post(s)
Hmm. I got a tip from a calibrator that the Colormunki Design can be used as a cheap spectrophotometer to help correct my i1DisplayPro.
But I can find just about zero references to it here or elsewhere. Is it of any use? How accurate is it? Price is about 2x the i1displaypro.
Barsk is offline
post #9341 of 9345 Old 10-18-2017, 10:44 AM
Liked: 415
There were some discussions here, but there was no consensus on the accuracy.
JVC DLA-RS400
post #9342 of 9345 Old 10-18-2017, 01:18 PM
Barsk's Avatar
Quoted: 42 Post(s)
I see the only figures was from you, with some larger dE for the ColorMunki. So in your opinion it is not worth it?
Barsk is offline
post #9343 of 9345 Old 10-18-2017, 01:33 PM
Liked: 415
As stated in my previous post, my opinion (take it for what it's worth) is that for display types that it directly supports, there's no benefit in profiling the i1DisplayPro to the ColorMunki Design/Photo. For non-supported display types, the ColorMunki Design/Photo may provide more accurate results as it measures the spectral data.
JVC DLA-RS400
post #9344 of 9345 Old Yesterday, 12:26 AM
Barsk's Avatar
Quoted: 42 Post(s)
Ok, I'll stay away from the Colormunki. It was just a thought.
Are there spectral profiles available for LG OLED panels? I guess so and I need to upgrade my gear, but my memory fails me to what and where I can get said profiles. Need to get up to speed in calibration again in time for Black friday sales...
Also, is there any summary of the methodology that is recommended for calibration of the LG 2017 OLEDs. Both SDR and HDR. E.g what the calibrators used in the HDTV shootout in the UK recently for instance. Vincent on HDTVTest would be an invaluable resource if he could be contacted I think.
Barsk is offline
post #9345 of 9345 Old Today, 01:52 PM
Liked: 0
Hello, I have a question: How do I enter chromapure data into HCFR?
Should I be more specific about my question?
The FAQ is not quite clear about it.
I really hope someone can explain it to me.
Should I provide some links?
Ramin1 is online now
Reply Display Calibration
