HCFR - Open source projector and display calibration software - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 986Likes
post #121 of 9353 Old 02-26-2012, 03:32 AM
JohnAd's Avatar
Originally Posted by 703 View Post
Since you're using argyll libraries, are you going to use the High Res mode for the i1Pro? As the i1Pro is not that great at low IRE's, even with the current crop of commercial software.
Can do, yes. Do you need a switch or should I always enable it?
John
My Company - Upsilon Software
Free Projects - DScaler & hcfr fork
JohnAd is offline
post #122 of 9353 Old 02-26-2012, 04:54 AM
deandob's Avatar
Quoted: 40 Post(s)
Liked: 24
Originally Posted by JohnAd View Post
So my ouline plan is
Meter support
Clean up, correct, extend and test colour maths library
Go through ui and simplify code and ensure each point's target is correct and that the displayed calculations make sense.
So essentially getting what's there working better before adding major new features in the UI. There will be plenty of releases along the way and this whole process will take a while but should be worth it...
Should still be on for a first release with the new meter code this week.
John
Makes sense John, concentrate on the basics first. I'll be able to test next weekend for your first release if its ready.
deandob is offline
post #123 of 9353 Old 02-26-2012, 05:12 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
John
I'd recommend a switch but how it operates will depend on how the 3.33 nm vs. 10 nm sampling is handled. If the 10 nm mode averages 3 x 3.33 nm samples (rather than just picking out every third sample) this would be the preferred mode for low IRE color measurements. If the 10 nm sampling mode just picks every third sample then I would get rid of it and create the two modes in software using only the driver's 3.33 nm sampling and then do the calculations with either 1 or 3 sample averaging.
I think in general the high resolution setting will be used most often, especially if you are profiling a secondary colorimeter. In cases where you do not have a colorimeter or the display spectral display is smoother (non-plasma) the low resolution mode would be preferable.
zoyd is offline
post #124 of 9353 Old 02-26-2012, 05:33 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
John
wow....that's great.
so should i pull the trigger on a colormunki display or an i1 display 3?
smokarz is offline
post #125 of 9353 Old 02-26-2012, 06:21 AM - Thread Starter
zoyd's Avatar
Liked: 1064
I tried compiling the mac code on my 10.7 macbook pro and there were quite a few deprecated functions without obvious work-arounds. I'm not a programmer but bringing this code up-to-date appears to be a big job.
zoyd is offline
post #126 of 9353 Old 02-26-2012, 11:05 AM
JohnAd's Avatar
It currently compiles cleanly in xcode 3.2, but yes upgrading it will be a lot of work.
John
JohnAd is offline
post #127 of 9353 Old 02-26-2012, 01:35 PM
Bluescale's Avatar
Quoted: 736 Post(s)
Liked: 301
What flavor of of the Display 3 will be supported by the next release of HCFR? I'm ready to purchase it, and I'd love to sign up as an alpha/beta tester.
Bluescale is offline
post #128 of 9353 Old 02-26-2012, 01:39 PM
Bluescale's Avatar
Quoted: 736 Post(s)
Liked: 301
Okay, it looks like I was mixing up information I saw on the CalMan and ChromaPure websites. If you're not buying a vendor customized one, it looks like there's one option:
Xrite EODIS3 i1Display Pro
Can you please verify that this will be the supported version? Also, will you verify that I can get on the tester list?
post #129 of 9353 Old 02-26-2012, 02:03 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
i would definitely love to test this if it has support for ColorMunki Display....
smokarz is offline
post #130 of 9353 Old 02-26-2012, 02:57 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
John
A switch for accessing both resolution modes for the i1 Pro would be very desirable -- and very much appreciated
Larry
LarryInRI is offline
post #131 of 9353 Old 02-26-2012, 09:43 PM
703
703's Avatar
Quoted: 76 Post(s)
Liked: 24
John
As a switch/check box would be great. So we can see for ourselves what difference it makes.
Would an application restart or meter re-init required for this?
703 is online now
post #132 of 9353 Old 02-27-2012, 12:48 AM
ascl's Avatar
Supporting XCode 4 is a problematic, as there is no supported way of building for 10.5 in XCode 4. So, for the best compatibility, we are currently sticking with XCode 3, which allows us to build for and support 10.5, 10.6 and 10.7, at least for 32 bit builds. So XCode 4 doesn't buy us anything very worthwhile right now.
Building for 64 bit is going to be a fair bit of work due to deprecated interfaces, but is something I will attempt once we have the argyll driver working better.
ascl is offline
post #133 of 9353 Old 02-27-2012, 12:53 AM
JohnAd's Avatar
I haven't got a Display 3 and so I can only go on the code and the ArgyllCms website.
see http://www.argyllcms.com/doc/instruments.html#i1d3
The supported meters should be:
i1 Display Pro
ColorMunki Display
The CalMan edition of the meter
Exactly how what drivers need to be installed and what needs to be stopped will need to be worked out once we have a releasable verison of the code.
John
JohnAd is offline
post #134 of 9353 Old 02-27-2012, 12:57 AM
JohnAd's Avatar
Just keep following this post, I'll post links here as soon as there is anything ready.
I wired everything up for the first time yesterday and it's working pretty well. There are a few error handling and logging issues to resolve but that shouldn't take too long and then getting the driver package build properly ....
John
JohnAd is offline
post #135 of 9353 Old 02-27-2012, 01:01 AM
JohnAd's Avatar
OK, I'll look at adding it, A meter re-init only should be required.
John
JohnAd is offline
post #136 of 9353 Old 02-27-2012, 01:45 AM
ascl's Avatar
I have this exact meter, and can confirm it works in with Argyll and hence will be supported.
ascl is offline
post #137 of 9353 Old 02-27-2012, 04:24 AM - Thread Starter
zoyd's Avatar
Liked: 1064
Good plan, thanks for the info on the mac version.
zoyd is offline
post #138 of 9353 Old 02-27-2012, 02:42 PM
JohnAd's Avatar
i1 Display Pro
ColorMunki Display
For sake of clarity, the CalMan edition of the meter means the i1Display3 OEM edition not the C6. According to the argyllcms list the C6 is apparently not supported at the moment.
John
JohnAd is offline
post #139 of 9353 Old 02-27-2012, 05:41 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
For sake of clarity, the CalMan edition of the meter means the i1Display3 OEM edition not the C6. According to the argyllcms list the C6 is apparently not supported at the moment although it may be in the future if Graeme Gill can get access to one.
John
I bought my OEM version from Tom with Chromapure and it works perfectly with argyll. So I propose dropping the reference to Calman and just say 'OEM' to cover both.
I'm very happy to see this project underway. I recently sent off my old LT to a friend and had a nightmare of a time creating offsets between Chromapure and HCFR.
fahrenheit is offline
post #140 of 9353 Old 02-27-2012, 06:35 PM
Bluescale's Avatar
Quoted: 736 Post(s)
Liked: 301
Thanks. I just ordered this today. Should have it in hand tomorrow. I'm really looking forward to the code release.
post #141 of 9353 Old 02-27-2012, 06:38 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
just wondering why you bought the i1 display pro instead of the colomunki display?
from what's being said here, the colormunki display is a spectrometer and should be a better choice?
just curious.
thanks
smokarz is offline
post #142 of 9353 Old 02-27-2012, 06:46 PM
Bluescale's Avatar
Quoted: 736 Post(s)
Liked: 301
just curious.
thanks
The colormunki is not a spectrometer. It's essentially identical to the Display 3. The main difference is speed of measurements, especially dark readings. I have no idea just how much slower (I'm not putting too much faith in the 1 reviewer who said it took only 2x longer than the Display 3), so I figured I'd spring for the extra cash. Yes, I'm probably throwing money into the wind...
post #143 of 9353 Old 02-27-2012, 07:04 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
ah i see. looks like i got my information wrong.
smokarz is offline
post #144 of 9353 Old 02-27-2012, 10:31 PM
ascl's Avatar
No not really... I find it confusing too. There are two products:
http://xritephoto.com/ph_product_overview.aspx?ID=1115
and
http://www.xrite.com/product_overview.aspx?ID=1513
which are very different (photo/design is spectro, display is not).
ascl is offline
post #145 of 9353 Old 02-27-2012, 10:42 PM
Bluescale's Avatar
Quoted: 736 Post(s)
Liked: 301
and
I doubt the ColorMunki Photo will compare with the Display3 in low light reading ability. For publishing work, where you need to calibrate your monitor and printer both, the ColorMunki Photo is a great product. For display calibration, I'm pretty sure the Display3 or ColorMunki Display will best it.
post #146 of 9353 Old 02-27-2012, 11:15 PM
JohnAd's Avatar
Thanks for that, you're probably right i1Display3 OEM is likely correct, I'm just worried about making unconfirmred claims of support.
John
JohnAd is offline
post #147 of 9353 Old 02-28-2012, 06:15 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Hi John, any update on a 'test ready' release?
I should be purchasing a colorimeter later this week. Thanks
smokarz is offline
post #148 of 9353 Old 02-28-2012, 06:36 AM
JohnAd's Avatar
There's a few signing wrinkles with the driver and a couple of bugs to sort out but nothing major, probably be ready Thursday/Friday.
John
JohnAd is offline
post #149 of 9353 Old 02-28-2012, 07:16 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
John
That's great. Looking forward to it.
Can we still use the existing guide to perform calibration with the updated HCFR program? Or will there be a need for a new guide?
http://www.curtpalme.com/forum/viewtopic.php?t=10457
smokarz is offline
post #150 of 9353 Old 02-28-2012, 07:25 AM
JohnAd's Avatar
Anything related to setting up the meter will change but the rest of it should be fine.
John
JohnAd is offline
Reply Display Calibration
