4K resolution and calibration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-24-2012, 12:30 PM - Thread Starter
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
With the advent of 4k resolution displays coming up, how will this affect today's meters and sw. I understand that the generators will have to change to produce the video patterns at 4k. Will there be a need for new meters and SW?
avsform1 is offline
post #2 of 8 Old 02-24-2012, 12:37 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Nah the software really doesn't care about resolution at all.
Same goes for meters, they have no concept of pixels, they just read the incoming light.
But yes you'll need a 4K source.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 8 Old 02-24-2012, 12:55 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Sotti, how does the source effect the calibration. Say the BR is set to 480 by accident on a 1080 display?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 8 Old 02-24-2012, 02:28 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Sometimes it doesn't, sometimes it does.
All depends on the TV's internals.
There is also the colorspace issue for YCC encoding between rec.601 and rec.709
Joel Barsotti
SpectraCal
sotti is offline
post #5 of 8 Old 02-24-2012, 02:41 PM
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
I'd say that's one of the main concerns between 480i/p (SD) and 720p/1080i/p (HD).
Also, for a 480p DVD movie would it matter whether the player or the display was doing the upscaling to 1080p?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #6 of 8 Old 02-24-2012, 03:07 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Let me rephrase my question.
If I have my BR resolution set to 480p using the HDMI connection and I am playing the AVS disk for Gray scale and Gamut readings, will there be a difference in meter readings compared to outputting 1080p?
Doug
post #7 of 8 Old 02-24-2012, 04:00 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Depends on your TV.
Joel Barsotti
SpectraCal
sotti is offline
post #8 of 8 Old 02-25-2012, 09:47 AM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
Actually, a 4K source (test pattern generator) isn't really necessary... yet. Or possibly ever, though "it depends" on whether a 4K video system that doesn't exist today has a different color space than HDTV or a different aim point than d65.
Normal HD test pattern generators are fine since the display will upconvert HD to 4K. If the display has separate memories for different input resolutions, you'd have to copy the HD-derived cal settings to the 4K memory but they would be the same if the color space for 4K is the same as the color space for HD.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
Reply Display Calibration
