What factors would cause red to be oversaturated and tend towards pink ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-29-2012, 07:14 AM - Thread Starter
chunon's Avatar
Quoted: 2019 Post(s)
Liked: 1777
Samsung 51D530 Plasma, can anything be done to rectify this without a meter and software ?
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #2 of 5 Old 02-29-2012, 07:20 AM
gremmy's Avatar
By oversaturated do you mean too bright?
Usually when people say oversaturated, I think of a primary that is too far out on the CIE color diagram. But it is also sometimes used to refer to how bright the color is.
If red is showing pink, it seems to me that it would be undersaturated on the CIE color chart.
It's hard to comment without more info...
You might try raising the gamma, if you can, to see if that makes any difference...
gremmy is offline
post #3 of 5 Old 02-29-2012, 07:23 AM - Thread Starter
chunon's Avatar
Liked: 1777
Thanks for the quick response, I apologize if my terminology is not correct, yes red appears to bright and has a pinkish hue. By raising Gamma do you mean gamma controls on the set itself ? Samsung has a control that goes from -3 to +3 would that mean an adjustment towards the negative or positive ?
65C6 OLED
post #4 of 5 Old 02-29-2012, 10:10 AM
Dark Rider's Avatar
It could be slight undersaturation, but assuming your grayscale is fairly accurate, it is more likely your hue setting for red that is causing you to shift toward magenta and blue, resulting in a pink cast. Can you detect any particular color cast in grayscale? As gremmy indicated, I'd venture your red luminance is too high. Adjusting gamma will impact all of your colors, not just red, but may be your only option if you don't have a 3D CMS.
Dark Rider is offline
post #5 of 5 Old 02-29-2012, 10:59 AM - Thread Starter
chunon's Avatar
Liked: 1777
Yeah no CMS on this set. I'm going to give the gamma adjustment a try see what effect that has. Thanks for the feedback.
65C6 OLED
Reply Display Calibration
