Discus and CalMan 3.6 or 3.7 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-04-2012, 07:29 AM - Thread Starter
DigitalKnight's Avatar
I can not get the Discus to show up under the CalMan 3.6 or 3.7 select meter option. My OTC-1000 shows up and works fine.
Does the Discus only work with 4.x CalMan?
DigitalKnight is offline
post #2 of 5 Old 03-04-2012, 07:48 AM
Rayjr's Avatar
Quoted: 187 Post(s)
Liked: 225
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
I think the Discus only works under CalMAN 4.X
RayJr
Rayjr is offline
post #3 of 5 Old 03-04-2012, 07:49 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Hey DK, you know, you could have just profiled the OTC with your i1pro and got the job done today. Or doesn't the 3.x version have profiling?
You may want to post this question on the spectracal forum as well. http://www.spectracal.com/forum/inde...ea7240dae4819d
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 5 Old 03-04-2012, 08:19 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
The Discuss is will only work in the 4.x line.
You can profile a meter in 3.x, but you have to create two cdf documents with gamut runs in order to get the data in.
sotti is offline
post #5 of 5 Old 03-05-2012, 04:54 PM - Thread Starter
Thanks everyone, looks like I will have to update then.
Reply Display Calibration
