Please Help? Color Setting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-04-2012, 09:46 AM - Thread Starter
LanceX's Avatar
Quoted: 109 Post(s)
Liked: 35
I have the Disney WoW, and Im not sure if I did the Color setting correctly.
I have the samsung PN59d550
I calibrated on Standard setting, and I got cell 18 , cont 95 , bright 51, sharp 20, gamma 0
Also using Warm 1
but my color setting it says with the blue filter all the colors should be the same shade/brightness as eachother.
To get that I have Color set at 40. tint 50/50
Is that an odd number for color? most people leave it 47-50 right?
but when I put it to 50 the picture with the bright oranges have a haze of orange around them and when its 40-43 the haze is gone.
I mean the colors still look really good at 40. I was just curious if 40 is way too low or odd?
LanceX is offline
post #2 of 5 Old 03-04-2012, 11:20 AM
donnymac51's Avatar
Instead of using the color filters which can be inaccurate you should use the RGB mode of your display.
Precision Video Calibrations
THX Certified Video Calibrator
Calibrating Florida and Georgia
donnymac51 is offline
post #3 of 5 Old 03-04-2012, 11:42 AM - Thread Starter
LanceX's Avatar
Quoted: 109 Post(s)
Liked: 35
same thing 40 color
do the entire bar have to be same color as others?
meaning the long bar then the small section undernearth
the white long and small blue piece all have to match right?
LanceX is offline
post #4 of 5 Old 03-04-2012, 11:54 AM
Chad B's Avatar
Quoted: 544 Post(s)
Liked: 1309
Standard mode may have some dynamic enhancements programmed in that could mess up your color calibration. They may be there even if you turned the enhancements off. In other words, it might increase or decrease color on the fly depending on the signal, which means test patterns might behave differently than real program material. Try calibrating movie mode instead; it strips away those artificial enhancements. In movie mode I believe you'll find a calibrated setting around 50 that will look good with material as well.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #5 of 5 Old 03-04-2012, 11:59 AM - Thread Starter
LanceX's Avatar
Quoted: 109 Post(s)
Liked: 35
i dont like movie mode in gaming but i did turn everything off. Im currently using 45 color and it looks nice. just curious if it being under 50 is normal
LanceX is offline
Reply Display Calibration
