Sencore VP403 - firmware update - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-07-2012, 01:11 AM - Thread Starter
dmanaudio's Avatar
well after several emails not returned from sencore, figured i would ask on here.. I need the most current firmware update for a sencore VP403 generator... No luck finding anything. Any help would be appreciated.. I still use the unit (though not very much at all), but would like as current as it can get since i still have original firmware version on it.. thanks
dmanaudio is offline
post #2 of 16 Old 03-07-2012, 04:38 AM
Rayjr's Avatar
Quoted: 188 Post(s)
Liked: 225
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
If you post what version it is........I may be able to help?
Later
RayJr
Rayjr is offline
post #3 of 16 Old 03-07-2012, 10:32 AM - Thread Starter
dmanaudio's Avatar
Later
RayJr
1.61s
post #4 of 16 Old 03-07-2012, 11:02 AM
Rayjr's Avatar
Quoted: 188 Post(s)
Liked: 225
Originally Posted by dmanaudio View Post
1.61s
Latest version of FW is 1.73...contact sencore and they should be able to get you the update.
RayJr
Rayjr is offline
post #5 of 16 Old 03-07-2012, 11:17 AM
turbe's Avatar
Liked: 97
I believe SpectraCal is now handling support for the VP403 and not Sencore.
You want to contact SpectraCal's Pro Support.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #6 of 16 Old 03-07-2012, 11:18 AM - Thread Starter
dmanaudio's Avatar
RayJr
Thanks Ray... Ive sent them probably 4-5 emails through their contact, and trouble ticket system... and have not got a single response.. I guess i can try calling them.. last time i called them i wanted to get my otc1000 recal'ed and i didnt get a call back until a week and half later.... Hell by then, i ran accross a new one on a deal, and just bought it, lol....
post #7 of 16 Old 03-07-2012, 11:21 AM - Thread Starter
dmanaudio's Avatar
i sent Jared a email also, havnt heard back from him
post #8 of 16 Old 03-07-2012, 11:23 AM
turbe's Avatar
Liked: 97
try these numbers for them: 877-886-5112 or 605-271-7959
ControlCAL™
turbe is offline
post #9 of 16 Old 03-07-2012, 11:53 AM
jamiemiller's Avatar
ray is correct, the current version is 1.73s. It can be updated via rs 232, the main item that was updated was a split gray pattern.
When sencore built that unit it maxed out at 1080p23 resolution, after that they revised the unit with a different main board to give it the range to work with 1080p60.
I am tracking down the update files right now, in the mean time you can email me at support@spectracal.com
Jamie Miller
Spectracal Technical Support
1-605-271-7959
jamiemiller is offline
post #10 of 16 Old 03-07-2012, 12:09 PM - Thread Starter
dmanaudio's Avatar
Jamie Miller
1-605-271-7959
Jamie, i sent you a email... thank you sir.
post #11 of 16 Old 03-07-2012, 12:25 PM
http://dl.dropbox.com/u/23684910/VP4...%20Upgrade.zip
the update package above includes instructions for how to update the unit, if you have questions let me know.
post #12 of 16 Old 03-07-2012, 01:00 PM - Thread Starter
dmanaudio's Avatar
HOLY CRAP.... ive been trying to get information for weeks, emails to sencore, no replies, calls, etc.. etc... etc.... searches on the net, etc. etc.etc..
Been a member here for a year (i mainly like to read), finally decided to post a question, and all my headaches and hassles were solved within a 24 HR. period... Jamie, i appreciate you!!! this simple thing right here that was done convinces me SpectraCal is one top notch company to deal with... and will be getting any of my future business regardless...
post #13 of 16 Old 03-07-2012, 04:40 PM
Citation4444's Avatar
Quoted: 186 Post(s)
Liked: 146
I used this to update my VP403 from 1.72s to 1.73s, but I wasn't able to get the included terminal program to run in W7 64bit. I booted into W7 32bit and it ran fine. I expect there is a terminal program in W7 64bit that can be used instead?
Bob
Citation4444 is offline
post #14 of 16 Old 03-07-2012, 04:49 PM
Rayjr's Avatar
Quoted: 188 Post(s)
Liked: 225
dmanaudio.....Jamie is the MAN...thats who I called to get you info
Thanks for posting Jamie
Later
RayJr
Rayjr is offline
post #15 of 16 Old 03-08-2012, 06:25 AM
http://www.hilgraeve.com/hyperterminal/
this is the terminal that used to be included in windows, 30 day free trial
It works on all versions of windows, its pretty similar to the terminal program that is in that download.
post #16 of 16 Old 03-08-2012, 07:58 AM
derekjsmith's Avatar
Liked: 116
Jamie, thank you for getting on top of this and sorting it quickly. We very much appreciate the work you do for us
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
Reply Display Calibration
