i1 pro - is calibration base needed? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-08-2012, 01:12 PM - Thread Starter
absolootbs's Avatar
Quoted: 18 Post(s)
Liked: 27
can someone tell me whether or not the included calibration base (the one with the matching serial number) is needed when using an i1 pro for tv/projector calibration with hcfr?
absolootbs is offline
post #2 of 13 Old 03-08-2012, 01:38 PM
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1521
You need the calibration plate to initialize your i1pro before each calibration session and for taking dark reading measurements every 10 min required for optimum accuracy.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #3 of 13 Old 03-08-2012, 01:52 PM - Thread Starter
absolootbs's Avatar
Quoted: 18 Post(s)
Liked: 27
so the numbers matching base for the i1 pro essentially serves the same purpose that "any old dark surface" does for the display 2/lt then?
post #4 of 13 Old 03-08-2012, 04:38 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
HCFR does not activate the internal lamp of the i1 Pro so the chip in the base serves no purpose. Using a black surface for initialization is sufficient.
Larry
LarryInRI is offline
post #5 of 13 Old 03-08-2012, 04:47 PM
rmongiovi's Avatar
Quoted: 27 Post(s)
I suspect you need the base if you ever run the i1 diagnostics, but you shouldn't need it otherwise. Anything that blocks out all light will work when taking a dark reading.
rmongiovi is offline
post #6 of 13 Old 03-08-2012, 07:26 PM
ZandarKoad's Avatar
So, what's the fastest method for taking a dark reading with the i1Pro? I can imagine it's faster if the meter isn't on the surface of the display.
Anyone out there come up with a push button method or something very very quick and very very easy?
ZandarKoad is offline
post #7 of 13 Old 03-08-2012, 07:53 PM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Yes indeed - right here. I have one. X-Rite #A-H/EOB
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is online now
post #8 of 13 Old 03-08-2012, 08:37 PM
ZandarKoad's Avatar
Does it have a shutter or something?
post #9 of 13 Old 03-08-2012, 08:42 PM
yuxiaoyaowei's Avatar
This is also the question of mine
yuxiaoyaowei is offline
post #10 of 13 Old 03-08-2012, 08:52 PM
buzzard767's Avatar
Liked: 2393
Yes. You can see it here. Select "Features" and click on the picture to enlarge it and see the shutter tab.
Buzz
post #11 of 13 Old 03-08-2012, 10:15 PM
ZandarKoad's Avatar
OK, now I see it. It looks like a manual slider shutter. For $150 it should actuate itself by reading my mind...
It also looks like the shutter has a big hole in it! LOL I'm sure it's immaterial.
post #12 of 13 Old 03-09-2012, 08:44 AM
derekjsmith's Avatar
Liked: 116
The i1Pro only needs the serial numbered base plate for dark calibration when doing a reflectance (internal lamp) measurement or running diagnostics.
It does not have a shutter, wished it did. So you will need to run a dark cal every 10 minutes or so to account for internal sensor drift. Does this mean you get bad readings after 10 minutes no. But they do start to drift especially on the lower end.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #13 of 13 Old 03-09-2012, 09:23 AM
buzzard767's Avatar
Liked: 2393
Some of you might find this little "study" interesting.
http://www.avsforum.com/avs-vb/showt...ighlight=i1pro
Buzz
Reply Display Calibration
