Help with TC-P55ST30 calibration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 03-12-2012, 10:14 PM - Thread Starter
chrisp9446's Avatar
I've been working on calibrating my 55ST30 and have come across a couple problems, so any advice would be appreciated. I'm certainly not an expert, but I would like to get the picture the best I can, so let me know anything you think I can do to improve it.
Setup:
i1 Display 3 colorimeter
CalMAN v4
GetGray DVD
OPPO BDP-80 --HDMI--> H/K AVR-254 --HDMI--> TC-P55ST30 (>200hrs)
The OPPO is set to upscale to 1080p and output YCbCr 4:2:2, and the receiver is set to pass-through.
Two issues that are apparent to me:
* I've been toying with a day (custom) and a night (cinema) mode, but can't seem to get enough luminance out of these modes. I've seen some other calibrations with a 47ftL day mode and 35ftL night mode, but I'm around 30ftL and 23ftL, respectively.
* I seem to have a severe issue with green luminance. Is this how the "green blob" manifests itself when looking at it with an instrument? Is an external VP the only solution for this? Any chance Panasonic would accept that it's a defect?
Graphs, etc. to follow.
Thanks for any and all help!
chrisp9446 is offline
post #2 of 25 Old 03-12-2012, 10:15 PM - Thread Starter
chrisp9446's Avatar
Cinema mode (night)
Contrast - 60
Brightness - 57
Color - 50
Tint - 3
Warm2
HDMI mode -- graphics
I did the calibration in the service menu using rcut/rdrv and bcut/bdrv. The exact values won't really be of any help, but can post them if needed.
With any contrast above 60, there was no impact on luminance or anything else.
post #3 of 25 Old 03-12-2012, 10:15 PM - Thread Starter
chrisp9446's Avatar
Custom mode (day)
Contrast - 75
Brightness - 57
Color - 52
Tint - 2
Gamma - 2.2
Normal temp, but changed normal settings to match warm settings in service menu as a baseline.
Brightness - Mid
High R - -2
High G - 0
High B - 9
Low R - 3
Low G - 0
Low B - -2
I settled on a contrast of 75 because above that, I would gain ~5ftL, but get a horrendous gamma curve, especially at 80IRE and 90IRE.
post #4 of 25 Old 03-13-2012, 10:19 AM
gremmy's Avatar
After following the ST30 thread over in the plasma forum, doing my own calibration (similar to yours), and talking to several owners and at least one calibrator, I've come to the conclusion that the people getting 47 ftL on these sets are taking their measurements on a smaller window pattern. The smaller window is brighter because there is less ABL. Your set is just as bright as mine. I get 33 ftL on Mid Panel brightness with an almost perfect calibration using the standard window patterns on the AVS HD 709 Test Disc.
My television suddenly seemed to get a lot brighter (although max white did not increase in ftL) when I fixed the high end gamma with my video processor. On my set there was a dip around 70 or 80 IRE and then a flight to the stratosphere at 90 that really made the bright scenes look dull, lifeless and dim.
The overly bright green primary is present on my set is well. It can only be fixed with an external video processor. I purchased a used Lumagen HDQ which allowed me to dial in my colors just about perfect. It also helped with the nasty humps in gamma and made my grayscale even cleaner.
And no, the overly bright green primary is not related to the green blob. The green blob is a panel uniformity issue. So far I do not have it.
gremmy is offline
post #5 of 25 Old 03-13-2012, 11:08 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
The following report is from an ST30 I did last fall. Output was about 35fL using Accupel window patterns and it had zero green issues.
Perhaps your set is defective.
Schlapi ST30ReducedSize.pdf 448.3984375k . file
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #6 of 25 Old 03-13-2012, 11:33 AM - Thread Starter
chrisp9446's Avatar
Thanks for the comments. Yeah, I have been following your trek to get your set in shape and it looks like you did finally get everything in line with the VP. I wish (probably like you did) that there was some easy/cheap way to just alter the green primary without having to get a video processor (a pipe dream, I know). I'm pretty happy with my grayscale, though the more I look at your results, the more tempting the Lumagen becomes .
That's good to hear about the light output; I wasn't sure how on earth I was supposed to be able to get an extra 15ftL out of it.
post #7 of 25 Old 03-13-2012, 11:41 AM - Thread Starter
chrisp9446's Avatar
Thanks for sharing the report; everything there looks really good!
To go with the extreme green luminance, I also notice some green ghosting in some dark areas of 3D images. Not sure if that is related, but it is also unfortunate.
Where in the set is the color decoding done? Would there be a chance of getting a repair (i.e. replace a board) from Panasonic on that, or would that generally require replacement of the TV? (I know the true answer lies with Panasonic, whom I'll approach, but wasn't sure how best to approach them).
post #8 of 25 Old 03-13-2012, 12:01 PM
gremmy's Avatar
I'm not sure, but if you can get them to repair the set to correct an overly bright green primary, that would be of great interest to a lot of people. Somehow I expect they are going to tell you that the set is operating within accepted tolerances, since many people do have an overly bright green primary (some don't, but a lot do).
gremmy is offline
post #9 of 25 Old 03-13-2012, 08:02 PM - Thread Starter
chrisp9446's Avatar
I'm not sure, but if you can get them to repair the set to correct an overly bright green primary, that would be of great interest to a lot of people. Somehow I espect they are going to tell you that the set is operating within accepted tolerances, since many people do have an overly bright green primary (some don't, but a lot do).
I submitted a service request, so I'll let you know what I hear back. I'd tend to agree that they'll probably brush it off, but it can't hurt to ask since it is so far off from correct.
post #10 of 25 Old 03-14-2012, 08:11 PM
themoth33's Avatar
Chad b just dd my 65 st30 and will post my report for you to compare. He was able to do a day, night and the 3d. 3d was the worst and most improved compared to night. Day came out great too
themoth33 is offline
post #11 of 25 Old 03-19-2012, 05:26 PM - Thread Starter
chrisp9446's Avatar
Well, they're going to send someone out to see if they can fix it.
Does anyone know of a good movie or other program that would be best for showing off the high green luminance, in case the Panasonic person isn't completely convinced? I have a couple ready, but would like to show the worst case scenario, if one exists.
post #12 of 25 Old 03-21-2012, 10:02 AM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1773
Cinema mode (night)
Contrast - 60
Brightness - 57
Color - 50
Tint - 3
Warm2
Would you mind pm'ing the SM values ?
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #13 of 25 Old 03-23-2012, 07:29 AM
gremmy's Avatar
Green push is a hard thing to pin down without a meter. What I noticed was that it was very hard to get flesh tones to look right. Unfortunately, this is unlikely to convince a technician.
I'd just show him the calibration report, formatted to draw attention to the green primary delta. I doubt he'll have any clue what it means, so be prepared to sell him on it.
gremmy is offline
post #14 of 25 Old 03-23-2012, 07:43 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Cinema mode (night)
Contrast - 60
Brightness - 57
Color - 50
Tint - 3
Warm2
Never worked on one of these, but for some reason that mode = graphics seems like a big old red flag waving..Can anyone explain what that is doing and why it would be in a graphics mode when doing a video calibration? Graphics say PC to me.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #15 of 25 Old 03-23-2012, 08:09 AM - Thread Starter
chrisp9446's Avatar
I agree it's tough because most of the time, unless you know what something's supposed to look like, it's hard to tell. It just doesn't look right.
That's going to be one of the things I use -- showing the +60% green primary luminance. I'm also going to show a couple of shows where faces actually do have a visibly green tint on the sides and a 3D program that exhibits the green ghosting.
post #16 of 25 Old 03-23-2012, 08:10 AM - Thread Starter
chrisp9446's Avatar
I experimented with all of the HDMI modes (I believe off, auto, photos, and graphics) and graphics had the smoothest gamma and most accurate grayscale to start with. I checked the color gamut with all four of the modes and found that there was essentially no difference between them on that front.
post #17 of 25 Old 03-23-2012, 03:12 PM - Thread Starter
chrisp9446's Avatar
The authorized service place nearby came over this afternoon to look at the set. He couldn't really notice the green tint to faces, but definitely noticed the green ghosting in 3D. After him talking to Panasonic, they're going to try to replace the SC board first. It's apparently going to "be a long process" if that doesn't work, because they'll replace another board, then replace the panel, etc. before finally replacing the set. I'll let you know how it goes.
Anyone know what the SC board is for?
post #18 of 25 Old 04-03-2012, 03:09 PM - Thread Starter
chrisp9446's Avatar
They came out and swapped the SC board. It didn't change anything (the repair guy was not surprised), so they're going to replace the A board next.
post #19 of 25 Old 04-11-2012, 05:34 PM - Thread Starter
chrisp9446's Avatar
The tech came out and replaced the A board and it still didn't fix the problem. He then raised VSUS from low to high (via Panasonic's instructions) to see if it had any impact, but it did not. He called Panasonic and they were confused and solution-less, so they asked for pictures.
I was able to take some pictures of what the green ghosting looks like in 3D - 3569 is through the left glasses lens and 3572 is without the glasses.
post #20 of 25 Old 04-12-2012, 06:14 AM
chunon's Avatar
Liked: 1773
Wow that is pretty noticeable, I have the same set as you and havent seen anything like that so far.
65C6 OLED
post #21 of 25 Old 07-30-2012, 02:42 PM - Thread Starter
chrisp9446's Avatar
So, after replacing the A board, SC board, SS board, V board, and sending pictures of the problem, Panasonic finally agrees that there's a problem. Three months later, they're now going to replace the set. Let's hope that this next one works right!
post #22 of 25 Old 09-03-2012, 11:08 PM
finedots's Avatar
I'm having a serious problem watching DVDs on this TV. I'm not talking about Blu-rays, just standard DVDs. Basically, the TV is processing too much of the content and is stripping away the movie's cinematic effects. When I watch a movie, it looks too clean, like I'm watching the pre-production rushes. I've calibrated the TV to my best of my abilities by following these and other threads and I have nothing but positive comments to make about the watching HDTV or online content, but DVDs are ruined for me. Can someone please help me with the settings to help return the TV to a minimal processing operations.
Many many thanks.
finedots is offline
post #23 of 25 Old 09-04-2012, 02:02 PM
chunon's Avatar
Liked: 1773
Many many thanks.
I have the same set no problem with upconverted dvd's. Do you have motion smoother on ? Is 24fps enabled ?
65C6 OLED
post #24 of 25 Old 09-05-2012, 11:45 AM
finedots's Avatar
I changed the motion smoother setting to off under the cinema picture setting but I couldn't change the 24 fps (not that I needed to as it was grayed-out on 24fps). So far, the picture looks much better. I'll give it a try tonight under darker conditions. Thank you for your help. This was immensely helpful.
finedots is offline
post #25 of 25 Old 09-05-2012, 12:48 PM
chunon's Avatar
Liked: 1773
You are welcome sure sounded like SOE(Soap Opera Effect), it baffles me that they added that as a "feature" on Plasma just to compete with LCD.
65C6 OLED
Reply Display Calibration
Panasonic Viera Tc P55st30 55 Inch 1080p 3d Plasma Hdtv
