how to enter 10 point gamma 65vt30? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-20-2012, 10:01 AM - Thread Starter
gtwizard's Avatar
how to enter 10 point wb and gamma?
gtwizard is offline
post #2 of 8 Old 03-20-2012, 10:16 AM
wyen78's Avatar
I don't have this tv but I looked it up. Go to ISFccc mode in the setup menu.
wyen78 is offline
post #3 of 8 Old 03-20-2012, 10:34 AM - Thread Starter
gtwizard's Avatar
im in setup but i dont see isf
gtwizard is offline
post #4 of 8 Old 03-20-2012, 10:54 AM
Chad B's Avatar
Quoted: 494 Post(s)
Liked: 1181
You have to interface a computer with the TV. I personally use a serial connection and ControlCal and/or CalMAN software. You can also use a cat-5e or similar LAN cable with CalMAN if you configure it right.
BTW, the VT30's 10 pt and CMS adjustment is difficult to say the least.
Chad B is online now
post #5 of 8 Old 03-20-2012, 01:44 PM
turbe's Avatar
Liked: 95
ControlCAL G/VT30 Edition v2 can also use the Network Interface on the VT30's.. I do recommend the serial interface for calibration though....
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #6 of 8 Old 03-20-2012, 03:06 PM
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
Is this an intentional design?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #7 of 8 Old 03-20-2012, 05:23 PM
Chad B's Avatar
Quoted: 494 Post(s)
Liked: 1181
Yes, it was designed that way.
post #8 of 8 Old 03-28-2012, 08:35 PM
Lirad's Avatar
I just calibrated my 65VT30 and I was able to adjust both W/B and Gamma 10 points in the non-SM menus. I think the VTs have the Pro settings while some of the other models do not.
Go into Menu -> Picture -> Pro Settings
10 Point W/B is located in the W/B detail adjustment menu
10 Point Gamma is located under Gamma detail adjustment
For both menus the Input signal level defines which of points you are adjusting (10IRE-100IRE).
Does this help you? I am a newbie, so it is possible that I did it wrong too. My picture looks fantastic though!
Lirad is offline
Reply Display Calibration
