For those who recommend turning sharpness to 0 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #61 of 66 Old 04-05-2012, 01:14 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
According to the AVS 709 Manual
http://dl.dropbox.com/u/8968806/Patterns-Manual.pdf
Page 3 top right screen shot of pattern, description is "Black Clipping" But is used like a pluge as it is for setting brightness. Unlike the standard Pluge I have seen on other disk, this pattern will display bars from 0-25 which will flash for easy viewing.
When using it for sharpness, you have already set brightness so there is nothing visible below video black. When you turn up sharpness you will see thin white lines around the where the bars from 0-25, but it is very obvious in the 0-16 area where there should be nothing but blackness. This is assuming the set you are looking at reacts like the ones we have talked about. Hope that makes it clearer.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #62 of 66 Old 04-05-2012, 01:18 PM
goku14139268520's Avatar
Thanks for the info.
goku14139268520 is offline
post #63 of 66 Old 01-05-2015, 03:54 PM
shield1280's Avatar
Quoted: 319 Post(s)
Liked: 69
My sharpness setting is at +8,but i needed to use teds disc to see where the sharpness should be at,DVE or Spears and Munsli did have no effect and till i hit +70 then i could see the white lines.
ConnecTEDDD likes this.
LG B6 55 inch-Panasonic TX-P55VT60Y-Klipsch RF-62 Mk1-Onkyo TX-NR616-Samsung UBD-K8500-Sony BDP-S6500-Pioneer BDP-120-Xbox 360 250GB-X Box One 500GB
shield1280 is online now
post #64 of 66 Old 08-06-2015, 08:42 PM
brad1138's Avatar
Quoted: 56 Post(s)
Liked: 24
Sorry to resurrect this old post, but all that is needed is "a bunch of black lines on a medium grey background" shouldn't we be able to just download a jpeg of said lines and view it off of USB or whatever to do this calibration?
EDIT: Tried it, for whatever reason, I can't adjust focus when viewing JPEGs...
Home Theater: Emotiva UMC-200, Citation 5.1 running Mirage M-3SIs, Harman Kardon signature 2.1 running Mirage M-CSI (center) & 4x BIC V-52 (surrounds), 2 x Velodyne ULD 15 Series II Sub & Amp, PS3, PS4, XBOX 1, 2x Adcom ACE-515, Vizio E-701B-3
2.0 setup: Acurus LS11, Citation 5.1, Mirage M3SIs, Onkyo DV-CP702 (CD transport), Schiit Modi Multibit DAC.
brad1138 is offline
post #65 of 66 Old 10-12-2015, 09:59 AM
Liked: 0
putting sharpness to 0 is insane. why artificially dull your image? would you set color, brightness or contrast to 0?
i see so called reviewers at major websites putting sharpness to 0. they have no idea how to set properly the tv's they review
coffee table is offline
post #66 of 66 Old 10-14-2015, 04:16 PM
buzzard767's Avatar
Quoted: 1619 Post(s)
Liked: 2394
There have been a few displays over the years that have a "softening" feature but for most displays the correct setting is 0.
Once upon a time a manufacturer added a Sharpening Control which did nothing to improve the picture but did a little to help their financial bottom line via this new marketing gimmick. The next year, all TVs had a Sharpening Control. The end.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
Reply Display Calibration
