Very low value foot lambert in non-dedicated room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-30-2012, 02:48 AM - Thread Starter
kyokushinkai's Avatar
Hello friends.
Let them the following question:
I only managed to obtain a value of 100% IRE white of 8 foot lambert
Why I can not get a higher value to calibrate my projector?
Could it be because the walls and ceiling of my room are white?
In black Batcave could increase this value to 12 or 16 foot lambert
Thank you very much
kyokushinkai is offline
post #2 of 6 Old 03-30-2012, 05:31 AM
BobL's Avatar
Liked: 56
Your room conditions aren't going to change the light coming from your projector. If the lights are off and you are only getting 8 foot lamberts on your screen, that is the most you are going to get.
Turning on the lights or white walls/ceiling might raise your foot lamberts as more light is hitting the screen but that is not the light you want. The white walls or ambient light is what hurts ANSI contrast. A bat cave will not raise the foot lamberts but will help ANSI contrast.
Are you using a 100ire window or field pattern for the measurement? It should be a field for this measurement. That can cause a bit of a discrepenancy, depending on the meter you are using.
How big is your screen? What gain? What projector?
BobL is offline
post #3 of 6 Old 03-30-2012, 05:52 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Put your read on continuous and change the meter's aim at the center of the screen until you get the maximum light measurement. Calibrate from there.
The difference in aiming points can be huge.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #4 of 6 Old 03-30-2012, 06:30 AM
Gregg Loewen's Avatar
Quoted: 22 Post(s)
Liked: 68
what tool are you using for measuring?
President, Lion Audio Video Consultants Inc.
Lead THX Video Standards Instructor
Gregg Loewen is online now
post #5 of 6 Old 03-30-2012, 07:08 AM - Thread Starter
Hello
I used a pattern for measurement window 100% white.
Screen 106 ", gain 1.1 and Optoma DLP HD80
Thank you very much.
post #6 of 6 Old 03-30-2012, 07:13 AM - Thread Starter
Hello
I use CromaPure and eye one display 2
It is clear that my views are not correct.
Thank you very much
Reply Display Calibration
