Quality of still images from dslr on 110"screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-31-2012, 04:47 AM - Thread Starter
ruszkowski's Avatar
Hi, I am newbie here, have a great issue with disappointing picture quality of my photos from DSLR canon 60D 18MP (jpeg, max quality), MUCH worse than HD sattelite tv signal. Slideshow from iPhoto via AppleTV hdmi connected to one of the top Denon amplituners, again hdmi to Sanyo PLV z5; Bluray great, even 720 TV great and my photos look worse than SD. Anyone can help?
ruszkowski is offline
post #2 of 5 Old 03-31-2012, 05:47 AM
ADDUpstate's Avatar
Sounds more like a weak link in the chain of source than display problems.
I don't now anything about iphoto, but does that program compress images to save space, or does it have an output resolution setting?
ADDUpstate is offline
post #3 of 5 Old 03-31-2012, 07:07 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Just a guess here, but you may want to re-size one of those massive 18 MP image closer to what the TV can display "1920×1080" before displaying it.. i.e. Photo shop or other program that you can be sure the image is of the highest quality. Just do one you know looks bad and see if it looks better.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 5 Old 03-31-2012, 08:51 AM
rovingtravler's Avatar
Your photos are well above HDTV i.e 1920X1080 therefore they are being scaled down to the projector's resolution. Either thesending device (computer) or the Projector is doing the scaling. Many projectors are not capable of scaling such a large image correctly; their vid processor is not strong enough. I would suggest rescaling on the computer and outputting the corralated size to your projector.
Also look at the limits on apple TV if it is first gen video is limited to 720p... I am not sure what it does with photos of a higher res, but either way the chip in the Apple is not great at scaling... scale them on the computer then display them or try to send them without the apple TV in the middle.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #5 of 5 Old 04-01-2012, 11:03 AM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
All the settings required to get good looking moving images are required to make still images look good. The Sharpness control is PARTICULARLY damaging to the appearance of still photos. If you don't know how or have the tool needed to adjust the Sharpness control to its "Off" setting (which is not necessarily Zero) you need to get into AVS Forum threads that describe how to find the best settings and what tools are needed to allow you to find the best possible settings.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
Reply Display Calibration
