new i1pro 2 spectrophotometer - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 149 Old 05-03-2012, 03:04 PM
turbe's Avatar
Liked: 97
make sure to check the AVS classifieds, used ones pop up here and there..
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #62 of 149 Old 05-04-2012, 08:57 AM
derekjsmith's Avatar
Liked: 116
Originally Posted by PlasmaPZ80U View Post
What I mean is that you're currently selling it for $1029 on the SpectraCal site. Will the remaining stock be sold at a lower price before the inventory is completely emptied?
EDIT: Will the re-certified used i1Pro's be sold on the SpectraCal site directly?
Chances are we may run out of i1Pro Rev D before we get our stocking order of OEM i1Pro 2.
Not sure if we are going to sell the used recert i1Pro's directly on our store or put them up on eBay. I guess it depends on number we get for trade ins.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #63 of 149 Old 05-04-2012, 09:36 AM
ConnecTEDDD's Avatar
Quoted: 1559 Post(s)
Liked: 1999
Derek, are you ready to make an announcement about the OEM price / trade program / availability in stock?
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #64 of 149 Old 05-04-2012, 01:14 PM
Liked: 116
Should be the middle of next week once we have comfirmed our stocking order with X-Rite.
Derek
post #65 of 149 Old 05-05-2012, 08:37 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
I got hold of an i1pro 2 for some testing and did a quick comparison with my now 6 yr old i1pro. It works out-of-the-box with the ArgyllCMS drivers in legacy mode which doesn't include the new functions like accelerated readings.
The comparison with my i1pro shows it has lost ~8% overall luminance sensitivity (see attached) but dE drift is smaller than I expected. (The i1pro has never been recalibrated and has just been stored in it's original case under temperature controlled conditions)
dE w/i1pro 2 as ref 75% White Red Green Blue Yellow Cyan Magenta
CIE94 0.8 1.1 1.2 1.1 0.4 0.5 0.5
Luminance reduction: Yw=7.6%, Yr=10.6%, Yg=5.8%, Yb=3.0%
zoyd is offline
post #66 of 149 Old 05-06-2012, 04:21 AM
fallengt's Avatar
May I ask why do you use ArgyllCMS drivers instead of i1 pro driver ? does it give better results ?
fallengt is offline
post #67 of 149 Old 05-06-2012, 05:10 AM
zoyd's Avatar
Liked: 1064
zoyd is offline
post #68 of 149 Old 05-06-2012, 08:49 AM
subraman's Avatar
The ArgyllCMS driver includes the 3.33 nm sampling mode which does a better job of picking up the peaks in my plasma spectra.
When the device itself is limited by 10nm bandwidth, what difference would the software's sampling mode have to do with picking peaks in the spectra?
subraman is offline
post #69 of 149 Old 05-06-2012, 11:08 AM
zoyd's Avatar
Liked: 1064
If your sample spacing is the same as the instrument resolution you run into aliasing errors if the measured spectra has narrow spectral features. To avoid undersampling it's generally recommend to sample at least 1.2xNyquist = 2.4 samples per resolution element.
In this plot (measured with the i1pro 2) of the red primary on my display the red trace is at 3.33 nm sampling and the black trace is 10 nm sampling. You can see some energy is not accounted for at 620 nm and 700 nm. The chromaticity shifts for this case are not huge but I prefer to not have to worry about such shifts.
zoyd is offline
post #70 of 149 Old 05-06-2012, 11:11 AM
PlasmaPZ80U's Avatar
Quoted: 2233 Post(s)
Liked: 683
what software are you running?
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is online now
post #71 of 149 Old 05-06-2012, 11:18 AM
zoyd's Avatar
Liked: 1064
ArgyllCMS This is commandline software only, there is a gui front-end for monitor calibration here. The ArgyllCMS drivers and tools have been integrated into the new open source HCFR version currently being developed by JohnAD and others.
zoyd is offline
post #72 of 149 Old 05-06-2012, 11:33 AM
Liked: 683
so this approach would not work with CalMAN, ChromaPure, or the old ColorHCFR, correct?
post #73 of 149 Old 05-06-2012, 11:43 AM
zoyd's Avatar
Liked: 1064
Not with the older ColorHCFR but check with the other guys because they might have the "hires" mode for the i1pro available in their software.
zoyd is offline
post #74 of 149 Old 05-08-2012, 10:27 AM
subraman's Avatar
From the specs below, it appears that this is just an artifact introduced by X-Rite's data compression in their standard Spectral reporting. If the software can read the full 128 array data, you will be able to see the raw data with greater detail, including extensions into IR and UV regions. Doing this will not improve on the device's inherent bandwidth limitations, 10nm in this case. In all its internal calculations, it has to be using the entire data - it would be stupid not to.
I had speculated a while ago that Calman may be using this raw data (and averaging) in their low level enhancement for the I1-Pro.
Specs. i1PRO i1PRO2
Spectral Analyzer Holographic diffraction grating with 128-pixel diode array Same with i1PRO
Spectral Range 380 - 730 nm Same with i1PRO
Physical Sampling Interval 3.5 nm Same with i1PRO
Optical Resolution 10 nm Same with i1PRO
Spectral Reporting 380 ... 730 nm in 10 nm steps Same with i1PRO
Measurement Scan Frequency 200 measurements per second (Rev. D) Same with i1PRO
Measurement Range 0.2 - 300 cd/m2 on a typical LCD-Monitor 0.2 - 1200 cd/m2 on a typical LCD-Monitor
Short-term Repeatability x,y: +/- 0.002 typical (5000°K, 80 cd/m2) Same with i1PRO
Inter-Instrument Agreement 0.4 ∆E94* average, 1.0 ∆E94* max. Same with i1PRO
Short-term Repeatability 0.1 ∆E94* on white Same with i1PRO
subraman is offline
post #75 of 149 Old 05-08-2012, 11:16 AM
zoyd's Avatar
Liked: 1064
The two modes are different internally because the meter will report two different sets of X Y Z values on my display depending on mode, so there is a real measured offset between the two. The low res mode averages 3 samples together and reports at 10 nm intervals while the high res mode does no averaging and reports at 3.33 nm. I assume that they did this either to increase signal-to-noise ratio or allow for a "fast" and "slow" mode at the same SNR.
zoyd is offline
post #76 of 149 Old 05-08-2012, 12:33 PM
Liked: 1999
Can this feature for i1pro which is currently available using iProfiler 1.3 will be supported by CalMAN or ChromaPure?
post #77 of 149 Old 05-08-2012, 12:50 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 333
I'm not sure exactly the feature you're referring to.
But yes CalMAN 4.6 has the enhanced drift compensation which means dynamic dark offset times (up to several hours). We take full advantage of the new SDK so any other perks from using the i1Pro2 in it's native gen2 mode will be available in CalMAN (As opposed to 11Pro compatiblility mode).
sotti is offline
post #78 of 149 Old 05-08-2012, 01:01 PM
Liked: 1999
''Adaptive integration time based on patch luminance'', X-Rite maybe found a software code to operate different the old i1pro to give better performance at low light readings.
post #79 of 149 Old 05-08-2012, 01:18 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 333
That sounds like they copied our low light handler. We've been doing that for years.
sotti is offline
post #80 of 149 Old 05-10-2012, 08:40 AM
Liked: 116
Looks like we are still a few weeks out from taking customer orders so around mid June. The last thing we want to do is take a bunch of orders and not be able to ship them within a reasonable time.
As for trade-ins, upgrades, bundles etc... all of that is planned, we have the programs ready and will announce them as the time gets closer to OEM product release.
In the mean time CalMAN v4.62 already has fully integrated support for the i1Pro 2 so if you do buy one retail it will work already.
Derek
post #81 of 149 Old 05-10-2012, 01:13 PM
Ericglo's Avatar
Quoted: 2049 Post(s)
Liked: 963
Derek,
This is a little OT and probably out of your wheelhouse. What is the difference between the i1 Pro and the portable paint spectros like the 552?
Current projector - JVC RS25 and Marantz VP15S1
Future projector - pre-ordered new JVC from AVScience
Ericglo is online now
post #82 of 149 Old 05-10-2012, 02:21 PM
Liked: 1999
I have a few questions.
Operating i1PRO2 with latest CalMAN 4.62:
1) Do you support the self-correction feature during meter initialization using the i1PRO2's White Tile auto-correction?
2) Do you have set any dark reading time counter? (was 10min for i1PRO)
3) What is the default Low Light Handler Trigger setting for i1PRO2? (was 10 cd/m2 for i1PRO)
post #83 of 149 Old 05-10-2012, 02:55 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 333
Yes, we now require the tile for dark offset, but perform the alignment.
Yes we get the information from the meter. It's frequently up in the 2 hour range.
Low light performance wasn't greatly increased so it's still at 10 by default.
sotti is offline
post #84 of 149 Old 05-10-2012, 04:06 PM
DaGamePimp's Avatar
Quoted: 424 Post(s)
Liked: 458
Wow, so the i1Pro2 can go 2 hours between initializations, that's a massive leap from the original.
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro / Xbox One S / WiiU / PS3 / 360 / Wii / 1080TI game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #85 of 149 Old 05-10-2012, 04:20 PM
Liked: 683
If you were just using the spectro for profiling, would the time between dark readings matter at all (i1Pro 2 vs. i1Pro)?
post #86 of 149 Old 05-10-2012, 04:25 PM
DaGamePimp's Avatar
Quoted: 424 Post(s)
Liked: 458
Well no but if you wanted to use it for doing Gamut it would be a nice bonus.
Jason
post #87 of 149 Old 05-10-2012, 06:34 PM
Liked: 683
Jason
would the spectro be any more accurate than the profiled colorimeter for gamut work?
post #88 of 149 Old 05-10-2012, 09:32 PM
airscapes's Avatar
Quoted: 380 Post(s)
Liked: 302
If you talking about the the i1pro and the C6, not much difference once profiled. The dark reading is not an issue, you set the button on the side of the i1pro to initialize within calman, then when you need to, cover the hole with your finger and hit the button.. done..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #89 of 149 Old 05-10-2012, 11:06 PM
DaGamePimp's Avatar
Quoted: 424 Post(s)
Liked: 458
Possibly, could vary by colorimeter...? I know I trust the i1Pro over my i1D3 for gamut even though the claims are the D3 could be better on certain displays. I am on D3 number two and each had different readings (no profiling).
That's exactly what I do but it's still kind of a pain if you are going for consistent reads from the same exact spot on the screen. I created profiles both ways, both meters on screen at once right next to each-other and then one at a time in the same location (which is the correct way to do it). I discovered that moving the i1Pro even slightly would change the reads a little. Obviously this is easier with projection having the meters secured to a tripod but with an HDtv it's kind of bothersome to have to initialize the Pro every 10 minutes. especially considering the goofy panel mount that the i1Pro comes with (obviously not intended for large hdtv's as I barely hit the middle of my screen with the weight sitting precariously on the top edge of my thin 60" LED LCD, thank goodness my plasma is smaller @ 50" or it would not work since it's even thinner).
I'll definitely be grabbing the Pro2 down the road once the prices are more reasonable for an enthusiast/hobbyist.
Jason
post #90 of 149 Old 05-11-2012, 12:06 AM
Liked: 1999
Profiling is designed for grayscale as a colorimeter is much quicker and more accurate at low light levels.
You need a new profile after any gamut change because when you are doing meter profiling, you are teaching the colorimeter where the primaries are. If you move the primaries doing CMS then the profile is off.
That's why both instruments are required, spectro for the colour gamut and then a profiled colorimeter for greyscale.
Reply Display Calibration
