Rec 601 Discs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-05-2012, 12:43 PM - Thread Starter
ZandarKoad's Avatar
I'm thinking GetGrey is the goto standard for 601, just as AVSHD is to 709. However, I'm looking for a standard definition calibration disc that I can leave behind with people I calibrate for. I can't do this with GetGrey due to licensing restrictions. Are there any decent calibration discs out there for 601 that are free?
ZandarKoad is offline
post #2 of 4 Old 04-05-2012, 01:00 PM
ConnecTEDDD's Avatar
Quoted: 1201 Post(s)
Liked: 1703
ChromaPure Free Calibration Disc (NTSC DVD)
https://www.chromapure.co.uk/calibration_dvd.zip
This is a basic calibration disc that can be used for calibration using the Chromapure software (or other) and a meter. If you don't have a meter you can try to set the basic controls like brightness, contrast etc.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #3 of 4 Old 04-05-2012, 01:29 PM
airscapes's Avatar
Quoted: 356 Post(s)
Liked: 289
Would it not make more sense to leave behind a list of settings rather than a disk? What is the reasoning.. just marketing? Something for the customer to hold in their hand when you are done?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #4 of 4 Old 04-05-2012, 01:46 PM - Thread Starter
ZandarKoad's Avatar
Added value. Even if it is nearly 100% perceptual.
Edit: And it's not merely perception in this case. They can use it to do the basics on their other displays themselves.
Reply Display Calibration
