Daylight lamp as white reference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 79 Old 04-06-2012, 03:00 PM - Thread Starter
booker21's Avatar
I don't own a colorimeter but I don't want the default white from my tv.
I bought a daylight 6500k lamp to use as white reference. I know this is far away from ideal but I believe it's better than nothing.
Comments?
booker21 is offline
post #2 of 79 Old 04-06-2012, 03:07 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
What is the make an model of the set, using the color temp preset that is closest to D6500 would be your best options. Most likely that would be warm or warm2
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 79 Old 04-06-2012, 03:32 PM
GeorgeAB's Avatar
Quoted: 136 Post(s)
Liked: 240
Comments?
What do you intend to do with the lamp? Please be more specific.
GeorgeAB is offline
post #4 of 79 Old 04-06-2012, 03:37 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Comments?
No, it could easily be worse than nothing.
I'd stick with the default settings unless you plan on investing in some real equipment.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #5 of 79 Old 04-06-2012, 04:25 PM - Thread Starter
booker21's Avatar
Ok I think I'll stick with default. I had the chance to compare with a Samsung plasma side by side, Samsung at default warm2 and lg plasma (mine) at warm setting and the lg was noticeable warmer than the Samsung. I read that Samsung warm2 was usually close to 6500k. I don't have the samsung no more so I can use it as a reference. This is what I thought about the daylight lamp. My tv has very limited color temp settings to work with. Only r,g,b
booker21 is offline
post #6 of 79 Old 04-07-2012, 12:49 PM
ADU
ADU's Avatar
Quoted: 313 Post(s)
Liked: 520
To use a daylight bulb as a grayscale reference, you'll also need some type of neutral white card. Then you can compare the color of the light bulb reflected off the white card to the color of grays on your TV with the different temperature settings to see which is the best match. Do this at night in a totally dark room to prevent other sources of light from reflecting off the white card.
Some other recent links you may want to read (or re-read ) on this...
http://www.avsforum.com/avs-vb/showthread.php?t=1318860
http://www.avsforum.com/avs-vb/showthread.php?t=1339315
http://www.avsforum.com/avs-vb/showt...7#post21234077
ADU
ADU is offline
post #7 of 79 Old 04-07-2012, 10:04 PM - Thread Starter
booker21's Avatar
Thank you. I forgot the white sheet to reflect the light.
booker21 is offline
post #8 of 79 Old 04-10-2012, 02:05 AM
HDTVChallenged's Avatar
Liked: 215
Why do folks still recommend attempting this "method?" It leads to nothing but frustration and wasted time.
If you feel calibration is something worth doing, and you want to do it yourself get one of the easily available (and relatively affordable) software/colorimeter packages ... otherwise just pick your "warm" color temp and carry on.
HDTVChallenged is offline
post #9 of 79 Old 04-10-2012, 05:21 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Originally Posted by hdtvchallenged View Post
why do folks still recommend attempting this "method?" it leads to nothing but frustration and wasted time.
If you feel calibration is something worth doing, and you want to do it yourself get one of the easily available (and relatively affordable) software/colorimeter packages ... Otherwise just pick your "warm" color temp and carry on.
+1
Doug
post #10 of 79 Old 04-10-2012, 11:05 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
I recommend this for anyone on a budget or this if you want better hardware for a little more. You can always add (or rent) a spectro later for absolute accuracy.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #11 of 79 Old 04-10-2012, 11:09 AM
Liked: 562
this approach was useful back when color analyzers were not available or affordable to the general public... not anymore
post #12 of 79 Old 04-10-2012, 02:12 PM - Thread Starter
booker21's Avatar
Well this is all i have. My country doesnt sell colorimeter and importing them is currently close and they cost x4 more. This method helps.
booker21 is offline
post #13 of 79 Old 04-10-2012, 02:26 PM
Liked: 562
then just stick the with default color temp preset that appears closest to neutral gray/white
what you're are attempting to do will likely make things worse than the default settings on your TVs; how do you know what you're doing right now helps without a reference point?
read post #4 again, Sotti knows what he's talking about
post #14 of 79 Old 04-10-2012, 06:54 PM - Thread Starter
booker21's Avatar
In not looking for a D6500 color temp. Actually my Main goal is to achieve the same white on my monitor pc and my tv. Of course they won't be exact since I'm doing by eye comparison but is much accurate than leaving both on default.
By doing this is If i can get closer to 6500 great. This is why I thought of using a 6500k lamp as reference to tweak my tv and monitor onstead of using the monitor as reference.
Now that you tell me this is no good, then I'll go back to my main idea that is to use the monitor 6500k default as reference and tweak the tv to match the most I can to the tv.
Why I'm not using the tv as reference because we I compared to my old Samsung warm2 setting and to all others warm setting I encounter the tv warm setting was too warm.
On the other hand the medium setting is way to blue. My monitor default 6500 seems to be more accurate to my eyes and same to warm2 setting from my old samsungs.
I hope I could explain my self with this. Sorry for the long post and I know this is not calibration.
booker21 is offline
post #15 of 79 Old 04-10-2012, 08:54 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
If you want your PC and TV to match, your best bet without equipment would be to set them next to each other and eyeball it.
Joel Barsotti
SpectraCal
sotti is offline
post #16 of 79 Old 04-10-2012, 09:41 PM - Thread Starter
booker21's Avatar
Yeah that is what I'm doing. I have them next to each other, but the other day I read about the daylight lamp and the white sheet and I thought on using that as a white reference instead the default 6500 monitor setting. That is why I started this thread.
booker21 is offline
post #17 of 79 Old 04-10-2012, 11:57 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
The light can be labelled 6500K, but its CRI and its bias towards red, green or blue can ultimately let it down.
The sheet is also unreliable as a white reference.
fahrenheit is offline
post #18 of 79 Old 04-11-2012, 10:32 AM - Thread Starter
booker21's Avatar
If you don't plan on getting a meter, you'd honestly be better leaving the white balance controls on your displays alone; I don't know why you don't believe that.
Why do you need them to match? How would you know which is closer and which is farther from D65 with your eyes alone anyway?
It looks ugly to see differencies on white on the tv and monitor, i want them to match because is distracting to my eyes when i use both at the same time.
Again I don't care to get them to be 6500 since I don't have the equipment, i understand is impossible. I just want them to match the best I can with my eyes.
The question was if I can use a 6500k lamp as reference. The answer is no. So I'll go back and use the monitor as reference to make those display match the best I can.
booker21 is offline
post #19 of 79 Old 04-11-2012, 10:44 AM
Liked: 562
Comments?
Sorry, it's not.
Yes, your LG might have been significantly warmer than the Samsung but the Samsung might have been too blue to begin with and so the LG could be closer OR both could be off by the same amount but in opposite directions. You don't have a reference point to know which is right and which is wrong, assuming they're not both wrong. You don't even know which is better, if either is to begin with.
Again, how do you know it helps?
You may get them reasonably close to matching if you know what you're doing but that in no way means it's more accurate than leaving both on default.
You say some presets look too blue and some too warm. While the ones that look too blue to your probably are too blue, the ones that look too warm might actually be quite close, or even still too blue. On many TVs the warm or warm2 preset is still too blue.
post #20 of 79 Old 04-11-2012, 10:46 AM
Liked: 562
Yes, if you want them to match, that's all you can do without a meter/software
post #21 of 79 Old 04-11-2012, 10:50 AM - Thread Starter
booker21's Avatar
Thanks. Ill do that.
booker21 is offline
post #22 of 79 Old 04-14-2012, 02:07 PM
ADU
ADU's Avatar
Quoted: 313 Post(s)
Liked: 520
booker21,
Folks here will try to pick apart the optical comparitor approach for various reasons. But if you use a bulb with CIE xy coordinates reasonably close to D65 (like the GE mentioned in my previous links), with a neutral white card that's a good match to the X-Rite/Munsell photo white cards, it should provide a pretty good reference for your TV's color temperature.
Is it as good as using a measuring instrument? Probably not. But it'll likely get you closer to the ballpark than any other low-cost method.
If you don't care what color the displays are though, and just want them to match, then you may not want to bother with this.
ADU
ADU is offline
post #23 of 79 Old 04-14-2012, 02:08 PM
ADU
ADU's Avatar
Quoted: 313 Post(s)
Liked: 520
The CRI doesn't matter if you're using a white card. All that really matters is how close the bulb's color is to D65.
ADU
ADU is offline
post #24 of 79 Old 04-14-2012, 02:13 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
I think the real trick is a bulb and white card that produces a spectrum remotely close to D65 cost as much i1 D2 or spyder4.
Decent setup, but no accuracy assurance:
http://www.cinemaquestinc.com/ideal_lumesb.htm#Standard
http://www.bhphotovideo.com/c/produc...e_Balance.html
While it may work, it's not really a value. That standard ideal lume bulb doesn't even have x,y specs, not that it's bad, but if you want a bulb that really nails D65 then you're looking at the pro bulb. http://www.cinemaquestinc.com/Ideal-Lume.htm#pro at $299, you're well into the cost of buying a meter and software.
Ten years ago when meters were all $1000 or more, this was a great value, budget solution. Now it's a non starter.
Joel Barsotti
SpectraCal
sotti is offline
post #25 of 79 Old 04-14-2012, 02:31 PM
Liked: 562
Some really good points, I agree that this method was useful a decade ago but now the best budget option is a D2, D3, or Spyder 4 (bundled with HDTV calibration software like CalMAN or ChromaPure).
post #26 of 79 Old 04-14-2012, 02:44 PM
ADU
ADU's Avatar
Quoted: 313 Post(s)
Liked: 520
I think the real trick is a bulb and white card that produces a spectrum remotely close to D65 cost as much i1 D2 or spyder4...
Not sure I agree Joel.
As mentioned here, according to GE, the coordinates on their standard off-the-shelf 6500K daylight bulbs are x=0.313, y=0.337, which is pretty close to D65. I'm just takin their word on that though.
The bulb used in the Ideal Lume Pro is probably more costly because it employs a more exotic blend of phosphors/illuminants to ensure that colors render accurately (which may be beneficial for bias lighting). If you're just reflecting light off a plain white card though, then the CRI (color rendering index) doesn't really matter.
Renting a good meter would probably be less hassle, and more accurate though, if that's a practical option for you.
ADU
ADU is offline
post #27 of 79 Old 04-14-2012, 03:23 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Exactly you are just taking GE's word about a budget bulb. Something mass produced without the level of quality control isn't very reliable.
Also I don't see any specs other than 6500K, no mention of d65 or x,y coordinates
http://genet.gelighting.com/LightPro...FieldCode=null
http://www.amazon.com/89082-10-Watt-...4438386&sr=8-1
Joel Barsotti
SpectraCal
sotti is offline
post #28 of 79 Old 04-14-2012, 04:07 PM
Liked: 562
I took a look at those links and this appears to just be typical CFL bulb rated at 6500K with a decent CRI (82). You could make a cheap bias light with this bulb but I can't see it being helpful in terms of dialing in grayscale on a modern TV with a Warm (or Warm2) preset that is likely in the ballpark to begin with.
This bulb may not even be truly 6500K, let alone D65.
post #29 of 79 Old 04-14-2012, 08:36 PM - Thread Starter
booker21's Avatar
I understand this but I can't get a colorimeter because import is close at the moment and it will be for a long time because government decision.
I can't leave default settings because one display is to warm and the other is too cold compared between the two.
My main goal is to get both white similar to each other. Since they are side by side I'll use my eyes and try to match them. I know it's not a perfect solition but is the only possible way.
This is why I asked abiut the chance of using a 6500k as reference white. I understand this is not possible or at least not accurate. In fact by looking the 6500k lamp I bought is bluer than the two displays. I'm wondering if the white I'm used to its warmer than the 6500k. Just a thought.
booker21 is offline
post #30 of 79 Old 04-15-2012, 04:53 AM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
You might want to take a look at my experiements with various lights (although I had different goals to you).
http://biaslighting.blogspot.com
Scroll down to where I tested the tubes on the white and grey cards and where I used the photoshop colour picker.
If you have a camera, you can at least sample the two displays and see how they differ from each other.
Ultimately, without a reliable reference like a colorimeter or trustworthy light source, you will be comparing two dissimilar things, but if you prefer or trust one monitor over the other, this method of comparison might help you get the other one closer to it.
Reply Display Calibration
