Tripod mount mod for i1pro/C6 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 04-06-2012, 03:03 PM - Thread Starter
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Posted this over in the spectracal forum but maybe of interest to others that don't frequent that site and/or have D3 and i1pro. Not sure if you get the tripod mount with the D3, I don't think it comes with one.
If you want to profile and adhere to keeping both meters with the same field of view this is a fast, 2 hole, one bolt modification if you have the tripod mount for the i1pro and the C6. It may not work to well with Front projection if your meters will be in the light path (you will need to tilt up) but for my purpose (HP screen, meters over the projector) should be fine (will be using it tonight)
If anyone wants to try this and needs measurements or instructions, just ask but it is really simple
You will need:
Drill or Drill press
7/16 bit
1/4 bit
center punch and hammer
1/4" bolt or screw
Offset distance is 17cm
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #2 of 16 Old 04-06-2012, 03:45 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
Nice job.
I was going to do something similar for my D3, but rather than having a single drilled hole to mount the bracket to the tripod, I was going to make it one long slot so the meter could be moved forwards and backwards. I didn't have the tools to pull it off though, so I abandoned that design althogether.
That bolt with the ring looks like something I could use in place of the wingnuts I'm currently using (easily lost). I've never seen those before. Is there a common name for them?
fahrenheit is offline
post #3 of 16 Old 04-06-2012, 03:48 PM - Thread Starter
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Originally Posted by fahrenheit View Post
Nice job.
No idea, it came with the mount, which came with the meter..
Doug
post #4 of 16 Old 04-06-2012, 03:50 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
Oh bummer. Oh well, now that I know they exist, I'll have to keep an eye out for them.
post #5 of 16 Old 04-06-2012, 04:02 PM - Thread Starter
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Have you tried a Google of "Tripod screw replacement"
Looks like this site had them but they are backordered.. I bet with a little searching you could fine one. (second page)
http://www.bhphotovideo.com/buy/Bush...-/N/4289936033
Doug
post #6 of 16 Old 04-06-2012, 04:11 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
^ Thanks. I currently have a fixed length bolt which I then screw the D3 onto. That gets a bit messy with that thin connection cord getting twisted around.
Something like this would make it easier to hold the meter in place and screw the bolt into it (just as it should be).
post #7 of 16 Old 04-06-2012, 07:36 PM
cal87's Avatar
Quoted: 30 Post(s)
Liked: 29
I have the i1Pro mount. What I did was drill a hole right between those 2 black posts. One screw there to attach the C6. A little simpler, I think.
cal87 is offline
post #8 of 16 Old 04-06-2012, 10:31 PM - Thread Starter
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
The thing I was trying to achieve was the proper offset so the FOV would be identical when profiling. The i1pro has to be 17cm behind the C6 so they view the same amount of area.
I just finished calibrating my projector and this is the first time doing it with the profiled C6 and using this setup. It worked fantastic! Once profiled the C6 read just like the I1pro at the top end and much better at the bottom end. I took several sets of readings before making any changes to compare. Not a real big difference but measurable.
Doug
post #9 of 16 Old 04-08-2012, 08:01 AM
CaptainZ's Avatar
So is the 17cm distance from the back of the C6 mounting plate to the front of the i1pro plate, or is it the distance from the face of each meter when mounted?
CaptainZ is offline
post #10 of 16 Old 04-08-2012, 08:32 AM - Thread Starter
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
The distance from the face. This is from Derek http://www.spectracal.com/forum/view...it=17cm#p21351 at the spectracal site and this chart is also helpful to understand why it is important and what your meter sees at a given distance.
http://store.spectracal.com/article-...e-is-important
Doug
post #11 of 16 Old 04-08-2012, 08:41 AM
CaptainZ's Avatar
Okay: I have the same mounts and meters...so what is the distance between the mounting brackets. (back of C6 to Front of i1ro)? If I know that distance I can just drill the holes and be good to go? or just give me the center distance to the hole that needs to be drilled in the i1pro bracket? and that should line everything up corectly...can you measure and share these numbers? Thanks!
CaptainZ is offline
post #12 of 16 Old 04-08-2012, 09:25 AM - Thread Starter
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
I1pro mount:
Center of 7/16 hole is almost 15/16" behind center of front factory mounting hole
C6 Mark center for 1/4 hole once you get the 7/16" hole drilled and lay the 2 parts together flush.
Doug
post #13 of 16 Old 04-29-2012, 05:11 AM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Thank You Doug!!!
Here is my DIY for about $25.
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #14 of 16 Old 06-23-2012, 06:51 AM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
What is the dimension as shown on the picture?
thanks
432
vega509 is offline
post #15 of 16 Old 06-23-2012, 02:24 PM - Thread Starter
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
look up at post #12
But to answer your question 4 1/4"
Doug
post #16 of 16 Old 03-10-2015, 04:26 AM
Francois76l's Avatar
Quoted: 77 Post(s)
Hello everybody!
it's an old thread (2012...) but maybe someone can answer me
I did my tripod mount yesterday thanks to this thread.
The distance between the two bracket is 10.8cm. I have to mesure but I should have 17cm between the two lens (if I understand well ^^)
With this tripod mount, at which distance should I put the i1d3 from the projector screen? I'm not sure if it's work for a projector calibration since area and distance are proportionnal to each other..
Thanks for your help!
ID:	594713   Click image for larger version
ID:	594721   Click image for larger version
ID:	594729   Click image for larger version
ID:	594737   Click image for larger version
HiFi:Nad C320BEE+Marantz CD-63 MkII-Ki Signature+Boston VR2+DIY cabling
HC:Onkyo TX-SR875+Boston VR2+CR8+VRC+Subwoofer MJ Acoustic Ref1 MKII
DISPLAYS:Panasonic P50ST50E/JVC DLA-X35 + HTPC (LAV+ffdshow+Avisynth+MPC-BE+MadVr)
SCREEN: Lumene Movie Palace Premium 240C + Dedicated room
Francois76l is offline
Reply Display Calibration
