red bias & red gain - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-07-2012, 07:15 AM - Thread Starter
evo5's Avatar
Hi,
Whats the difference in calibration between bias and gain? When use one or the other?
I have an Optoma HD20...
Thanks in advance
evo5 is offline
post #2 of 12 Old 04-07-2012, 07:22 AM
chunon's Avatar
Quoted: 2013 Post(s)
Liked: 1774
Originally Posted by evo5 View Post
Hi,
Thanks in advance
Far from an expert but gain effects the entire ire range from my understanding. Bias affects the lower ire range for the most part.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #3 of 12 Old 04-07-2012, 07:26 AM - Thread Starter
evo5's Avatar
Thank you chunon...
What means for ire range?
evo5 is offline
post #4 of 12 Old 04-07-2012, 07:27 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
They are typically interactive in they effect everything to some extent, but
Bias is for the low end 10-50 and gains are for 50-100. You would start out a 2 point gray scale adjustment by displaying a 30% white pattern and adjusting the RGB Bias to get you as close to D65 for that stimulus then display an 80% pattern and adjust the RGB gains to get close to D65. Then take readings of the complete 10 point scale and adjust either/or to get everything as flat as possible even if your 30 and 80 are now slightly off.
If you do not have an accurate meter and software do not mess with these adjustments as they can not be properly set by eye.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #5 of 12 Old 04-07-2012, 07:31 AM - Thread Starter
evo5's Avatar
Thank you airscapes...
Will work Spears & Munsil disc calibrator?
evo5 is offline
post #6 of 12 Old 04-07-2012, 07:35 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Thank you chunon...
IRE is a term from the old Analog days (I think it stands for International Radio Engineers ) but it refers to the amount of luminous stimulates (how bright) a gray pattern is. A 10 point gray scale consists of 10 patterns of white, from video white which is 100% luminous down to 10% which is 10% above Video black and all the other percentages in between 10%,20%,30%,40%,50%,60%,70%,80%,90%,100%
Doug
post #7 of 12 Old 04-07-2012, 07:45 AM - Thread Starter
evo5's Avatar
Thank you!!!!!
Spears & Munsil is a good calibrator? Any other?
evo5 is offline
post #8 of 12 Old 04-07-2012, 12:48 PM
Gregg Loewen's Avatar
Quoted: 22 Post(s)
Liked: 68
Think of bias as the Brightness (AKA black level) control.
Think of Gain at the Contrast (AKA picture) control,
Bias or brightness is made up of a combination of RGB.
Gain or contrast is made up of a combination of RGB.
Bias affects the near black part of the image, Gain affects the near white part of the image.
Bias and gain interact.
President, Lion Audio Video Consultants Inc.
Lead THX Video Standards Instructor
Gregg Loewen is offline
post #9 of 12 Old 04-07-2012, 02:14 PM - Thread Starter
evo5's Avatar
Thank you, Gregg
evo5 is offline
post #10 of 12 Old 04-07-2012, 04:26 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
IRE is a term from the old Analog days (I think it stands for International Radio Engineers ) ---[snip]
Old analog days, indeed.
IRE stands for the Institute of Radio Engineers. It is now known as the Institute of Electrical and Electronics Engineers (IEEE.)
Some of us are members. Some of us even were members of the both the IRE and the American Institute of Electrical Engineers (AIEE) before the merger of the two and the subsequent name change in the early 1960s.
Larry
LarryInRI is offline
post #11 of 12 Old 04-07-2012, 04:38 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Larry
No offense meant..
I guess the point I was trying to making is calling something "20 IRE" does not really properly describe a white pattern at 20% stimulus.
Doug
post #12 of 12 Old 04-07-2012, 04:57 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
No offense meant..
No offense taken.
The IRE unit was defined to indicate relative amplitude of the voltage in an amplitude modulated TV signal waveform.
Long before digital TV, when digital signal technology was being developed in the 1960s and 1970s, the IRE unit was used only because it was convenient. It still has its uses but not in the context of HDTV.
Larry
Reply Display Calibration
