CalMan 4 issues... - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 93 Old 04-17-2012, 08:32 PM
coderguy's Avatar
Quoted: 504 Post(s)
Liked: 345
I am using version 4.5.0341, that is the version I have the problem on.
I'll just wait for DG-Pimp to test and see if he figures it out before I re-install any other versions.
Access HERE from this thread
coderguy is offline
post #32 of 93 Old 04-20-2012, 04:29 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Will be checking into this more tonight, i1Pro just arrived today so I'll have another point of reference to verify colorimeter vs spectro vs software.
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #33 of 93 Old 04-20-2012, 07:05 PM
coderguy's Avatar
Quoted: 504 Post(s)
Liked: 345
Yes, please let me know, I don't have an i1Pro so it's harder for me to figure it out.
coderguy is offline
post #34 of 93 Old 04-21-2012, 04:31 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Well I was not able to figure much out last night with my testing, it seems that true verification may require the spectro add-on license but I obviously don't wish to make that investment only to discover that I am still having the erratic errors.
It would be great if there was a short trial license or something of that nature so that people could see first hand if everything is functioning as it should. I might consider buying the add-on license if I knew they would be willing to refund it should things not end up functioning properly.
At this point HCFR 2.1 functions properly with the i1Pro, HCFR 3 still has some bugs they are working on and I have the issues with Calman so I am not sure what my next step should be (don't want to invest in Chroma-pure after just investing in CalMan).
Jason
post #35 of 93 Old 04-21-2012, 04:44 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Call up our sales dept on monday, they can do trial keys.
sotti is offline
post #36 of 93 Old 04-21-2012, 04:50 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Ah that's exactly what I need, thank you Joel!
* Got the trial and will be digging into it over the next couple days. Thanks again Joel (and special thanks to Loel and Jamie).
Jason
post #37 of 93 Old 04-26-2012, 02:48 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Still working on this...
Getting very different results/settings between CalMan and HCFR (both using an i1Pro profiled i1D3).
CalMan was giving me very odd greyscale reads requiring a drastic amount of green adjustment while HCFR seemed very consistent with what other Pro calibrations have shown (regarding greyscale).
I plan to run through it a few more times to make sure I have considered every possible variable and show more repeatability before making any definitive conclusions.
Jason
post #38 of 93 Old 04-26-2012, 02:58 PM
djams's Avatar
Jason
Did you see sotti's post that black level compensation is "flat out broke" in the current version?
djams is offline
post #39 of 93 Old 04-26-2012, 03:34 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Yes and that is not enabled, thank you for the post though.
Jason
post #40 of 93 Old 04-26-2012, 04:26 PM
ConnecTEDDD's Avatar
Quoted: 1733 Post(s)
Liked: 2137
Black Level Compensation Calculations Fixed, Get the Latest Version.
CalMAN 4.6.1 Release Notes
Released April 25, 2012
Updates
Fixed issue where CalMAN after connecting to a meter, could not connect to another of the same meter without deleting the settings file. Meters affected were the Spyder3, Spyder4, i1D3, C6, and i1Pro.
Added PDP table to the Spyder4 meter
Added OLED table to the K-10
Added watchdog timer to the Sharp Elite when connected over IP
Fixed localization issue when profiling meters
Fixed issue where CalMAN was not calculating targets when Black Light Compensation was enabled
Fixed issue where CalMAN was not calculating targets when Colorfacts RGB Absolute Correction and Black Light Compensation were both enabled.
Fixed issue where CalMAN would crash when Black Light Compensation and Colorfacts RGB Absolute Correction were both enabled on some international versions of Windows.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #41 of 93 Old 04-26-2012, 04:29 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Oh, an update... nice!
Will try it out, thank you ConnecTEDDD for the heads up!
* CalMan is telling me I have the latest version at 4.6.0.368.
** Downloaded 4.6.1 from website http://store.spectracal.com/downloads.html
Jason
post #42 of 93 Old 04-26-2012, 04:51 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
We just pushed 4.6.1 yesterday, we usually wait to update the in app notification for a day or two just in case something nasty shows up in the field.
sotti is offline
post #43 of 93 Old 04-26-2012, 04:59 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Will installing update over the previous install have any negative effect or should I do a clean install?
Thanks Joel,
Jason
post #44 of 93 Old 04-26-2012, 05:21 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Thanks Joel,
Jason
installing over the top should work fine, effectively the installer does an uninstall/re-install anyway.
sotti is offline
post #45 of 93 Old 04-26-2012, 05:32 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Nice, thanks again Joel!
I am so very thankful to have you and Derek here, your support has been excellent to say the least!
Jason
post #46 of 93 Old 04-27-2012, 06:18 AM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Ok, so what I have figured out so far is that CalMan shows read issues from the initial readings to the greyscale reads. I can take all the initial reads touching no settings on the display and jump right to greyscale with different results. As an example the initial read would say red @ 20 IRE was at 98 yet the greyscale graphic read shows red as being way too high (between 20 & 40 in the box). Should Red not be showing slightly below 0 in that box if the initial read claimed it was at 98, if this is normal then it is not very straight forward? It exhibited similar behavior on all 3 colors with the Blue reads being more truthful from initial to greyscale, at least both reads claimed Blue was too high (not a single setting touched on the display).
This is with an i1Pro corrected i1D3 and CalMan 4.6.1.
Jason
post #47 of 93 Old 04-27-2012, 08:46 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
I think what you may be seeing is the difference between RGB relative and RGB absolute.
When the chart is in relative mode it balances against 100%, but doesn't include overall luminance.
When the chart is in absolute mode it balances at 0, and if you have too much luminance you'll be above 0, too little and you're below 0.
So if you have 2 point grayscale controls using relative is the right thing to do since you can't change your gamma with a 2 point control.
If you have a 10 point or more system, then using absolute gives you better information so that you can correct your gamma as well.
At least that was my best interpretation of your post. If you could post screens shots I might have a more specific answer to what you're seeing.
sotti is offline
post #48 of 93 Old 04-27-2012, 08:50 AM
PlasmaPZ80U's Avatar
Quoted: 2318 Post(s)
Liked: 716
Jason
could you use the print button and something like PrimoPDF to post your data in PDF format?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
post #49 of 93 Old 04-27-2012, 02:05 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Ah, that sounds like it explains what I am seeing then. The current 'test' display has 2 point greyscale so I'll set it for 'relative' and see how it goes (and then test one of my other displays that has 10 point with 'absolute').
One other quick Q, considering greyscale should typically be done first why is Gamut before Greyscale in the standard workflow?
Thanks again Joel,
Jason
post #50 of 93 Old 04-27-2012, 02:18 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
ISF teaches gamut before grayscale
THX teaches grayscale before gamut
The workflows were based off of the specific ones we did for ISF. Really either way you need to double check the other because their can be interactions.
When I calibrate I do grayscale work first, then gamut, then double check everything.
sotti is offline
post #51 of 93 Old 04-27-2012, 02:34 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
I see, it was politics . I have always done greyscale first and then spend a good bit of time balancing back and forth once gamut has been completed (always seems to work well for me).
By the way have another Q in another thread regarding the i1Pro http://www.avsforum.com/avs-vb/showthread.php?t=1406603 , you probably know the answer.
Does the i1Pro use the internal lamp for emissive reads at all, do we need to worry (for our use) that it fails a lamp test when using longer usb cables?
Thank You!
Jason
post #52 of 93 Old 04-27-2012, 03:39 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
The lamp is strictly for reflective readings.
If you are having problems with a long USB cable I'd recommend going and grabbing a powered USB hub.
sotti is offline
post #53 of 93 Old 04-27-2012, 04:02 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
That's what I figured (didn't want to assume) but thanks for the confirmation Joel.
Jason
post #54 of 93 Old 05-02-2012, 05:25 AM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Some odd behavior with 4.6.1...
Doing auto greyscale read sequence yields different results than manual reads.
I did 80/20 @ .313 x .329 and then running the auto 10 step showed all reads close to delta 3 , yet with each step done manually all but 100 IRE is under delta 1.
Just wanted to pass it along, may be a bug (?).
Jason
post #55 of 93 Old 05-02-2012, 08:06 AM
derekjsmith's Avatar
Liked: 116
Jason
If this happens then it might be you need a longer source delay, in that the pattern has not settled before a reading starts. On the sources advanced you will see a delay we put in by default try adding a couple of seconds to that delay.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #56 of 93 Old 05-02-2012, 02:14 PM - Thread Starter
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Excellent, will do.
Thank You Derek!
Jason
post #57 of 93 Old 05-08-2012, 06:48 AM
WTS
WTS's Avatar
Quoted: 38 Post(s)
Hi,
What is "black compensation" used for and what probes does it affect/work with?
Walter
WTS is offline
post #58 of 93 Old 05-08-2012, 09:01 AM
Liked: 716
Originally Posted by WTS View Post
Hi,
It factors in the black level of a display when calculating gamma; it works with any meter that can accurately read a 0% black pattern from the display.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #59 of 93 Old 05-08-2012, 09:46 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
How does this play into a manual calibrations? I thought I remembered reading this was going to be for autocal, but that was back before it was even functional.
So from your description, it just uses the actual reading at 0 percent to calculate gamma rather than assuming 0? This being used with absolute charts and the Target _Y when doing gamma/grayscale?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #60 of 93 Old 05-08-2012, 12:56 PM
Liked: 716
this feature is not specific to auto or manual calibrations... it can be used either way
yes, and the higher the black level of the display, the greater the impact this feature will have on low-end gamma
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
Reply Display Calibration
