First time Calibrating my TV with HCFR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 04-13-2012, 11:12 PM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
Hello, I been lurking around the forum for awhile. I just bought a new Samnsung UN55D7000. Then I bought, DVE HD and Eye-One Display two. I followed HCFR guide, adjusting everything according to the tutorial. Here are the picture, hopefully you guys would correct me on what I should change.
kanti123 is offline
post #2 of 21 Old 04-13-2012, 11:54 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
10pt grey scale?
the low ires need the rgb increased and he high ires need to be lowered,.
gamma shows this.
also, 10 point should allow better balance then what I am seeing.
Loving D65
CalWldLif is offline
post #3 of 21 Old 04-14-2012, 06:45 AM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
Okay, how exactly do hey work. I see interval 1-10
kanti123 is offline
post #4 of 21 Old 04-14-2012, 01:28 PM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
I could not get my gamma to flatten at all
kanti123 is offline
post #5 of 21 Old 04-14-2012, 06:40 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
if you have 10 adjustments for
w/b-grey scale, by lowering the
value for red, blue, green the same amount the gamma will increase. and if you raise them the gamma will decrease. so
0 ire raise the values of all RGB the same amount, 10 ire same, 20-50 ire sameamount.
60 ire lower all RBG do the same for 70-100 ire.
recheck, adjust, recheck.
be aware contrast and brightness will also affect the gamma. Read here in AVS for tips, tricks, general control responses info
Loving D65
post #6 of 21 Old 04-15-2012, 08:37 AM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
Thanks I went through all 1 to 10 interval this is the result I got. I also notice that each interval affects others. Gamma still mess up, also I think my I-1 Display two can't read 10IRE right.
kanti123 is offline
post #7 of 21 Old 04-15-2012, 10:17 AM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
Here's the best I can do, I get all my Gamma close to 2.2 as possible. I can't lower my 80-100 IRE any more its max out, with out compromise my 100% IRE ftL(Y) value. Its still within 30-40ftL and my RGB is close as possible. Delta E is right below 3. As far as I know human eyes can't see the different below DeltaE value.
kanti123 is offline
post #8 of 21 Old 04-15-2012, 10:27 AM
PlasmaPZ80U's Avatar
Quoted: 1963 Post(s)
Liked: 559
you might be able to get 30% and 40% closer in terms of dE AND more importantly you should fix the gamma by moving all three colors up or down by the same amount at each step to get a much flatter gamma response
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #9 of 21 Old 04-15-2012, 10:29 AM
Liked: 559
looks much better
post #10 of 21 Old 04-15-2012, 10:52 AM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
I had to put my gamma to -1 in advance menu to get it to that area. my 80-100 IRE is already at -10 for all RGB. Unless I lower gamma to -2. that would mess up my birghtness and contrass value. Does Backlight effects anything?
kanti123 is offline
post #11 of 21 Old 04-15-2012, 02:36 PM
Liked: 559
backlight can affect the color portion of the grayscale (RGB balance) somewhat, especially with large changes
post #12 of 21 Old 04-15-2012, 04:08 PM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
Ah okay, I might experiment with Gamma boost abit. Maybe shadow control too.
kanti123 is offline
post #13 of 21 Old 04-15-2012, 11:17 PM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
Okay, I played with Gamma boost and such, Still no luck bringing IREs 40-90 to 2.2 gamma. Any suggestions?, I have already max my 10p white balance. The gammas ranged from 2.25-1.89 on the chart.
BlackLight: 7
Contrast: 92
Brightness: 44
Sharpness: 0
Color: 50
Tint: 50/50
Advance
BlackTone: Off
Dynamic Contrast: Off
Shadow Detail: 0
Gamma: 2
Expert Pattern: off
RGB only: off
Color Space: Auto (don't know how to work the custom)
White Balance
R-Offset: 24
G-Offset: 25
B-Offset: 20
R-Gain: 24
G-Gain: 25
B-Gain: 19
10P White balance: R|G|B
1: 1|1|0
2: 0|0|1
3: -3|-3|-4
4: -4|-3|-2
5: -10|-7|-5
6: -10|-9|-6
7: -10|-10|-8
8: -10|-10|-9
9: -10|-10|-10
10: -10|-10|-10
kanti123 is offline
post #14 of 21 Old 04-16-2012, 02:25 PM
Liked: 559
BlackLight: 7
Contrast: 92
Brightness: 44
Sharpness: 0
Color: 50
Tint: 50/50
Advance
BlackTone: Off
Shadow Detail: 0
Gamma: 2
Expert Pattern: off
RGB only: off
White Balance
R-Offset: 24
G-Offset: 25
B-Offset: 20
R-Gain: 24
G-Gain: 25
B-Gain: 19
1: 1|1|0
2: 0|0|1
3: -3|-3|-4
4: -4|-3|-2
5: -10|-7|-5
6: -10|-9|-6
7: -10|-10|-8
8: -10|-10|-9
9: -10|-10|-10
10: -10|-10|-10
to raise point gamma you need to lower the gamma setting, not raise it
post #15 of 21 Old 04-16-2012, 02:37 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
you need to lower contrast to get good greyscale and gamma.
then raise backlight.
I have the impression you are trying to get too much Ftl with contrast alone.
Loving D65
post #16 of 21 Old 04-16-2012, 02:41 PM
Liked: 559
to the contrary, contrast needs to be set in the low to mid 90s for Samsungs in order for the 10-pt controls to work properly
post #17 of 21 Old 04-16-2012, 02:43 PM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
My FTL is at 33 which is within the margin I believe
kanti123 is offline
post #18 of 21 Old 04-16-2012, 02:58 PM
Liked: 559
you should definitely be able to get gamma much flatter and closer to 2.2 at each point
try lowering the main gamma control to give you more range with the 10-pt controls
post #19 of 21 Old 04-16-2012, 04:02 PM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
Kk I will try that, I went ahead and buy CalMAN 4 for home user. So well see how that's go. I'm just curious, I see Alot of post talking about service menu. What is it may I ask
kanti123 is offline
post #20 of 21 Old 04-16-2012, 04:48 PM
Liked: 559
no need to go in there, it's a hidden menu that contains internal settings in the TV
you can easily brick your set in there, especially on the Samsungs, so I wouldn't recommend going in there
movie mode in the regular user menu has everything you could need/want for calibration purposes
post #21 of 21 Old 04-16-2012, 06:46 PM - Thread Starter
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
Ah thanks, Okay i'm still having trouble with this damn gamma. I am using Calman 4 now, my gamma still dipped at 50IRE. I have reset all my settings back to default and tried again. Still no luck.
kanti123 is offline
Reply Display Calibration
